Hi dears! I have a similar situation.
Please advise on how the issue can be solved.
[email protected]:/home/pi# apt-get update
Get:1
http://mirrordirector.raspbian.org jessie InRelease [15.0 kB]
Get:2
http://archive.raspberrypi.org jessie InRelease [13.2 kB]
Get:3
http://mirrordirector.raspbian.org jessie/main armhf Packages [8,963 kB]
Get:4
http://archive.raspberrypi.org jessie/main armhf Packages [143 kB]
Hit
http://archive.raspberrypi.org jessie/ui armhf Packages
Hit
http://archive.raspberrypi.org jessie/staging armhf Packages
Ign
http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign
Ign
http://archive.raspberrypi.org jessie/staging Translation-en_GB
Ign
Ign
http://archive.raspberrypi.org jessie/ui Translation-en_GB
Ign
Get:5
http://mirrordirector.raspbian.org jessie/contrib armhf Packages [37.5 kB]
Get:6
http://mirrordirector.raspbian.org jessie/non-free armhf Packages [70.3 kB]
Get:7
http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1,356 B]
Ign
http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign
Ign
http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign
Ign
http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign
Ign
http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Ign
Fetched 9,244 kB in 49s (185 kB/s)
Reading package lists... Done
while performing upgrade:
[email protected]:/home/pi# apt-get upgrade
(the full log is in the attachment)
Processing triggers for man-db (2.7.0.2-5) ...
/usr/bin/mandb: can't write to /var/cache/man/891: No space left on device
/usr/bin/mandb: can't write to /var/cache/man/1357: No space left on device
Processing triggers for gnome-menus (3.13.3-6) ...
Processing triggers for desktop-file-utils (0.22-1) ...
Processing triggers for mime-support (3.58) ...
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 1, near "my $mask = ""
(Missing semicolon on previous line?)
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 1, near """
Number found where operator expected at /usr/share/perl/5.20/warnings.pm line 2, near ""5.11"
(Might be a runaway multi-line "" string starting on line 1)
(Missing operator before 5.11?)
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 2, near """
Number found where operator expected at /usr/share/perl/5.20/warnings.pm line 3, near ""5.15"
(Might be a runaway multi-line "" string starting on line 2)
(Missing operator before 5.15?)
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 3, near """
Bareword found where operator expected at /usr/share/perl/5.20/warnings.pm line 4, near ""all"
(Might be a runaway multi-line "" string starting on line 3)
(Missing operator before all?)
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 4, near """
Bareword found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near ""default"
(Might be a runaway multi-line "" string starting on line 4)
(Missing operator before default?)
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "$feature_bundle{""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "5.12"} = $feature_bundle{""
(Missing operator before "} = $feature_bundle{"?)
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "5.13"} = $feature_bundle{""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "5.14"} = $feature_bundle{""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "5.16"} = $feature_bundle{""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "5.17"} = $feature_bundle{""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "5.18"} = $feature_bundle{""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "5.19"} = $feature_bundle{""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "5.20"} = $feature_bundle{""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "5.9.5"} = $feature_bundle{""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "croak(""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "if (substr($name, 0, 1) eq ""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "croak(sprintf('Feature bundle ""
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "ed' => ""
Backslash found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "x20\"
Backslash found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "x00\"
String found where operator expected at /usr/share/perl/5.20/warnings.pm line 5, near "'digit' => ""
Backslash found where operator expected at /usr/share/perl/5.20/warnings.pm line 6, near "'digit' => "\"
(Might be a runaway multi-line "" string starting on line 5)
(Missing operator before \?)
Backslash found where operator expected at /usr/share/perl/5.20/warnings.pm line 6, near "x00\"
