Re: Do not upgrade VLC [solved]
wonder debian update VLC in the 1st place faster than Archlinux, security issue?
- Raspberry Pi Engineer & Forum Moderator
- Location: The unfashionable end of the western spiral arm of the Galaxy
https://www.debian.org/security/2020/dsa-4704cjan wrote: wonder debian update VLC in the 1st place faster than Archlinux, security issue?
Hi!
After update VLC doesn't open up. I have a segmentation fault error warning.
It opens only when using "vlc --reset-config --reset-plugins-cache". Is it only me?
I purged it, reinstalled ALSA and certified that pulseadio is not installed. Same issue.
Thanks!
Thanks!
vlc broken again.
- HawaiianPi
Yup, see: viewtopic.php?f=28&t=282016#p1708241
Re: Do not upgrade VLC [not solved]
Somebody needs to remove [solved] from the header...
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Loves Linux; loves to dance.
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
I just updated, not knowing any of this, and vlc is gone. No longer in the menus or available on command line. How do I get it back?
- mahjongg
- Forum Moderator
That is exactly the OPPOSITE of what I want to do. threads marked solved should not be re-opened. new issues should get a new thread.GlowInTheDark wrote: ↑Wed Aug 05, 2020 10:39 pmSomebody needs to remove [solved] from the header...
I should split this thread in two, but it's already such a chaos that I don't know where to split.
so to stop further derailment, I reluctantly lock this thread.
Please start a new thread, if someone gives me a hint where the split should be so that we split the thread in the solved part, and the place where things go off the rail, I will split, and re-open the new part.
Thanks...
