gkreidl
Re: Minimal Kiosk Browser
Mon Mar 23, 2015 9:47 pm
PuppetHoundZ wrote:Awesome, I can't wait for the OMX Player update! :geek:
I hope that my Raspberry Pi 2 comes out soon so that I can test out your browser performance with that too ;)
The update to 1.6.4 will be published tomorrow.
Minimal Kiosk Browser (kweb)
mrtee37
Mon Mar 23, 2015 10:01 pm
I am running a set of results screens consisting of a raspberry pi, 32" tv in portrate mode and a wifi dongle. The screen displays a scrolling webpage via kweb in kiosk mode. I intend to have no keyboard attached. Following the kweb setup instructions the unit auto starts and displays well.
Every now and again i get a blank screen with the "unable to load page message", with a keyboard attached an alt "r" sets the screen running again. Is there any way of detecting the blank screen and automatically sending a alt"r" to the unit.
frackers
Mon Mar 23, 2015 11:30 pm
Greetings
I'm also trying to use autoplay in a private kiosk app - having downloaded the source tarball I can find no reference to this html5 property and hence to enable it. Is it hidden in the binary somehow?
gkreidl
Tue Mar 24, 2015 10:16 am
mrtee37 wrote:I am running a set of results screens consisting of a raspberry pi, 32" tv in portrate mode and a wifi dongle. The screen displays a scrolling webpage via kweb in kiosk mode. I intend to have no keyboard attached. Following the kweb setup instructions the unit auto starts and displays well.
No. You should try to find the reason why the page cannot be accessed and fix it.
gkreidl
Tue Mar 24, 2015 10:18 am
frackers wrote:Greetings
Yes it's hard compiled into the binary. I can send you a binary of kweb3 with autoplay enabled. Send me a PM with your email address.
gkreidl
Tue Mar 24, 2015 8:55 pm
Version 1.6.4 is now available.
Update it from within your browser (menu or control panel page).
Read the changelog for details.
toti_ste
Thu Mar 26, 2015 10:22 am
First of all thank you for this browser. I think this is exactly what I am looking for.
Now I have following error message during install :
Error during install: 'Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 Not Found
'cp: cannot stat `/usr/local/share/kweb/ktop': No such file or directory
Maybe I missed something. Can you help please?
mrtee37
Thu Mar 26, 2015 1:41 pm
Thanks. I have WiFi_Check running in cron andit will reestablish a wifi link ( i can ssh via Wifi) but the browser wont refresh without manual intervention. If i have a wifi network connection what else should i be looking for? Is the ."unable to load page message" generated within the browser and what triggers it?
Mrtee
gkreidl
Thu Mar 26, 2015 2:53 pm
mrtee37 wrote: Thanks. I have WiFi_Check running in cron andit will reestablish a wifi link ( i can ssh via Wifi) but the browser wont refresh without manual intervention. If i have a wifi network connection what else should i be looking for? Is the ."unable to load page message" generated within the browser and what triggers it?
Mrtee
It's triggered withing the webkit engine if the URL cannot be loaded (usually a network problem).
You could send a refresh message from a script using xdotool.
xdotool key alt+r
PuppetHoundZ
Thu Mar 26, 2015 10:54 pm
I tested the update yesterday.
It works great. Either OMXplayer update or your browser has made the OMXPlayerGUI much more stable. I can now change the size of the gui much more smoothly without those jumps that sometimes crash OMXPlayerGUI.
I really wish Raspberry Pi Foundation would utilize your browser as the default it really is the most powerful and media center like browser on the Pi. All they would have to do is reskin the icons and interface a bit and it will be perfect.
Keep up the good work.
PS is there a way to make the Kweb GUI smaller on the top without having to hide it?
gkreidl
Thu Mar 26, 2015 11:22 pm
PuppetHoundZ wrote:I tested the update yesterday.
Set the small icons option and the icons only option (or use text buttons only).
You can also select another icon set using lxappearance. I've used only system icons. You can download additional icon themes from the Raspbian repository.
The smooth moving and resizing of the video window without breaks has been accomplished by the new omxplayer version (highly recommended!). I've just modified some small things in omxplayerGUI to make better use of it.
Ulfasti
Mon Mar 30, 2015 9:48 am
Is it possible to block ads with this browser?
Thank you for your hard work!
gkreidl
Mon Mar 30, 2015 10:26 am
No, but disabling Javascript, where applicable, removes a lot of ads.
michaelfranz
Mon Mar 30, 2015 10:47 am
Can I please have such a version ? :)
Trying to run a kiosk where I need to run videos which should play automatically.
Thanks in advance
gkreidl
Mon Mar 30, 2015 11:20 am
michaelfranz wrote: Can I please have such a version ? :)
Thanks in advance
wget http://steinerdatenbank.de/software/kweb3-1.6.4-autoplay.tar.gz
tar -xzf kweb3-1.6.4-autoplay.tar.gz
sudo mv kweb3 /usr/bin
michaelfranz
Mon Mar 30, 2015 11:44 am
Thanks in advance
That was fast ;) Thanks man!
gkreidl
Mon Mar 30, 2015 11:52 am
michaelfranz wrote:[
I'm prepared for it, as quite a number of people have been asking for it.
Mon Mar 30, 2015 12:20 pm
Ulfasti wrote:Is it possible to block ads with this browser?
Run a local ad-blocking squid3 proxy and route your HTML traffic through that.
djole94hns
Tue Mar 31, 2015 11:41 am
First, I must say, I'm fairly impressed with this piece of software, really made my life easier with omxplayerGUI :)
But I have a teeny problem:
Now, in Epiphany, when I go to youtube.com, all the video titles and button names are bold. :?
Any way to revert this change?
ktb
Tue Mar 31, 2015 11:45 am
Dougie, do you know if that performs better than just using a huge hosts file?
EDIT: Thanks Dougie, that is a good point.
Tue Mar 31, 2015 11:48 am
Sorry I don't I'm running firefox/chrome with an ad-blocker plugin on my Windows browsers. I don't use my Raspberries for web surfing.
Big hosts file isn't optimised for read, to find the 100,000th record you have to read 99,999 earlier records. With a proxy it's more likely to use a properly indexed database to reduce seek time.
gkreidl
Tue Mar 31, 2015 12:19 pm
djole94hns wrote:First, I must say, I'm fairly impressed with this piece of software, really made my life easier with omxplayerGUI :)
kweb introduces no change that can affect epiphany in any way. Both kweb3 and epiphany use the same webkit and javascript engine.
Terratic
Thu Apr 02, 2015 5:22 am
toti_ste wrote:Hello,
I'm also getting this error.
gkreidl
Thu Apr 02, 2015 6:39 am
Run
sudo apt-get update
sudo apt-get upgrade
If you haven't updated for many months, also run
sudo apt-get dist-upgrade.
Then try installing kweb again.
eriktheitalian
Thu Apr 02, 2015 8:03 am
Best adblock for low performance devices is editing host file. Puppy linux like lightweight distros have internal solutions for this. They have automated host file building.This is universal solution.
Don't use lot question like "why not?" This is raspberrryyyyy! (not spartaaa. if u need sparta go and buy x86) lol
I cant using enough English language. My writings can be wrong grammer.$
"in micro$oft we not trust"
Return to “Raspberry Pi OS”
