MrWm
Re: jessie added to main raspbian archive
Fri Jul 04, 2014 9:36 pm
Well... This might be an old thread, but I am wondering if Debian Unstable aka "sid" is available for us to point our sources.list.
Or is it discouraged/not available :?:
LOOK! A RAINBOW!!!
joan
Fri Jul 04, 2014 9:42 pm
As far as I'm aware Raspbian only tracks the stable and testing distributions of Debian.
You'd have to be using Debian (soft-float) to track unstable (sid).
gowen
Mon Jul 14, 2014 9:18 am
hifi wrote:Latest raspbian-ua-netinst has full jessie support out of box now. You just need to set the release to jessie as described earlier but do not need the cat hack anymore.
Example installer-config.txt to install the server preset jessie:
release=jessie
I've just tried to create a jessie install using this method. Everything appeared to work fine until the reboot at the end, where I was presented with a shaded blue band down the middle of the screen and only the pwr led lit. After a while the screen power saver kicked in.
I've now tried the install twice on different monitors and get the same result. Any ideas?
Mon Jul 14, 2014 10:20 pm
I've just had the exact same results with raspbian-ua-netinst 1.0.2 trying to install wheezy.
EDIT: There's a solution here: https://github.com/debian-pi/raspbian-u ... /issues/68 by editing the config.txt file to point to the 3.12-1 initramfs (rather than 3.10-3).
gowen
Tue Jul 15, 2014 8:03 am
DougieLawson wrote: There's a solution here: https://github.com/debian-pi/raspbian-u ... /issues/68 by editing the config.txt file to point to the 3.12-1 initramfs (rather than 3.10-3).
Thanks Dougie, that worked like a charm.
For anyone else with this problem:
1. Run the install until you get the blue band.
2. Take your SD card out of the Pi and place it in a PC/Mac.
3. Open the boot partition. It's in FAT format so can be read on just about anything.
4. Many of the files in this directory are named with the version. E.g. initrd.img-3.12-1-rpi. Make a note of this number.
5. Open the config.txt file and change the "initramfs initrd.img-3.10-3-rpi" line to match the current version.
6. Save the file and eject the SD card.
7. Put the card back in the Pi and power it on. Fingers crossed, it should now boot.
diederik
Wed Jul 16, 2014 9:04 pm
DougieLawson wrote:
gowen wrote: I've just tried to create a jessie install using this method. Everything appeared to work fine until the reboot at the end, where I was presented with a shaded blue band down the middle of the screen and only the pwr led lit. After a while the screen power saver kicked in.
raspbian-ua-netinst 1.0.3 has just been released, which fixes this issue.
Outersyn
Tue Oct 28, 2014 2:55 am
Hi, after a system update (sudo apt-get update; sudo apt-get upgrade and dist-upgrade ) tonight and a reboot, the display is stuck in a loop:
1. display blanks
2. X pointer flashes
3. These messages are printed to the console:
bcm2708_fb_pan_display(0,0) returns=0
(...over and over)
I tried by doing Ctrl+Alt+F4 and then running a rpi-update, but didn't helped, also I restored the boot partition with a backup, with no results. Anyone else had this error? Can anyone help me?
PD: Sorry if there's anything wrong with my english, i'm not a native speaker
ddd1600
Fri Jan 02, 2015 2:09 am
Upgrading to jessie causes my bootup to crash every time no matter what I do.
Here's what I see before I die:
[FAILED] Failed to start Modem Manager.
See 'systemctl status ModemManger.service' for details.
And then my startup crashes. Never moves, freezes, that's the end.
Micha1982
Sat Jan 03, 2015 5:01 am
Also some problems after update, upgrade and dist-upgrade (!)...it starts, but taskbar has strange colors, windows and pointer often flickering...as if something got terribly wrong.
Dont know what exactly...but already read that there is a new desktop? Think I am going to install it completly fresh and new. Sure a lot of work, but then I know everything is fresh and clean, actual and hopefully working again.
In the meanwhile I´ll have a closer look at RiscOS.....
Alles, was schiefgehen kann, wird auch schiefgehen.
Fght
Mon Feb 23, 2015 10:00 pm
rpdom wrote:
shuckle wrote:So how can it be used? I bet apt-get update will not find it?
Edit your /etc/apt/sources.list
Change all lines that have "wheezy" to "jessie".
sudo apt-get update
sudo apt-get dist-upgrade
during installation from the raspbian of the first two commands i was receiving some yes or no questions... i'm not sure if i chose the right answers. right now i'm in the last command.
is there a chance the installation won't be installed properly because of wrong choices?
PeterO
Tue Feb 24, 2015 8:09 am
I tried this last evening on a Pi2. I wanted to see if the Qt5 development environment worked on Jessie, but it was a waste of time. qtcreator failed to run because it seemed to want to use openGL and didn't fall back to anything else and just exited!
PeterO
Tue Feb 24, 2015 9:52 am
I've been running Jessie for ages on one of my Bs. Last night I reverted my 2B to Wheezy because systemd is just too unstable to use. I've gone with the /etc/apt/preferences route so I could install MariaDB on a Wheezy install.
I wasted a lot of time doing battle with systemctl and journalctl to try to fathom why systemd wasn't working (stuff would start at some boots but not the next) and was the PID 1 systemd task was running 100% busy on one of the four cores.
It was a pain reverting, I'd done a lot of work to get my 2B ready to replace my old Viglen MPC-L.
plugwash
Tue Feb 24, 2015 10:13 am
Theres also the option of running jessie with sysvinit.
Tue Feb 24, 2015 10:18 am
plugwash wrote:Theres also the option of running jessie with sysvinit.
I was trying to embrace the future. But at the moment systemd is seriously awful. It'll be a long time before Wheezy is replaced while that mess is sorted out.
I'm going to stick with Wheezy on my 2B server because I need a stable system.
Shoka
Tue Feb 24, 2015 10:11 pm
When "professional beta testers" decide something is too flaky to tinker with, mere mortals should steer a mile clear methinks :cry:
Cheers Harry
asandford
Tue Feb 24, 2015 10:40 pm
DougieLawson wrote:I've been running Jessie for ages on one of my Bs. Last night I reverted my 2B to Wheezy because systemd is just too unstable to use. I've gone with the /etc/apt/preferences route so I could install MariaDB on a Wheezy install.
Glad it wasn't just me, recently it's gone mental (misery loves company :) ).
dickg4bbh
Sat Apr 25, 2015 10:40 am
Is this still a valid way of upgrading? I have a spare microSD card for my RPi2 loaded with latest wheezy updates and want to have a look at jessie. OK I realise there may be bugs :-)
Richard
sudo apt-get update
Sat Apr 25, 2015 10:55 am
dickg4bbh wrote:Is this still a valid way of upgrading? I have a spare microSD card for my RPi2 loaded with latest wheezy updates and want to have a look at jessie. OK I realise there may be bugs :-)
Richard
sudo apt-get update
Yes, but you may be dissapointed with the end result ;)
adieu
My other Computer is an Asus CS10 ChromeBit
Claggy
Sat Apr 25, 2015 11:50 pm
Richard
sudo apt-get update
I updated a new Pi Model B installation to Jessie a week or so ago without problems, where previously it wouldn't complete the boot,
Claggy
dickg4bbh
Sun Apr 26, 2015 1:19 am
Thanks Claggy. I have now done an upgrade to jessie and it seems to work. There were a whole bunch of questions about updating various packages. I went with the default (N) each time. There is a minor hiccup with alsa sound when my existing application switches between input and output but should be resolvable. I am having no problems using the VNC server and accessing the RPi via the internet..
Richard
milkmandan
Sun Apr 26, 2015 6:02 am
any chance we'll see a stable distro of Raspbian with Jessie @ https://www.raspberrypi.org/downloads/ soon?
I am mid working on a project with my rpi, but if a new image coming soon, I'd rather hold out instead of editing my /etc/apt/sources.list and running upgrades as I don't want to be "disappointed with the end results". :oops:
Sun Apr 26, 2015 6:28 am
milkmandan wrote:any chance we'll see a stable distro of Raspbian with Jessie @ https://www.raspberrypi.org/downloads/ soon?
I doubt it will be "soon", but it shouldn't be very long before that happens. I'd be very surprised if there aren't a number of people looking at what is required for generating and supporting a Jessie image right now.
Some of the existing documentation will probably need to be re-written due to the significant changes in the way the default init system in Jessie works. Using that correctly is going to be a big learning curve for some of the more experience Linux users.
justinsb
Wed Apr 29, 2015 9:24 pm
Something to bear in mind is that the upgrade process will completely fill a 4gb SD card, so it's not worth trying it on anything less than an 8gb one, says he, speaking from experience here... I had to dd my 4gb card onto an 8gb one & expand the partition, but thankfully it picked up the upgrade where it had crashed out & completed it all OK.
gdt
Thu Jun 11, 2015 1:27 pm
Some notes I made upgrading a Raspberry Pi2 from Raspbian Wheezy to Raspbian Jessie. The notes are particularly strong on solving post-upgrade issues which prevent successful boot (udev rules, ifplugd, cgroups, systemd-stub, etc). Enjoy.
olivier2831
Thu Jun 11, 2015 1:57 pm
gdt wrote:Some notes I made upgrading a Raspberry Pi2 from Raspbian Wheezy to Raspbian Jessie. The notes are particularly strong on solving post-upgrade issues which prevent successful boot (udev rules, ifplugd, cgroups, systemd-stub, etc). Enjoy.
Very interesting !
Return to “Raspbian”
