techskies11
Re: Rasbian repository for audio related software packages
Sat Apr 02, 2016 9:00 am
would there be a way to have more support for music programs and distros on ARM cpus,
im making a custom computer for linux using arm hardware, and i was looking at KXstudio, and all the cool programs like ardour, and jack, and carla and cadence etc. is this possible, and how much would something like this cost, ill pay someone who can do this for me if possible, its either that or i use the intel atom cpu which i know has more support and less headache, but im looking into the arm hardware and im looking for some help.
i have a android tv box mx 8 i think, which has a arm cpu maybe theres a way i can test the programs on their before i start building and customizing the design for my linux music machine im working on.
tvjon
Wed May 11, 2016 8:16 am
@autostatic
Thank you for doing that, but where exactly is the file?
Your repo puts:
deb http://rpi.autostatic.com/raspbian wheezy main
into
/etc/apt/sources.list.d/autostatic-audio-raspbian.list
I changed wheezy to jessie, but an apt-get install still installs linuxsampler 1.0
I tried building ls2 on RPi3 but eventually got to:
Making all in common
make[3]: Entering directory '/tmp/linuxsampler-2.0.0/src/common'
depbase=`echo RTMath.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
/bin/bash ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -Wreturn-type -ffast-math -g -O2 -pthread -MT RTMath.lo -MD -MP -MF $depbase.Tpo -c -o RTMath.lo RTMath.cpp &&\
mv -f $depbase.Tpo $depbase.Plo
libtool: compile: g++ -DHAVE_CONFIG_H -I. -I../.. -Wreturn-type -ffast-math -g -O2 -pthread -MT RTMath.lo -MD -MP -MF .deps/RTMath.Tpo -c RTMath.cpp -fPIC -DPIC -o .libs/RTMath.o
RTMath.cpp:75:8: error: #error "Sorry, LinuxSampler lacks time stamp code for your system."
# error "Sorry, LinuxSampler lacks time stamp code for your system."
RTMath.cpp:76:8: error: #error "Please report this error and the CPU you are using to the LinuxSampler developers mailing list!"
# error "Please report this error and the CPU you are using to the LinuxSampler developers mailing list!"
RTMath.cpp: In static member function 'static RTMathBase::time_stamp_t RTMathBase::CreateTimeStamp()':
RTMath.cpp:78:1: warning: no return statement in function returning non-void [-Wreturn-type]
Makefile:523: recipe for target 'RTMath.lo' failed
make[3]: *** [RTMath.lo] Error 1
make[3]: Leaving directory '/tmp/linuxsampler-2.0.0/src/common'
Makefile:674: recipe for target 'all-recursive' failed
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory '/tmp/linuxsampler-2.0.0/src'
Makefile:496: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/tmp/linuxsampler-2.0.0'
Makefile:400: recipe for target 'all' failed
make: *** [all] Error 2
pi@j1 /tmp/linuxsampler-2.0.0 $
There are lots of these too:
#warning libs/pbd has no implementation of strictly atomic operations for your hardware.
Reading your blog, I see you found relevant patches. Are they anywhere on your site please?
Edit:
I've since found a patch source so can now build linuxsampler 2:
https://codeload.github.com/coolder/rpi ... zip/master
LePioo
Tue Nov 21, 2017 7:07 pm
Hi
I got trouble installing from this repository on my rpi3..
When I add the repo following the method here : http://rpi.autostatic.com/ I end up with many errors:
pi@raspberrypi:~ $ sudo apt-get update
Atteint:1 http://archive.raspberrypi.org/debian stretch InRelease
Atteint:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Réception de:3 http://rpi.autostatic.com/raspbian jessie InRelease [1 457 B]
Ign:3 http://rpi.autostatic.com/raspbian jessie InRelease
1 457 o réceptionnés en 1s (1 245 o/s)
Lecture des listes de paquets... Fait
W: Erreur de GPG : http://rpi.autostatic.com/raspbian jessie InRelease : Les signatures suivantes ne sont pas valables : 71997F416FAB85BCA07092531CED24226B3D4B4C
W: The repository 'http://rpi.autostatic.com/raspbian jessie InRelease' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I don't know what to do from here, how to perform installation of jackd2 for example, can someone drive me please?
ZipSnipe
Wed Dec 20, 2017 8:29 am
OK I got the same thing but the repository does get installed you need to follow the steps here https://wiki.linuxaudio.org/wiki/raspbe ... repository
4tm
Sun Feb 18, 2018 12:10 pm
@AutoStatic: anyting new for "Stretch"?
Return to “Raspbian”
Who is online
Users browsing this forum: No registered users and 31 guests
