Xorg utilization
Posted: Thu Apr 15, 2021 6:40 pm
by w4mmp
I am working on a hardware product that incorporates the RPi 4B (2GB) and a DSI display from DF Robot (https://www.dfrobot.com/product-1784.html). The application driving the display drives it quite heavily (an active spectrum graph and waterfall display are continually running).
When examining Xorg utilization I have the following observations.
With the line: #dtoverlay=vc4-fkms-v3d (commented out) of /boot/config.txt, Xorg utilization is about 25%. However as expected, the HDMI ports will not function. It is desired to have both the DSI display and a HDMI display available to the user. So to have both, dtoverlay=vc4-fkms-v3d is un-commented in /boot/config.txt. This does allow both the displays to be available to the user. However, this is where Xorg goes a bit nuts. Xorg utilization goes to over 80% with the same identical application running, over three times the utilization verses when the overlay is not active. This high utilization apparently causes some sluggishness of the spectrum display. Please note that even when both displays are configured to be available, the application is still only using the DSI display. There is nothing on the HDMI display other than an idle desk top.
So the question I have is why does allowing both displays to be available, cause such high Xorg utilization particularly when only the DSI display is being used by the application? And then the follow on question, what if anything can be done about it.
Thanks for your attention,
Ron
Re: Xorg utilization
Posted: Fri Apr 16, 2021 3:58 pm
by w4mmp
Help, please.
Should I post this in a different category such bug reports?
Posted: Tue Apr 20, 2021 11:05 am
by 6by9
Sorry, this isn't a sub-forum I routinely read. I don't know about other Pi employees.
For display related questions you're generally best to ask under "Interfacing (DSI, CSI, I2C, etc.)" if you want me to see it.
That display is a third party display that clones the behaviour of the Pi 7" touchscreen. Seeing as DSI displays do vary dramatically, and the Pi screen has an Atmel MCU for power management, I'm slightly amazed it actually all works.
That's unlikely to be the cause of any issue here.
vc4-fkms-v3d (and vc4-kms-v3d) both switch all window composition from being framebuffer based to using OpenGL. For most things this is more efficient than having to bash things through on the CPU, but it depends on exactly the operations you're using.
Is xorg using large amounts of CPU without this app running? It shouldn't.
What is this application doing in terms of on-screen drawing, and using what API calls? It may be that some operation was either tied to the display frame rate under the framebuffer driver, or offloaded to some other thread/worker for a large proportion of the time, whereas that throttling doesn't apply under DRM/KMS.
Posted: Wed Apr 21, 2021 2:51 pm
by w4mmp
Hello and thank you for responding to my request for help.
Your response helped break a log jam in my thought processes. There three processes that display information on the screen. I found only one of the three is causing the problem. Now I need to determine why it drives Xorg so busy particularly in light of the fact it does not access the HDMI display.
To answer your question, no Xorg is not busy when the application(s) are not running. Only when the above mentioned application is running does Xorg become successively busy.
Oh, I want to mention that if Raspberry offered a 5" DSI touch display, I would have highly considered using it in our product. The Raspberry 7" display is simply too large for our product.
If you a curious about the applications and want to know more, read on.
Below is a screen shot of the full application running on the DSI display.
There are three independent applications driving the display. 1) MSCC (Multus SDR Control Console), 2) spectrum display, 3) waterfall display.
All three run under the service of Mono. Yea, I know, a bad choice but I'm stuck with it for now and after working around the bugs in Mono, the applications work. One day MicroSoft may offer a .Net 5.x desktop for Linux but for now the .Net 5.x desktop runs only in Windows.
As mentioned at the top of this reply, it is the spectrum display that is causing the heart burn. This application use a graphing library called ZedGraph. To find out how ZedGraph is accessing the display, I will need to dig down deep into the source code. I might be better off simply re-writing the spectrum display application using direct calls to GDI+ as the waterfall application does. The waterfall application runs well and does not cause the issue. Or scrap Mono for the spectrum application use QT (but I loathe C++).
Regards,
Ron
Posted: Wed Apr 21, 2021 2:56 pm
by w4mmp
I should have mentioned the applications are developed with MS Visual Studio and Winforms. Yep, old technology but developing this application started some years ago and was intended for Windows. We are moving to the RPi 4B for the host computer and at the time Mono seemed a good path to follow. But that is one of the dangers of using open source applications. Support dies.
Posted: Wed Apr 21, 2021 3:05 pm
by fruitoftheloom
Osoyoo offer a 5" DSi Screen
https://osoyoo.com/2019/09/20/instructi ... ch-screen/
Visual Studio Code is now offered by Microsoft for Raspberry Pi SBC / CM
Posted: Wed Apr 21, 2021 3:27 pm
by w4mmp
Thanks for the info on the display. I will take a look.
On the Visual Studio desktop issue, nope the desktop is not available for running Winforms on Linux:
From the https://dotnet.microsoft.com/download/dotnet/5.0 page:
Posted: Wed Apr 21, 2021 3:37 pm
by 6by9
Total shot in the dark, but if it is drawing on textures and flushing lots, then under simple X it would just write a few pixels to the framebuffer. With GL composition it'll trigger a redraw of the texture.
Posted: Wed Apr 21, 2021 4:09 pm
by w4mmp
Thanks for you insights. I will be first to admit that I'm not really up on the low level stuff. I assume that a redraw of the texture is not a good thing.
Posted: Wed May 19, 2021 1:51 am
by w4mmp
Just to follow up on this. The suspect application was rewritten using an alternate graphing package and the issue no longer occurs. With all three applications that access X.org running, X.org utilization is in the 20% range. This is very acceptable. The entire application (GUI applications and back end servers) is consuming roughly 30% of the RPi 4B. Lots of capacity for running other Amateur radio applications.
Thanks,
Ron
