tik0 wrote:Hi there,
first of all, great job what you have done there with the Pi! So now my issue:
Systemstate:
Installad "2012-12-16-wheezy-raspbian" and the newest firmware(<- Here is the problem) from github. After that I ran apt-get update and apt-get upgrade, so everything is realy up-to-date.
Running: unameCode: Select all
Linux raspberrypi 3.6.11+
Problem:
With copying the new firmware from Github onto my Pi, the new Kernel 3.6.11+ is installed. But this Kernel causing problems when it tries to load modules. "modprob" is always searching in the folder /lib/modules/3.6.11+ for loading modules, but it's obviously not on the filesystem.
Folder /lib/modules containing:Outputmessages:Code: Select all
3.2.27+ 3.2.27-cutdown+
E.g. while booting, "modprob" tries to load "snd-bcm2835" which results in the following message:E.g. Running "depmod -a"Code: Select all
libkmod: ERROR ../libkmod/libkmod.c:554 kmod_search_moddep: could not open moddep file '/lib/modules/3.6.11+/modules.dep.bin'Workaround until now:Code: Select all
ERROR: could not open directory /lib/modules/3.6.11+: No such file or directory FATAL: could not search modules:No suchfile or directory
Just copying back the old firmware with the original Kernel 3.2.27+ works fine, because then "modprob" is loading the modules from the existing folders. But I would like to have the newest firmware.
Does anyone know how to make the newst firmware work with Raspbian?
Would be nice if someone can help me.
Greetz Tik0
