root@raspberrypi:~# apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
isc-dhcp-client : Depends: isc-dhcp-common (= 4.2.2.dfsg.1-5+deb70u2) but 4.2.2.dfsg.1-5+deb70u3 is installed
E: Unmet dependencies. Try using -f.
root@raspberrypi:~# apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libblas3gf liblapack3gf
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
isc-dhcp-client
Suggested packages:
resolvconf avahi-autoipd
The following packages will be upgraded:
isc-dhcp-client
1 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
106 not fully installed or removed.
Need to get 0 B/743 kB of archives.
After this operation, 1,024 B of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 59235 files and directories currently installed.)
Preparing to replace isc-dhcp-client 4.2.2.dfsg.1-5+deb70u2 (using .../isc-dhcp-client_4.2.2.dfsg.1-5+deb70u3_armhf.deb) ...
Unpacking replacement isc-dhcp-client ...
dpkg-deb (subprocess): decompressing archive member: internal gzip read error: '<fd:4>: incorrect data check'
dpkg-deb: error: subprocess <decompress> returned error exit status 2
dpkg: error processing /var/cache/apt/archives/isc-dhcp-client_4.2.2.dfsg.1-5+deb70u3_armhf.deb (--unpack):
corrupted filesystem tarfile - corrupted package archive
Processing triggers for man-db ...
root@raspberrypi:~#
Any Ideas?
