Error: command youtube-dl not foundgkreidl wrote:runjakky567 wrote: I'm in the United States, I think that particular example is blocked wherever you're at unfortunately.from the command line. What does it report?Code: Select all
youtube-dl -g https://www.youtube.com/watch?v=qVr4h7A3BWM
Re: Minimal Kiosk Browser
Didn't you install it during installation of the kweb package? Does the folder "/home/pi/youtube-dl" exist?jakky567 wrote:Error: command youtube-dl not foundgkreidl wrote:runjakky567 wrote: I'm in the United States, I think that particular example is blocked wherever you're at unfortunately.from the command line. What does it report?Code: Select all
If not, run:
ginstall-ytdl
update-ytdl
Minimal Kiosk Browser (kweb)
I did a full reinstall and have noted it's just videos blocked in Germany that do not work. Oh well.
When displaying a video via an iframe's src value does the browser emit any javascript events for on video end or finish or video error?
Also does anyone have any experience with kweb3's performance of an angularjs app?
I'd like to build a simple digital signage app and I'm considering using angularjs and kweb3 for the client.
Thanks!
Thanks!
No, but with the help of the ytdl-server (running on the local RPi) you can send dbus commands to the player which may return values. It's possible to get get the duration and the current position of the video.wmwood wrote:When displaying a video via an iframe's src value does the browser emit any javascript events for on video end or finish or video error?
Thanks!
Check the developer's section of the omxplayerGUI manual for details.
I am using a translator, my English is not good.
I installed the plugien in google chroem and it works wonders, I just wanted to see if you may repodusca a list of youtube videos without stopping, as I now play a single video and to continue should precionar play in the proxime video. It's not like browser directly put autoplay videos on youtube and passes the list. Thank you
The translator may be worse than your Englisharielf wrote:I am using a translator, my English is not good.
The combination of chromium-broser, rpi-youtube plugin and omxplayerGUI will work for channels, playlists and search results but you ma have to wait for 30 seconds or more, before it starts playing. The player window will contain a list of all videos found and play them one after the other.
After a full reinstall of kweb, this got me this in the terminalgkreidl wrote:runjakky567 wrote: I'm in the United States, I think that particular example is blocked wherever you're at unfortunately.from the command line. What does it report?Code: Select all
https://r3---sn-n0qqxoapo3-utgl.googlev ... bypass=yes
Running that link in Omxplayergui closes the gui when opened.
try (from a terminal)jakky567 wrote:Running that link in Omxplayergui closes the gui when opened.
omxplayer "link"
where "link" is the link you got from youtube-dl (must be quoted!)
If you get the famous "Have a nice day", run
omxplayer -i "link"
The link might have been expired, so get it again before you test it with omxplayer.
I'm using omxplayer gui for a kiosk code. I only want the play button, timeline and close button. Is it possible to hide all other buttons?
Fazil
Fazil
I'm running kweb3 on a Jessie build.
In the bookmark utility i've created a linkwhich works perfectly. When I put the same address into the URL start page box of the configuration page and save it the address comes back truncated before the first ampersand. Do I need an escape character to use the ampersand character in the text box?
http://login:passwd@IP:PORT/live?cameraNum=0&cameraNum=1&cameraNum=2&cameraNum=3&viewMethod=0
Here is the result!
pi@raspberrypi:~ $ omxplayer "https://r3---sn-n0qqxoapo3-utgl.googlev ... 1469520769"
have a nice day
[1]+ Stopped omxplayer https://r3---sn-n0qqxoapo3-utgl.googlev ... ps=2131250
[16] Done itag=43
[17] Done requiressl=yes
[20] Done mn=sn-n0qqxoapo3-utgl
[26] Done sver=3
pi@raspberrypi:~ $ omxplayer -i "https://r3---sn-n0qqxoapo3-utgl.googlev ... 1469520769"
Input #0, matroska,webm, from 'https://r3---sn-n0qqxoapo3-utgl.googlev ... 1469520769':
Metadata:
encoder : Google
Duration: 00:22:36.62, start: 0.000000, bitrate: 604 kb/s
Stream #0:0: Video: vp8, yuv420p, 472x360, SAR 1:1 DAR 59:45, 29.97 fps, 29.97 tbr, 1k tbn, 1k tbc (default)
Stream #0:1: Audio: vorbis, 44100 Hz, stereo, fltp (default)
have a nice day
have a nice day
[16] Done itag=43
[26] Done sver=3
Metadata:
encoder : Google
have a nice day
You need the extended firmware to play VP8 video. In /boot/config.txt add
and reboot.
start_x=1
Thank you for that, I forgot I turned off the camera module when I was messing around with the opengl driver. Very much appreciated, keep up the great work. Out of curiosity, is there anyway to specify what video compression format YouTube-dl pulls?gkreidl wrote:You need the extended firmware to play VP8 video. In /boot/config.txt addand reboot.Code: Select all
start_x=1
Yes, a lot. omxplayerGUI uses by default:jakky567 wrote: Thank you for that, I forgot I turned off the camera module when I was messing around with the opengl driver. Very much appreciated, keep up the great work. Out of curiosity, is there anyway to specify what video compression format YouTube-dl pulls?
-f best
This will produce the best resolution which sends video and audio in one stream. On youtube this is usually 720p (1080p would be send as separate audio and video streams which omxplayer cannot handle). On vimeo.com this will usually be 1080p. There are lots options for youtube-dl, but not all will work with omxplayerGUI.
Version 1.7.3
Version 1.7.3 is now available.
You can update from within kweb or from kusti8's repository.
I've also rewritten the OP to better match current development.
Re: Kweb Suite (Minimal Kiosk Browser)
O..p, update...forgot omxplayer-gui setting save file name, where is it location?
The settings are in /usr/local/share/kweb_settings.pycjan wrote:O..p, update...forgot omxplayer-gui setting save file name, where is it location?
But you should better use the web interface. Start omxplayerGUI from the program menu and click on "Edit Settings".
If you had created your own preset before, you can get your settings back (after an upgrade) by clicking the preset's name.
Hi!
First to start with, thank you for your browser.
For me it was easy to install en use.
Second I'm a noob.
I'm trying to load this page in kiosk mode http://www.buienradar.nl/nederland/neer ... dig-scherm but is doesn't load fully.
I don't know what is.
Because this page does load http://www.buienradar.nl/nederland/neerslag/buienradar and I 'think' it's the same page except the other weather view is bigger.
Hope you can help me, or explain what the problem is or even help me.
That would be great.
Greetings,
Jsprs
Second I'm a noob.
Greetings,
Jsprs
This page is built completely from Javascript and contains browser-specific code. It doesn't work in any webkit based browser. In Firefox it has bugs (a flashing blue bar), in chromium it works until you do too much zooming.Jsprs wrote:Hi!
Second I'm a noob.
Greetings,
Jsprs
Does there happen to be any way that I could execute a script upon page load using KWeb commands? The problem I'm having is that the webpage automatically moves between content of different file types, but when I try to move from a PDF file to a normal webpage, evince stays on top of the KWeb window.
Basically the script would kill evince when a page is loaded, so that KWeb would be the foremost application again.
Any help with this is appreciated.
If the HTML pages are local files, it's easy. If they come from web server it is more complicated but can be done; it's possible to transfer the command interface to a certain URL (L option). It has not been tested very much. I would use local files for development and transfer it to a server if everything is working well.Brutick wrote:Does there happen to be any way that I could execute a script upon page load using KWeb commands? The problem I'm having is that the webpage automatically moves between content of different file types, but when I try to move from a PDF file to a normal webpage, evince stays on top of the KWeb window.
The script itself must be on the client. To avoid a terminal popping up you have to add it to the direct_command list.
It's important to understand how the command interface works (manual page 62 and following)
someone can tell me if youtube videos alone without precionar start the play button? autoplay option
No. Not possible.arielf wrote:someone can tell me if youtube videos alone without precionar start the play button? autoplay option
