Page 1 of 2
How to disable the "You have removed it without ejecting it" message?
Posted: Mon Jun 29, 2020 4:51 pm
by GlowInTheDark
I am running the usual desktop, with Buster OS.
I insert a USB drive; it automounts.
From the Terminal (command line), I work with the contents of the drive, then use "umount" to unmount it.
Then I unplug the drive from the Pi and a message pops up onscreen telling me that I have removed it without ejecting it. Obviously, it doesn't know (or is pretending not to know) that it was "umount"d before it was removed. This is obviously not a big deal, b/c the message is just annoying, but it's annoying that the message stays there for quite a while (at least 30 seconds) and can't be closed or dismissed.
Is there any way to prevent this message from appearing (*) ?
(*) No smartaleck answers like: Don't remove the drive without ejecting it. The point is that umount'ing it from the command line is certainly sufficient. There is just a disconnect (and, IMHO, a bug) in the GUI stuff that it doesn't figure out that the thing has been umount'd.
P.S. Another way to fix this is to set whatever setting it is that just turns off auto-mounting completely. I knew what setting it was once, but have since forgotten what it is/how to do this. But the point is I like that it auto-mounts; I just want to do my own umount'ing.
Re: How to disable the "You have removed it without ejecting it" message?
Posted: Mon Jun 29, 2020 10:52 pm
by Imperf3kt
Are you giving it sufficient time to flush its cache before removing it from the Pi?
Posted: Mon Jun 29, 2020 10:57 pm
by kerry_s
have you gone into the file manager & unchecked auto mount?
Posted: Mon Jun 29, 2020 11:02 pm
by GlowInTheDark
Please re-read the original text of the post. Thank you.
Posted: Mon Jun 29, 2020 11:20 pm
by kerry_s
never mind, i'm multi-tasking. my attention is on the other monitor.
Posted: Tue Jun 30, 2020 12:22 am
by GlowInTheDark
Anyway, as I said, it is (merely) annoying, but I do think it is, ultimately, a bug.
No doubt, they expect that you'll either do things entirely by GUI or entirely by command line, and get upset at my "hybrid" approach.
There's probably just some daemon that you need to kill to make it stop doing this. Some daemon that monitors for USB removals...
Posted: Tue Jun 30, 2020 12:51 am
by kerry_s
yeah, it's in " pcmanfm --desktop " i remember using it on 1 of my budgie installs to get auto mount as well as desktop icons.
Posted: Tue Jun 30, 2020 1:27 am
by GlowInTheDark
I'm sorry. I don't understand what you are saying here.
What is the antecedent of "it's" ?
Posted: Tue Jun 30, 2020 3:31 am
by pidd
" it's " = " it is "
Posted: Tue Jun 30, 2020 6:14 am
by GlowInTheDark
Grammar. a word, phrase, or clause, usually a substantive, that is replaced by a pronoun or other substitute later, or occasionally earlier, in the same or in another, usually subsequent, sentence. In Jane lost a glove and she can't find it, Jane is the antecedent of she and glove is the antecedent of it.
Posted: Tue Jun 30, 2020 6:45 am
by HawaiianPi
Auto-mounting is handled by the file manager (pcmanfm). You can change it in the file manager's preferences settings.
Posted: Tue Jun 30, 2020 7:20 am
by GlowInTheDark
This has (almost) nothing to do with auto-mounting.
Posted: Tue Jun 30, 2020 2:49 pm
by bjtheone
Will try and check tonight as I am running with Mate and Caja rather than pcmanfm. Definitely have automounting working. Will see what happens if I manually umount a stick then pull it. Curious if I have the same bug.
Posted: Wed Jul 01, 2020 12:53 am
by bjtheone
Running Raspbian Lite + Mate, file manager is Caja, USB data sticks automount. If I use the "eject safely ..." menu pulldown in Caja or issue a "umount" command from a terminal, when I then remove the data stick there is no annoying and incorrect message.
That points to it potentially being an interaction with pcmanfm.
Posted: Wed Jul 01, 2020 1:00 am
by GlowInTheDark
Just to be clear: If you use the "eject safely menu pulldown", then OF COURSE you don't get the annoying message, because that what you're "supposed to" (in the behavioral normative sense) to do.
The consistent theme in this thread is that it gets out of whack (in standard Raspbian Buster OS) if you insert the stick, have it get automounted, then do a manual "umount", followed by a physical removal.
That said, it does seem like it is something in the "pcmanfm" program that is doing it.
P.S. I've since discovered that the message can be "clicked" away, by clicking on it. Annoyingly, it stays up (forever) unless/until you do click it.
Posted: Wed Jul 01, 2020 9:07 pm
by bjtheone
I am aware that using the GUI option to unmount it should not trigger the issue since that is the full monty GUI "is the expected and correct behaviour". I was just trying to provide all the info. The relevant bit is that Mate and Caja play nicely with umount and don't throw up bogus error messages.
What I am not entirely sure of is what is doing the automount, in a Raspbian Lite + Mate installs, since it plays nicely with cli umount commands.
While I have mucked about with various bits I have not installed anything that should change the automounter.
Posted: Wed Jul 01, 2020 9:50 pm
by kerry_s
it's not that it's playing nicely, it just doesn't have the notification.
Posted: Wed Jul 01, 2020 10:06 pm
by GlowInTheDark
Assuming I am understanding you correctly, it doesn't *NEED* notification. All it needs is just before displaying the (bogus) error message, it should check to see if the thing is, in fact, and at this very moment, mounted. If not, then don't display the (bogus) error message.
Posted: Wed Jul 01, 2020 10:29 pm
by kerry_s
your assuming it is a " bogus " error, what if it's not? what if the daemon has it in memory & did not flush? leading to a memory leak, zombie process, corruption....
anyways, your device, your risk, do as you please, a computer is a dumb device that runs software the way it was programmed to. :D
Posted: Wed Jul 01, 2020 10:34 pm
by GlowInTheDark
You're totally missing the point.
Go back and re-read. Thank you.
Posted: Wed Jul 01, 2020 10:47 pm
by kerry_s
what point? umount is a kernel thing, automount is a software thing, it's a system subsystem issue, like pulling the chair out from someone whose sitting on it.
anyways i'm done, have at it.
Posted: Thu Jul 02, 2020 12:32 am
by GlowInTheDark
Oh, well. It was a pleasure doing business with you.
NOT!
Posted: Thu Jul 02, 2020 1:14 am
by Imperf3kt
Which brings us back to
How long do you give it after unmounting before you remove it?
Posted: Thu Jul 02, 2020 2:02 am
by DarkElvenAngel
I've seen this too it's very easy to replicate. Put a USB stick in it mounts then do a sudo umount and a sync and you still get the message. After sync returns you know the drive is safe to pull. But the GUI will still spit up the error message.
Your not alone GlowInTheDark I have no idea how to stop the notification other than just use the GUI or ignore it.
Posted: Thu Jul 02, 2020 3:33 am
by jojopi
I may be seeing slightly different behaviour. The popup message stays until clicked (and interferes with focus somewhat).
It appears even if I safely eject in the GUI. Even if I unplug while the "It is now safe to remove the device" message is visible. Even if automount is disabled and the device has never been mounted. Even if the device has no partition table or reports a size of zero, or no medium present.
It is a particularly nice touch that in most of these cases it is smart enough not to show the eject icon ("menu"?), but still remembers to complain when the device is removed. The eject icon also disappears very smartly following a CLI umount.
Source code here: https://github.com/raspberrypi-ui/lxplu ... /ejecter.c
So, what you want to do is edit /etc/xdg/lxpanel/LXDE-pi/panels/panel and comment out this bit:
Plugin {
  type=ejecter
  Config {
    AutoHide=1
