Page 1 of 3
jessie added to main raspbian archive
Posted: Sun Jun 23, 2013 4:42 pm
by plugwash
jessie has now been added to the main raspbian archive.
Enjoy!
Re: jessie added to main raspbian archive
Posted: Sun Jun 23, 2013 4:43 pm
by redhawk
what is jessie??
Richard S.
Posted: Sun Jun 23, 2013 4:47 pm
by plugwash
jessie is the codename for the next version of debian/raspbian currently in "testing" (and will be for some time).
Posted: Sun Jun 23, 2013 5:01 pm
by malakai
I can't wait. I will just pretend I didn't read this and come back in a few months.
Posted: Sun Jun 23, 2013 7:10 pm
by shuckle
So how can it be used? I bet apt-get update will not find it?
Posted: Sun Jun 23, 2013 7:34 pm
by rpdom
shuckle wrote:So how can it be used? I bet apt-get update will not find it?
Edit your /etc/apt/sources.list
Change all lines that have "wheezy" to "jessie".
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
Posted: Mon Jun 24, 2013 6:03 pm
by frh_rpi
you can also use the 2 distributions at the same time thanks to apt pinning
in /etc/apt/sources.list
deb
http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
deb
http://archive.raspbian.org/raspbian wheezy main contrib non-free rpi
# Source repository to add
deb-src
deb
http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb
http://archive.raspbian.org/raspbian jessie main contrib non-free rpi
deb-src
create /etc/apt/preferences and, if you want to track jessie, put inside
Package: *
Pin: release n=jessie
Pin-Priority: 900
Package: *
Pin: release n=wheezy
Pin-Priority: 300
Package: *
Pin: release o=Raspbian
Pin-Priority: -10
Or, if you want to stick to wheezy
Package: *
Pin-Priority: 900
Package: *
Pin-Priority: 300
Package: *
Pin-Priority: -10
and then do apt-get upgrade
You will also be able to choose what version of a package you want by using:
apt-get install -t jessie <package>
Greetings all
Posted: Thu Jul 11, 2013 9:49 pm
by plugwash
So anyone running raspbian jessie yet?
Posted: Fri Jul 12, 2013 7:56 am
by rpdom
plugwash wrote:So anyone running raspbian jessie yet?
I wasn't planning to switch over to Jessie yet. I'm giving it a chance to settle down, after the Debian release of Wheezy as Stable. I like to keep all my systems (PCs and Pis) on the same version.
However, now that you've mentioned it, I will upgrade one Pi and see how it goes
Posted: Fri Jul 12, 2013 8:51 am
by bmstrong
Curious to see how it goes. Any real benefits over stable save for being bleeding edge?
Posted: Fri Jul 12, 2013 10:24 am
by rpdom
Ok Pi upgraded.
I had a problem with python3-numpy, where it spat out a load of messages
Preparing to replace python3-numpy 1:1.6.2-1.2 (using .../python3-numpy_1%3a1.7.1-2_armhf.deb) ...
File "/usr/bin/py3clean", line 32, in <module>
from debpython import files as dpf
EOFError: EOF read where not expected
dpkg: warning: subprocess old pre-removal script returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: error processing /var/cache/apt/archives/python3-numpy_1%3a1.7.1-2_armhf.deb (--unpack):
subprocess new pre-removal script returned error exit status 1
File "/usr/bin/py3compile", line 34, in <module>
from debpython.version import SUPPORTED, debsorted, vrepr, \
dpkg: error while cleaning up:
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
This seems to have happened to a few people using Ubuntu too, os it's not a Raspbian specific problem.
Someone suggested deleting the contents of /usr/share/python3/debpython/__pycache__ so I did that and ran the dist-upgrade again and it worked.
Posted: Sat Jul 13, 2013 1:02 am
by bmstrong
rpdom wrote:Ok Pi upgraded.
Say what? You can run Ubuntu on a Pi?
Posted: Sat Jul 13, 2013 4:09 am
by rpdom
bmstrong wrote:Say what? You can run Ubuntu on a Pi?
Not properly. But a few people seem to have managed to get it to work on a PC
, and they use python too...
Posted: Sat Jul 20, 2013 2:13 pm
by bmstrong
rpdom wrote:bmstrong wrote:Say what? You can run Ubuntu on a Pi?
So how has your Pi been running with the new image? Any noticeable improvements?
Posted: Mon Jul 22, 2013 7:57 pm
by hifi
If you want to test out jessie with a minimal install, raspbian-ua-netinst can certainly help you with that. It is not an official way to install Raspbian but should do the job quite well for power users who want less than the full SD image.
While jessie is currently not available in cdebootstrap suites it can still be used as the target release for raspbian-ua-netinst with clever scripting in the installer configuration script.
Example
installer-config.txt to install the server preset jessie:
release=jessie
cat >>/usr/share/cdebootstrap-static/suites <<EOF
Suite: jessie
Config: generic
Keyring: debian-archive-keyring.gpg
EOF
Please take note that the default apt sources list has the official raspberrypi.org repository which does not yet have jessie dist and will cause 404 errors on apt-get update. It should be possible to change the raspberrypi.org repo to use wheezy instead by manually adjusting /etc/apt/sources.list by hand.
For more information, full documentation and installer downloads,check out
https://github.com/hifi/raspbian-ua-netinst
Posted: Mon Jul 22, 2013 8:56 pm
by plugwash
BTW adding jessie to the main archive caused a massive traffic spike, I was expecting a spike but not one this big (the week after I added jessie to the main archive is marked as "week 26" on the graph.
Posted: Tue Jul 23, 2013 4:07 am
by rpdom
plugwash wrote:BTW adding jessie to the main archive caused a massive traffic spike, I was expecting a spike but not one this big
Perhaps a lot of people had their sources.list pointing at "testing" instead of "wheezy" and upgraded without realising?
Posted: Tue Jul 23, 2013 10:52 am
by jackokring
Just started the upgrade. Looks like it will take a while.
Any news on Qt 5.1, and is it included as a built package? Just checking, as the packages from twolife.be uninstalled qtcreator.
Posted: Tue Jul 23, 2013 1:51 pm
by plugwash
rpdom wrote:Perhaps a lot of people had their sources.list pointing at "testing" instead of "wheezy" and upgraded without realising?
I suspect it was more that we just seem to have a crazy number of mirrors nowadays.
jackokring wrote:Any news on Qt 5.1
It looks like so far QT5 is still only in experimental.
Posted: Tue Jul 23, 2013 7:18 pm
by jackokring
Ok with an external / and full SD /boot it works excepting the CTRL+D needed to get past the file not found error on /boot. Hopefully this is the start of a launch a different machine code file option.
EDIT: One more thing, the kernel firmware is still the rpi-update latest. So this may be related to the init ramdisk content.
EDIT2: False alarm, just needed a noauto in fstab on the unplugged media volume.
Jessie? It's big.
Posted: Fri Jul 26, 2013 6:19 pm
by hifi
Latest raspbian-ua-netinst has full jessie support out of box now. You just need to set the release to jessie as described earlier but do not need the cat hack anymore.
Example
Thanks to plugwash for patching the Raspbian cdebootstrap package until upstream (Debian) does it for theirs.
Posted: Tue Sep 10, 2013 4:09 pm
by Jahangir
First really thanks to port Jessie on the Rpi. Second I didn't see any other thread talking about it then I post this "report" here.
It seems the last version of Perl is missing from the repository index.
When I wanted to do an upgrade with aptitude it tells me :
The following packages have unmet dependencies:
libnet-ssleay-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
Depends: perlapi-5.18.1 which is a virtual package.
liblocale-gettext-perl : PreDepends: perl-base (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
PreDepends: perlapi-5.18.1 which is a virtual package.
libalgorithm-diff-xs-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libhtml-parser-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libtext-charwidth-perl : Depends: perl-base (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libossp-uuid-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libxml-parser-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libsocket-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libtext-iconv-perl : Depends: perl-base (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libjson-xs-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libclone-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
in the "Packages" file you can see it's saying 5.14, but when going manually on the server
http://mirrordirector.raspbian.org/rasp ... in/p/perl/ I see that the 5.18 is available.
I also checked the debian repository :
http://packages.debian.org/jessie/perl and it's clearly stating that the last version of perl is the 5.18 for Jessie.
Can you update the repository index to correct this ?
Thanks.
Posted: Tue Sep 10, 2013 8:23 pm
by plugwash
Unfortunately due to design limitations in the tools that handle migration between jessie-staging and jessie some packages have migrated from jessie-staging to jessie before things were really ready.
The only real way out of this now is to complete the transition to the new perl but that is going to take a while. Rebuiling hundreds of packages simply takes time.
Posted: Wed Sep 11, 2013 1:36 pm
by Jahangir
No problem, I completely understand. In every case, having the 5.14 or the 5.18 doesn't made any differences for me.
I just wanted to report the "wrong" index.
Posted: Thu Sep 12, 2013 7:05 pm
by plugwash
perl has now migrated from jessie-staging to jessie but you may still find some packages perl related packages are uninstallable for a few more days.
