Problem installing Raspbian 2013-02-09-wheezy-raspbian
Posted: Sat Feb 16, 2013 12:52 pm
Hey!
I have tries for some time now to install the new Raspbian to a 32gb Kingston SD class 10 card.
It succsessfully installed the image onto the SD card. But when I try to run it for the first time I only get this on my screen:
example:
And after some time just dooing this and changing the numbers in [] and cmdx. I get this:
What is the problem? And how do I fix it?
Hope for a fast respons!
PS! It works on the same 4GB card instead of a 32gb card... And just checked the Verfi wiki site for SD card compatible, and the card shall work just fine.
I have also tested the SHA-1 number on the zip file. and it is the same as the one I downloaded from the RPi site.
example:
[717.702208] mmc0: Timeout waiting for hardware interrupt - cmd1.Code: Select all
INIT: ID "4" respawning to fast: Disabled for 5 minutes
INIT: Cannot execute "/sbin/getty"
INIT: cannot execute /sbin/getty"ed for 5 minutesHope for a fast respons!
