AutoStatic
Rasbian repository for audio related software packages
Wed Mar 13, 2013 1:31 pm
I've set up a repository with some packages for Raspbian of audio software that is either not available or not up to date:
http://wiki.linuxaudio.org/wiki/raspber ... repository
For the moment the repository only contains guitarix 0.25.2, Jack1 0.121.3 and Jack2 1.9.8 (the latter two both patched for use on the RPi). I'm in the process of adding more packages. This is more or less a personal repo so I'll only add stuff I really need myself. You can do package requests of course but I can't guarantee they'll be honored.
Regards,
Jeremy
RPi and real-time, low-latency audio: http://wiki.linuxaudio.org/wiki/raspberrypi
RPi audio repository: http://rpi.autostatic.com/
RPi and audio blog: https://autostatic.com/tag/raspberrypi/
elatllat
Re: Rasbian repository for audio related software packages
Mon Mar 18, 2013 3:48 am
Thanks, added it to the 3rd party list:
http://elinux.org/RPi_applications#Addi ... pt_Sources
2160p + USB3 + Wayland: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
AutoStatic
Mon May 20, 2013 8:32 pm
Big bump :)
I've added quite some packages. These are the packages currently available:
  • a2jmidid
  • amsynth
  • dbus-triggerd
  • drumkv1
  • guitarix
  • Jack1 (jack-audio-connection-kit)
  • Jack2 (jackd2)
  • jalv
  • lilv
  • lv2
  • madfuload
  • non-daw-and-mixer
  • non-sequencer
  • phasex
  • samplv1
  • serd
  • sorcer
  • sord
  • sratom
  • suil
  • synthv1
  • yoshimi
More to come and keep those requests coming! Well, I've got none so far actually ;) I'm a bit baffled by the very limited interest in making music with your RPi and readily available tools and applications.
AutoStatic
Mon May 20, 2013 8:33 pm
elatllat wrote:Thanks, added it to the 3rd party list:
Thanks!
Peterleroux
Fri Jul 19, 2013 1:07 pm
Thanks! I'm going to be breadboarding a guitar effects pedal based on a model a, this will be a very solid start for me
AutoStatic
Wed Jul 24, 2013 7:24 am
Peterleroux wrote:Thanks! I'm going to be breadboarding a guitar effects pedal based on a model a, this will be a very solid start for me
Awesome! The RPi is not perfect for guitar effects but it does the job once properly set up. You might want to check out http://ampbrownie.com too.
AutoStatic
Wed Jul 24, 2013 7:29 am
Together with falkTX I got his plugin host to work on the RPi:
Carla can now be found in my RPI audio repository.
AutoStatic
Thu Jul 25, 2013 2:02 pm
LinuxSampler is now also in the repository. And I've updated the Carla package which now has full support for all features.
tobybear
Mon Sep 02, 2013 9:41 pm
Thank you for your effoerts with the audio repository so far - great work!
Well, as these little gems seem to run quite well, what about adding current versions of:
http://synthv1.sourceforge.net/synthv1-index.html
http://samplv1.sourceforge.net/samplv1-index.html
http://drumkv1.sourceforge.net/drumkv1-index.html
The versions in the repository are already a bit dated, or rather Rui Nuno Capela is adding new features constantly :-)
I am currently compiling their latest sources on the pi for testing...
AutoStatic
Thu Sep 05, 2013 9:45 am
Will do, thanks for the heads up!
AutoStatic
Thu Sep 05, 2013 11:19 am
The Vee One Suite has been updated to 0.3.4.
Metatronin
Mon Sep 09, 2013 6:05 am
Jackrack as a request?
AutoStatic
Mon Sep 09, 2013 8:22 am
JACK Rack is already in the Raspbian repositories: http://archive.raspbian.org/raspbian/po ... /jack-rack
AutoStatic
Wed Sep 11, 2013 1:59 pm
Updated seq24 to the latest bazaar revision that is available.
canula
Mon Sep 30, 2013 7:03 pm
Hi, thanks for providing this repository. I am really interested to try using linux sampler with rpi however when I try and start Qsampler it crashes stating 'Segmentation Error'. Looking at the Linuxsampler forums this appeared to be a problem that I think was eventually solved. Would you be able to help? I'm very new to all things rpi/linux related so I am unfortunately unable to provide a more technical explanation of the problem. Thanks.
webb
Sun Dec 28, 2014 8:43 pm
I am unable to connect to the rpi autostatic repository:
wget -O /etc/apt/sources.list.d/autostatic-audio-raspbian.list http://rpi.autostatic.com/autostatic-audio-raspbian.list
--2014-12-28 20:42:14--  http://rpi.autostatic.com/autostatic-audio-raspbian.list
Resolving rpi.autostatic.com (rpi.autostatic.com)... 93.94.224.100
Connecting to rpi.autostatic.com (rpi.autostatic.com)|93.94.224.100|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2014-12-28 20:42:24 ERROR 404: Not Found.
AutoStatic
Thu Jun 04, 2015 6:40 pm
For those interested I've uploaded the following packages to my Raspbian repository (http://rpi.autostatic.com/):
  • linux-image-cirrus: meta package that installs a kernel with Wolfson/Cirrus Logic audio interface support
  • cirrus-config-overlay: package that installs the device tree overlay file for the Wolfson/Cirrus Logic audio interface
  • cirrus-config-modprobe: package that installs the modprobe config file for the Wolfson/Cirrus Logic audio interface
  • cirrus-config-scripts: package that installs the playback, record and reset scripts for use with the Wolfson/Cirrus Logic audio interface
  • cirrus-config: meta package that installs all the above packages
If anyone is interested in testing these packages, go ahead, feedback is greatly appreciated. On a clean Raspbian install adding my repo, installing the cirrus-config package and rebooting your RPi should enable the Wolfson/Cirrus Logic audio interface. No need to edit any config files.
Jeremy
AutoStatic
Sat Jun 06, 2015 8:27 pm
Just a quick addendum, the cirrus-config and linux-image packages have been tested on both the RPi1 and the RPi2.
Plastik
Mon Dec 28, 2015 3:57 am
Love what you did here! I really want to try out "non-sequencer" but I keep getting an error when I go to download it from your repository. Do you no longer keep that online?
Plastik
Mon Dec 28, 2015 7:56 pm
My mistake it was a network issue on my end. Got non-sequencer installed and will be trying it out soon. Thanks again!
madtom1999
Fri Jan 22, 2016 5:02 pm
I cannot get a2jmidid to work at all. It runs in the console but connecting to it in qjackctrl crashes jack.
madtom1999
Sun Jan 24, 2016 11:03 am
Trying to build a2jmidid on the Pi
waf configure finishes with the following
Install prefix : /usr/local/
D-Bus support : yes
D-Bus service install directory : /usr/local/share/dbus-1/services
WARNING: D-Bus session services directory as reported by pkg-config is
WARNING: /usr/share/dbus-1/services
WARNING: but service file will be installed in
WARNING: /usr/local/share/dbus-1/services
WARNING: You may need to adjust your D-Bus configuration after installing
WARNING: You can override dbus service install directory
WARNING: with --enable-pkg-config-dbus-service-dir option to this script
Configuration finished successfully; project is now ready to build.
does this mean it will build and run OK or do I need to override the dbus service install to get it to run on the pi?
madtom1999
Wed Feb 10, 2016 1:23 pm
Seems a2jmidid on the Pi only works with Jack2
AutoStatic
Tue Mar 15, 2016 4:52 pm
a2jmidid should work but nowadays you might want to look at the built-in JACK-ALSA MIDI bridges for Jack1 and Jack2. When using -Xseq they should get loaded with recent versions of Jack1 and Jack2. Which Raspbian are you using? The Wheezy or the Jessie one?
AutoStatic
Tue Mar 15, 2016 4:57 pm
Long overdue but I've uploaded LinuxSampler 2.0.0 to my Raspbian Jessie repository. Raspbian Wheezy users are out of luck unless someone knows a way to compile LinuxSampler 2.0.0 with a GCC version <= 4.8.
Return to “Raspbian”
Who is online
Users browsing this forum: No registered users and 8 guests
