sander2
netstat gives "InOctets: -1" after 4.2+GB
Tue Jun 18, 2013 9:24 pm
This looks like a bug in netstat on Raspbian. The problem does not occur on Ubuntu 32-bit (nor 64-bit)
"netstat -s" gives "InOctets: -1" and stays on that value
pi@raspberrypi ~ $ netstat -s | grep -i octet | grep -vi cast
    InOctets: -1
    OutOctets: 79624814
pi@raspberrypi ~ $
This seems to happen after receiving 4.2GB; see logging below which happened after download a few ISO-images in another terminal. So some kind of 32-bit counter overflow?
FWIW: ifconfig shows " RX bytes:2868081491 (2.6 GiB) TX bytes:52829058 (50.3 MiB)", meaning 4.2 + 2.6 = 6.8GB
Note:
- ifconfig on 32-bit OS is a 32-bit counter.
- netstat seems to be a two's complement 32-bit counter (even on 64-bit Ubuntu), so therefore the negative values before locking on -1
Google seems to only give results with "Client data" ... some kind of reporting data, and ... on armv6l and 3.2.2-kvm-i386
Tips welcome.
    InOctets: 135846329
    OutOctets: 551351
pi@raspberrypi ~ $
    InOctets: 201321541
    OutOctets: 794419
    InOctets: 412541238
    OutOctets: 1825179
pi@raspberrypi ~ $
    InOctets: 1349541109
    OutOctets: 6815405
    InOctets: -2128487815
    OutOctets: 10995377
    InOctets: -1124081361
    OutOctets: 15466277
    InOctets: -435327466
    OutOctets: 18907355
    InOctets: -1
    OutOctets: 25297311
pi@raspberrypi ~ $
aaa801
Re: netstat gives "InOctets: -1" after 4.2+GB
Tue Jun 18, 2013 9:46 pm
Sounds like a overflow to the sign bit,
what does cat /proc/net/netstat
print out ?
Also this will prob fix it
http://net-tools.git.sourceforge.net/gi ... 03eb43e34d
sander2
Tue Jun 18, 2013 10:11 pm
Wow, that looks good: 20768496576, so 20.768.496.576 octes = 20 GB. So it's just a matter of presentation?
pi@raspberrypi ~ $ cat /proc/net/netstat  | awk '{ print $8 }'  | tail -2
InOctets
20768496576
InOctets
20913680964
InOctets
21758842200
pi@raspberrypi ~ $
Do you know the git URL of http://net-tools.git.sourceforge.net/ so that I can do a "git clone ..."?
EDIT: found it:
git clone git://net-tools.git.sourceforge.net/gitroot/net-tools/net-tools
... I'm now compiling it ...
sander2
Tue Jun 18, 2013 10:45 pm
And ... solved with the the git version of net-tools/netstat:
pi@raspberrypi ~/git/net-tools $ ./netstat --version
net-tools 2.10-alpha
Fred Baumgarten, Alan Cox, Bernd Eckenfels, Phil Blundell, Tuan Hoang, Brian Micek and others
+NEW_ADDRT +RTF_IRTT +RTF_REJECT +FW_MASQUERADE -I18N
AF: (inet) +UNIX +INET +INET6 +IPX +AX25 +NETROM +X25 +ATALK +ECONET +ROSE -BLUETOOTH
HW:  +ETHER +ARC +SLIP +PPP +TUNNEL -TR +AX25 +NETROM +X25 +FR +ROSE +ASH +SIT +FDDI +HIPPI +HDLC/LAPB +EUI64
pi@raspberrypi ~/git/net-tools $ ./netstat -s  | grep -i octet | grep -vi cast
    InOctets: 44243492434
    OutOctets: 216890158
pi@raspberrypi ~/git/net-tools $ ./netstat -s -6 | grep -i octet | grep -vi cast
    Ip6InOctets: 773754535
    Ip6OutOctets: 333902508
So: counter is now at 44GB, well above 4.2GB. Great.
And now I wish Raspbian (or Debian?) incorporates this new version of net-tools / netstat into the distribution.
rpdom
Wed Jun 19, 2013 4:20 am
sander2 wrote:And now I wish Raspbian (or Debian?) incorporates this new version of net-tools / netstat into the distribution.
It is a known bug, for which a patch is available. However the severity is "normal", so lower importance than all the "release critical" bugs that needed fixing before Debian moved their stable release to Wheezy. I suspect it will get fixed at some point in Jessie.
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=640480
sander2
Wed Jun 19, 2013 6:18 am
Thank you for your help and explanation!
Return to “Raspberry Pi OS”
