joacliba
Old versions of raspbian on a new raspberry
Wed Jun 12, 2013 10:11 am
Hi, because I couldn't downgrade kernel to 3.2 in the last raspbian image, I tried old versions with my raspberry without success.
I only can boot 2013 versions of firmware, with 2012 raspberry doesn't boot (black screen). I follow the same procedure and I tried with 2 methods (PiWritter and with dd command on OSX). without luck.
Is there a difference between old firmwares?
mahjongg
Re: Old versions of raspbian on a new raspberry
Wed Jun 12, 2013 10:24 am
Old firmwares may not know the configuration parameters of a newer RAM device, that your new PI might use,
The trick is to replace the /boot files of the older distro with the ones used by a new distro.
joacliba
Wed Jun 12, 2013 10:33 am
So If I want to have the kernel of the 16-12-2012 raspbian I need to replace all /boot except the kernel.img? Or there are more files that I don't have to replace in /boot?
Thanks!
RaTTuS
Contact: Twitter YouTube
Wed Jun 12, 2013 10:37 am
possibly you can get away with
bootcode.bin
YMMV
why do you need an old version of raspbian?
Covfefe
joacliba
Wed Jun 12, 2013 10:45 am
RaTTuS wrote:possibly you can get away with
bootcode.bin
YMMV
I need a working 3.2 kernel because more newer kernels have a bug with my arcade joystick (up and left axis don't work).
I tried to downgrade in the last raspbian without luck, it boots but applications don't work. So I need to try an older firmware with 3.2 kernel.
Now I can boot the 16-12-2012! Let's go to test joystick and advancemame.
Thank you!
EDIT: No, with this configuration I have the 3.2 kernel, the system boots but X doesn't work.
joacliba
Wed Jun 12, 2013 6:24 pm
Trying with the files I see that the file I need to replace for boot the old version is the start.elf.
Replacing only that file (and with all /boot) I can boot the raspberry but not startx (the system freezes).
So now, I can't downgrade the last raspbian to a 3.2 kernel and I can't boot an old version of raspbian with the 3.2 kernel.
No 3.2 kernel for me :(
Any idea?
Return to “Raspbian”
