biglesp
Shortening the boot time of a Raspberry Pi 4
Fri Jun 12, 2020 1:54 pm
Hello, I'm Les Pounder, better known as @biglesp on Twitter. https://twitter.com/biglesp
In a former life I was part of the Picademy team travelling the UK help educators take their first step with the Raspberry Pi.
These days I am Associate Editor at Tom's Hardware and I specialise in Raspberry Pi and Linux stories.
I'm working on a new project to shorten the boot time of a Raspberry Pi 4 to sub twenty seconds. And by this I mean from power on, to usable desktop experience.
Has anyone tried this, and do you have any pointers?
What services can be cut?
Thanks!
jahboater
Re: Shortening the boot time of a Raspberry Pi 4
Fri Jun 12, 2020 2:16 pm
The following two commands may help decide which services to disable:
systemd-analyze blame
systemd-analyze critical-chain
This helps a little:
initial_turbo=30
My Pi4 8GB running PIOS64 on a Sandisk A1 SD card, starts in:
pi@raspberrypi:~ $ systemd-analyze
Startup finished in 1.174s (kernel) + 2.467s (userspace) = 3.641s
graphical.target reached after 2.442s in userspace
pi@raspberrypi:~ $
biglesp
Mon Jun 22, 2020 9:42 am
Thanks very much I shall give this a try.
Best wishes, and sorry for the slow reply.
Mon Jun 22, 2020 11:20 am
I think you're tilting at windmills. My RPi3B with the official display got this
root@tranquility:~ # systemd-analyze critical-chain
The time after the unit is active or started is printed after the "@" character.
The time the unit takes to start is printed after the "+" character.
graphical.target @15.949s
└─multi-user.target @15.948s
  └─tvheadend.service @10.227s +5.718s
    └─remote-fs.target @10.174s
      └─remote-fs-pre.target @8.445s
        └─rpcbind.service @7.917s +490ms
          └─systemd-tmpfiles-setup.service @7.744s +163ms
            └─local-fs.target @7.698s
              └─boot.mount @7.637s +55ms
                └─systemd-fsck@dev-disk-by\x2dpartuuid-0c3a490b\x2d01.service @6
                  └─dev-disk-by\x2dpartuuid-0c3a490b\x2d01.device @6.600s
This was from a timed shutdown -r 17:30 (with a stable clock).
root@tranquility:~ # uptime -s
2020-06-18 17:30:38
so that was 38 seconds to shutdown and reboot. You're not going to strip any time out of that.
biglesp
Mon Jun 22, 2020 3:32 pm
2020-06-18 17:30:38
Thanks Dougie, I am going to persevere and see what can be done, if it results in nothing then at least I have found the answer and learnt a little bit more about systemd.
Best
Les!
cleverca22
Mon Jun 22, 2020 10:56 pm
root@raspberrypi:~# ./uptime
 42.868002
31.22 100.38
root@raspberrypi:~# systemd-analyze critical-chain
graphical.target @17.310s
└─multi-user.target @17.309s
  └─exim4.service @16.673s +633ms
    └─network-online.target @16.667s
      └─network.target @16.666s
        └─dhcpcd.service @5.059s +11.604s
          └─basic.target @4.978s
            └─sockets.target @4.975s
              └─triggerhappy.socket @4.972s
                └─sysinit.target @4.896s
                  └─systemd-timesyncd.service @4.543s +345ms
                    └─systemd-tmpfiles-setup.service @4.400s +127ms
                      └─local-fs.target @4.382s
                        └─boot.mount @4.330s +48ms
                          └─systemd-fsck@dev-disk-by\x2dpartuuid-6c586e13\x2d01.service @3.916s +398ms
                            └─dev-disk-by\x2dpartuuid-6c586e13\x2d01.device @3.703s
root@raspberrypi:~#
source for uptime.c over here
`systemd-analyze` can only measure time relative to when linux gained control of the arm core
the `uptime.c` code in the above link, shows both the linux uptime (starts counting when linux gained control of arm) and the VPU uptime (starts counting when the reset signal was released)
the difference (42-31, aka 11 seconds) is how long it took for linux to even get control of the arm core
that 11 seconds includes the maskrom loading and validating bootcode.bin from SPI
bootcode.bin bringing dram online
> There are limits to how quickly the Pi 4 can boot - the SDRAM PHY has quite a lengthy training sequence, several seconds from what I remember.
bootcode.bin loading start4.elf from the uSD card (depends on SD speed)
start4.elf doing all of its init stuff, and loading linux+initrd from uSD (depends on kernel size, and SD speed)
kolsi
Tue Jun 23, 2020 8:02 am
For our setup, the slowest operation at boot is the login and Xorg starting up. We have custom gui.service that automatically logs in the user and then calls "startx" in .bash_profile. There is more than 2.5 seconds delay between gui.service startup time and the first line in Xorg.log.
geev03
Tue Jun 23, 2020 4:20 pm
Thanks!
Startup finished in 6.152s (kernel) + 43.081s (userspace) = 49.233s
>>https://linux-hardware.org/index.php?pr ... md-analyze
ganzgustav22
Tue Jun 23, 2020 8:41 pm
disable_splash=1
boot_delay=0
In config.txt should shorten the boot time until the kernel starts by around 2 seconds (atleast it did on the Pi0/1/2/3).
cleverca22
Tue Jun 23, 2020 9:17 pm
on my pi4, boot_delay=0 on its own had zero effect
disable_splash=1 on its own also has no effect
still no difference with both combined
boot_delay=10 has the expected effect, it now takes 21 seconds instead of 11, so the option at least does something, and must be defaulting to 0
dickon
Tue Jun 30, 2020 10:47 pm
If you're booting a 32b kernel, can you try setting kernel_address=0x2000000 and see if that makes a difference? I've been made aware that the Pi's bootloader loads 32b kernels at 0x8000, which is ludicrous and not recommended, although does appear to be weirdly common.
It should shave some time off the boot. Not sure how much.
rhester72
Wed Jul 15, 2020 2:14 pm
In my experience, 5 seconds of the Pi 4 boot time is entirely caused by the bootloader firmware and cannot be avoided.
One of the bare-metal code developers and I entered into a somewhat lengthy discussion about it and ultimately engaged Raspberry engineering who more or less said that's how it is and how it will be in the future because of the radical change to how boot devices are discovered.
cleverca22
Wed Jul 15, 2020 2:33 pm
this github issue also says the dram i partially to blame
pelwell wrote: There are limits to how quickly the Pi 4 can boot - the SDRAM PHY has quite a lengthy training sequence, several seconds from what I remember.
Return to “Raspberry Pi OS”
