Wifi without x, next try
Posted: Sun Jan 13, 2013 11:00 am
by truehl
Hi Folks,
I tried to ask this question one week ago, but there was only trash. So I try again now and ask you for serious answers.
I tried to configure Wifi without x. If I do so it won't work, unless I start an x session. There a can see the right settings and I only need to press connect. Wifi connects and works. Even on a reboot it still works. So I took all setting in /etc/network/interfaces and in etc/wpa_supplicant/wpa_supplicant.conf in put them in my config. With this settings, wlan0 did not come up un start, I have to start it from the wpa_gui!
What's wrong here, what am I missing?
Thanks for help,
Thomas
Re: Wifi without x, next try
Posted: Sun Jan 13, 2013 11:11 am
by jamiesk
When to boot up to the CLI and the wireless is down, then can you get to it and type in "sudo ifconfig"
My ethernet only shows
[email protected]:/home/pi# ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:eb:19:d7:61
          inet addr:192.168.0.5  Bcast:192.168.0.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:85655 errors:0 dropped:256 overruns:0 frame:0
          TX packets:2374 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:5515386 (5.2 MiB)  TX bytes:219875 (214.7 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
What is shown on yours ?
Also does the wifi device show up in "lsusb" ?
Posted: Sun Jan 13, 2013 11:56 am
by Cloudcentric
......maybe try WICD http://wicd.sourceforge.net it is in the repository
Posted: Sun Jan 13, 2013 12:57 pm
by Unhban
I too had loads of problems getting wifi working. In the end I just went through the following (if the page asks for a password just click on Cancel):
http://blog.xrmx.co.uk/2012/07/setting- ... on-wheezy/
Posted: Sun Jan 13, 2013 1:36 pm
by truehl
My problem is, that I don't like to use additional SW to get it working.
After setting Wifi up from my scripts, /etc/network/interfases look like this;
nano /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them.
# The loopback network interface
auto lo
iface lo inet loopback
# The WLAN network interface
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
# The LAN network interface
auto eth0
iface eth0 inet dhcp
That's the same for Wifi if I use wpa_gui as far as I know.
An the /etc/wpa_supplicant/wpa_supplicant.conf looks like this:
update_config=1
network={
        ssid="BlabberBlub06"
        psk="xxxxx"
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=TKIP
        group=TKIP WEP104 WEP40
        auth_alg=OPEN
That's also the same for Wifi if I use wpa_gui as far as I know.
If I don't use the wpa_gui ifconfig shown this after a boot:
eth0 Link encap:Ethernet  HWaddr b8:27:eb:7d:0f:d0
          inet addr:192.168.2.75  Bcast:192.168.2.255  Mask:255.255.255.0
          RX packets:179 errors:0 dropped:0 overruns:0 frame:0
          TX packets:148 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:18599 (18.1 KiB)  TX bytes:23355 (22.8 KiB)
          RX packets:2 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:100 (100.0 B)  TX bytes:100 (100.0 B)
wlan0  Link encap:Ethernet  HWaddr 80:1f:02:76:50:f6
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
No IP address assigned for wlan0.
After connection manually with wpa_gui Ifconfig gives this:
          RX packets:1183 errors:0 dropped:0 overruns:0 frame:0
          TX packets:269 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:87751 (85.6 KiB)  TX bytes:45668 (44.5 KiB)
          RX packets:4 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:200 (200.0 B)  TX bytes:200 (200.0 B)
          inet addr:192.168.2.13  Bcast:192.168.2.255  Mask:255.255.255.0
          RX packets:342 errors:0 dropped:367 overruns:0 frame:0
          TX packets:28 errors:0 dropped:1 overruns:0 carrier:0
          RX bytes:86994 (84.9 KiB)  TX bytes:6053 (5.9 KiB)
As you see it's connected and I get an IP. I only don't like to swich to the wpa_gui. how can I activate wlan0 without wpa_gui?
Posted: Sun Jan 13, 2013 10:38 pm
by Cloudcentric
I actually believe it may be feasible to run wpa_supplicant from command line, bottom of this page:
http://hostap.epitest.fi/gitweb/gitweb. ... ant/README
