saxonpaul92
No Raspberry Pi imager for Raspberry Pi
Thu Jun 25, 2020 10:40 pm
I was wondering why there is a Raspberry Pi Imager for Windows, MAC, and Ubuntu but not for Raspberry Pi.
I have been contemplating switching my desktop to Raspberry Pi 4 but there really is very little support for ARM processors.
Any thoughts?
trejan
Re: No Raspberry Pi imager for Raspberry Pi
Thu Jun 25, 2020 10:43 pm
It already exists. "sudo apt install rpi-imager"
B.Goode
Thu Jun 25, 2020 10:57 pm
Any thoughts?
This recent very similar thread seems relevant, and points out that you are incorrect - viewtopic.php?f=66&t=277981
Fri Jun 26, 2020 6:16 am
Any thoughts?
There's loads of support for ARM. There are over 25000 apps in the Raspberry Pi repositories...
LTolledo
Fri Jun 26, 2020 6:34 am
Any thoughts?
methinks it depends on the the OP what he think as important apps for his desktop...
if ARM equivalent is not up to his standards or does not exist....
he will always think "...but there really is very little support for ARM processors..."
the Raspberry Pi Imager is available for RPiOS, but not for Raspbian OS versions prior to Buster.
I've ported most of my favorite desktop apps from a w$ system to RPiOS on RPi4B-4G..... and happy with it.
the w$ system is either gathering dust (lots of it already) or back in its box...
Some people be like:
clicky
Fri Jun 26, 2020 3:32 pm
BTW I had similar question only a few days ago (but I'm fine to use dd from command line). Anyway - is it worth adding line somewhere on https://www.raspberrypi.org/downloads/ just to avoid further confusion?
Re support for ARM: it all boils down to what is really needed. I've sorted out all my candy for Linux and arm (to be precise 64bit one) with some effort - and now happily using RPi4 (8GB with 1TB SSD) for my current development and as a general purpose computer (mail/web stuff).
Fri Jun 26, 2020 5:11 pm
I don't access to the downloads page otherwise I would have already done that. I'll pass on to the content team.
bjtheone
Thu Jul 02, 2020 11:51 am
Also should relabel the "Raspberry Pi Imager for Ubuntu" to make it clear that it is for x86 Ubuntu. I know the file name of "imager_amd64.deb" should be enough of a clue, but I suspect it will be a source of confusion, especially once you add the one for ARM.
richard_bonomo
Mon Aug 03, 2020 4:01 pm
I having an issue using sudo apt -install rpi-imager on Raspberry Pi OS 64 bit.
I get this message:
pi@raspberrypi:~ $ sudo apt install rpi-imager
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
rpi-imager : Depends: libqt5qml5 (>= 5.1.0) but it is not going to be installed
Depends: libqt5quick5 (>= 5.0.2) but it is not going to be installed
Depends: qml-module-qtquick2 but it is not going to be installed
Depends: qml-module-qtquick-controls2 but it is not going to be installed
Depends: qml-module-qt-labs-settings but it is not going to be installed
Depends: qml-module-qtquick-layouts but it is not going to be installed
Depends: qml-module-qtquick-templates2 but it is not going to be installed
Depends: qml-module-qtquick-window2 but it is not going to be installed
Depends: qml-module-qtgraphicaleffects but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I can't seem to install the individual packages either. Ideas?
Return to “Raspberry Pi OS”
