ApexRon
Bookshelf Download Destination
Thu May 28, 2020 11:20 pm
Currently, magazines, books, and so on, download to a Bookshelf folder within Raspberry Pi’s internal storage. I would like to have the location of the Download folder be on a USB hard drive. How do I accomplish this?
Ron
RaspbianUser1
Re: Bookshelf Download Destination
Fri May 29, 2020 2:08 am
Can’t you just copy them from the sd? simple then delete from pi after
Running Raspberry Pi OS Full, therefore my comments will be based on that
Using RPI-4B 4GB at 2.1GHz CPU and 700MHz GPU
don't format your sd because someone said so.
Or put your favourite cutlery into your nearest outlet (May result in death) ;)
DarkElvenAngel
Fri May 29, 2020 3:16 am
It looks like once you open it up it creates a Bookshelf folder in your home directory.
So you can use symlinks to point that folder to your USB stick.
ApexRon
Fri May 29, 2020 1:38 pm
Of course but why should I go through that every time I download.
Ron
spl23
Fri May 29, 2020 1:52 pm
It writes to ~/Bookshelf by default. We'll look at making this customisable in future, but a symlink will probably work just fine.
ApexRon
Fri May 29, 2020 3:05 pm
I use the following:
sudo ln -s /home/pi/Bookshelf /NetDrive
The symbolic link worked but now there are other issues:
  • While I can now see Bookshelf folder on my network drive the contents of the Bookshelf directory on the Raspberry Pi remain. What I had hoped to achieve was only partially successful. I wanted the OS to not fill the Raspberry Pi with literature.
  • I am working on a permissions issue as well, though I am using the same userid for a terminal session, a VNC session, and connections from my iPad/iPhone. Finder on my Mac does not see the folder at all even though I did a killall on Finder
    pi@raspberrypi:~ $ ls -l /NetDrive/Bookshelf
    lrwxrwxrwx 1 root root 18 May 29 10:01 /NetDrive/Bookshelf -> /home/pi/Bookshelf.
Ron
DarkElvenAngel
Fri May 29, 2020 3:20 pm
Don't create your link with sudo.
You need to
sudo rm /home/pi/Bookshelf
Try that way
ApexRon
Fri May 29, 2020 3:36 pm
You need to
Try that way
I used 'rmdir' instead.
Back to where I was.
  • Permissions issue
  • Not visible in Mac Finder (not a biggie)
  • Bookshelf was created on Raspberry Pi with downloaded file appearing in both Bookshelf directories (as you would expect)
Ron
DarkElvenAngel
Fri May 29, 2020 3:58 pm
The location pointed to by the link can pi write to it normally? The might be your permission issue
dickon
Fri May 29, 2020 4:07 pm
Er. ln takes the destination as its first argument, not the second.
sudo mv Bookshelf /NetDrive
ln -s /NetDrive/Bookshelf .
is, I think, what you want.
ApexRon
Fri May 29, 2020 4:18 pm
Okay this is getting weird. Raspberry OS wrote the file with minimum permissions and I did a chmod to the Directory and the file. Then I downloaded another file. Note that Raspberry OS continues to use the same permissions when writing a new file:
pi@raspberrypi:~ $ ls -l /home/pi/Bookshelf/
total 74920
-rw-r--r-- 1 pi pi 39359295 May 29 12:05 MagPi93.pdf
-rwxrwxrwx 1 pi pi 37354589 May 29 11:27 MagPi94.pdf
pi@raspberrypi:~ $ ls -l /NetDrive/Bookshelf/
total 74920
Ron
ApexRon
Fri May 29, 2020 4:52 pm
I can now access and read from my Mac and iPad. Yea!!!
Only issue is that the Bookshelf app still stores on Raspberry Pi.
Ron
Return to “Raspberry Pi OS”
