mpthompson said:
Abishur said:
I don't suppose while we're tweaking things, we could make it so that Debian doesn't stall for a long time when loading the R-Pi when it's not connected to a network? Probably the wrong place to bring this up, but I thought I'd throw it out there for what it's worth
As it seems the Foundation will have a new Debian armel image out soon, you may want to send them suggestion to look into that issue. Since I and 99.999% of everyone else here doesn't have any real hardware we have no way off addressing the issue. In any case, we will be using the same exact kernel that Debian armel is using.
This is fixed in the next release. Also some other issues with Mac addresses being stored (so an SD card from one Pi has a 'hardcoded' Mac address which goes pear shaped when used on another Pi - or something like that). There's also a fix to set the clock on startup to the date of the latest log entry. Won't be accurate, but at least will be incrementing. Sure there is a load of other stuff as well. Was talking to the guy doing it all, he's been looking at wireless stuff, but that's difficult to make generic enough because of all the different firmwares required for different adapters.
