Ectra wrote:Hello,
I'm trying to get a Huawei E173s 3G dongle working under Raspbian but all it causes is pain
. Vendor 12d1 product 1c0b.
So far I've narrowed the issue down to usb_modeswitch and possibly broken udev rules. My initial problem was that if I unplugged it and then plugged it back in it wouldn't switch into modem and would still say modem off in lsusb. I can now change it at will with "usb_modeswitch -I -c /usr/share/usb_modeswitch/12d1\:1c0b -v 12d1 -p 1c0b" but won't automatically via udev. Other dongles are fine.
Has anyone had similar issues and been able to resolve them?
I can even get it to switch to modem mode
Here is what I did so far:
1.
sudo apt-get install usb_modeswitch
2.
Bus 001 Device 015: ID 12d1:1c0b Huawei Technologies Co., Ltd. E173s 3G broadband stick (modem off)
3.
sudo nano /etc/usb_modeswitch.d/12d1:1c0b
# Huawei E173s-2 Orange UK
DefaultVendor= 0x12d1
DefaultProduct= 0x1c0b
TargetVendor= 0x12d1
TargetProduct= 0x1c05
CheckSuccess=20
MessageEndpoint= 0x0f
MessageContent= "55534243123456780000000000000011062000000100000000000000000000"
4.
sudo nano /lib/udev/rules.d/40-usb_modeswitch.rules
ATTRS{idVendor}=="12d1", ATTRS{idProduct}=="1c0b", RUN+="usb_modeswitch '%b/%k'"
5.
sudo modprobe usbserial vendor=0x12d1 product=0x1c05
6.
sudo usb_modeswitch -I -c /etc/usb_modeswitch.d/12d1\:1c0b -v 12d1 -p 1c0b
[email protected] ~ $ sudo usb_modeswitch -I -c /etc/usb_modeswitch.d/12d1\:1c0b -v 12d1 -p 1c0b
Looking for target devices ...
No devices in target mode or class found
Looking for default devices ...
found matching product ID
adding device
Found device in default mode, class or configuration (1)
Accessing device 015 on bus 001 ...
Getting the current device configuration ...
OK, got current device configuration (1)
Using first interface: 0x00
Using endpoints 0x0f (out) and 0x8f (in)
USB description data (for identification)
Manufacturer: HUAWEI
Product: HUAWEI Mobile
Serial No.: not provided
Looking for active driver ...
No driver found. Either detached before or never attached
Setting up communication with interface 0
Using endpoint 0x0f for message sending ...
Trying to send message 1 to endpoint 0x0f ...
OK, message successfully sent
Resetting response endpoint 0x8f
Could not reset endpoint (probably harmless): -71
Resetting message endpoint 0x0f
Checking for mode switch (max. 20 times, once per second) ...
Searching for target devices ...
No new devices in target mode or class found
Mode switch has failed. Bye.
and the
http://debianarmpi.blogspot.co.uk does not work.
