unclejed613
resize root partition, but not to fill whole card
Thu Mar 28, 2013 2:34 am
i'd like to resize the root partition on the raspi. it's a 4G image on an 8G card. the thing is, i want to keep a rather large pool of unused cells for wear leveling, so i only want to expand the partition by 1 or 2G. is there any safe way to do this?
pluggy
Re: resize root partition, but not to fill whole card
Thu Mar 28, 2013 6:53 am
Personally I'd put the card in another Linux box and attack it with gparted.
jmranger
Fri Mar 29, 2013 4:18 am
Given that not all SD/SDHC/SDXC cards do wear leveling, that it's pretty much impossible to tell whether a specific card is doing wear leveling, that an 8GB card is only worth a few $/€/£, that the card should last quite some time anyway, and that the replacement card will cost even less when yours die... I wouldn't bother.
But to answer your question, you can create an extra (3rd) partition using fdisk (device /dev/mmcblk0) at a specific location, reboot and perform the partition enlarge operation, and then delete the extra partition. I just did exactly that (except for the final delete) to setup a dedicated swap partition.
Good luck!
Return to “Raspbian”
