gkreidl
Do not upgrade VLC [solved]
Sat May 02, 2020 11:44 am
Today a new VLC version appeared in the Raspbian repository (3.0.100+deb10u1).
This version does not contain the RPi-specific patches! Do not upgrade to it!
The maintainers of the Foundation repository should care about the problem. A new version was anounced recently so it seems to be the right time to create an update.
Edit May, 3rd: The Foundation published version 3.0.100+deb10u1+rpt1 which will take precendence. Problem solved.
Minimal Kiosk Browser (kweb)
NightLord
Re: Do not upgrade VLC
Sat May 02, 2020 9:25 pm
I second that.. I did the upgrade, and lost h264 hw decoding. Any ideas how to roll back?
Gadgetguy
Sat May 02, 2020 10:26 pm
Thanks very much for the warning! I have now locked all my vlc packages. It would be great if someone gives Raspbian users the all clear when a new modded version is released
cjan
Sat May 02, 2020 10:32 pm
too late, but i always use GL output.
they did it before, why VLC not been quarantine?
ShiftPlusOne
Sun May 03, 2020 12:49 am
gkreidl wrote: The maintainers of the Foundation repository should care about the problem.
Not much that can be done about it.
Security fixes bump our version intentionally and I get an automatic notification when it happens.
Even if we prioritized our patches over security fixes, this update bumped the upstream version of the package, so the only alternative would be for us to bump the epoch of the package. That's not an option because it would make us eternally responsible for maintaining the package even after our patches are upstreamed.
Unfortunately, unless somebody has a better approach in mind, that means these things will happen sometimes
GlowInTheDark
Sun May 03, 2020 3:25 am
Interestingly, I was going to try (fresh) installing VLC on my RPI4, but seeing this thread, it seems I'd get a broken version of it.
So, the question becomes: What hocus pocus would I have to do to install it and ensure that I get a previous, working version?
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
klricks
Sun May 03, 2020 4:38 am
An update to VLC has just been released via apt.
sudo apt update
sudo apt full-upgrade
gkreidl
Re: Do not upgrade VLC [solved]
Sun May 03, 2020 5:37 am
deleted
GlowInTheDark
Sun May 03, 2020 10:56 am
Just to confirm, are you saying that it is now safe to fresh-install it?
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
gkreidl
Sun May 03, 2020 8:36 pm
Yes.
mvrk80
Wed May 13, 2020 9:09 am
the latest update didn't fix the serious vlc issue on Pi4 4GB
viewtopic.php?f=66&t=246575&start=50
gkreidl
Wed May 13, 2020 9:54 am
I'm also running VLC on a RPi 4B/4G and experience none of your problems.
Phoenixbyrd
Wed May 13, 2020 12:19 pm
Just flatpak install celluloid and remove vlc.
Facelook
Fri May 15, 2020 1:33 pm
Is there an update for "stretch"?
Fri May 15, 2020 1:39 pm
Raspbian Buster is the currently supported release ( Raspberry Pi Foundation / Trading ), and has been since June 2019.
RPi 4B 4GB (SSD Boot)..
gkreidl
Re: Do not upgrade VLC - it happened again
Wed Jun 17, 2020 8:28 am
Today I see a new VLC version in the update list (3.0.11-0+deb10u1). But this is again a default Raspbian version without the RPi specific modifications.
Do not upgrade to it! You will lose HW acceleration and all other RPi-specific modifications.
The RPT repository maintainers should publish a new version as soon as possible.
cjan
Wed Jun 17, 2020 12:06 pm
too late.
never mind, always use GL output.
GlowInTheDark
Wed Jun 17, 2020 12:14 pm
(seriously) just out of curiosity, in which sense are you using the word "should" here?
In the sense of:
1) "ought to" (as in, "You should eat your vegetables")
or
2) "(probably) will" (as in "It should rain tomorrow")
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
gkreidl
Wed Jun 17, 2020 12:58 pm
In the sense of:
or
Both.
Ainz
Wed Jun 17, 2020 2:59 pm
I also lost HW acceleration in VLC after recent update.
How can we get back the HW acceleration? Is it possible to rollback?
ShiftPlusOne
Wed Jun 17, 2020 3:10 pm
A patched version should've been up for a while now.
Ainz
Wed Jun 17, 2020 3:14 pm
Just got the patched version. Thank You.
GlowInTheDark
Wed Jun 17, 2020 3:20 pm
Does that mean that it is once again safe to do the usual update/upgrade stuff?
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Wed Jun 17, 2020 4:16 pm
It would appear so, have just done the update / full-ugrade / reboot dance on my RpiOS64
gkreidl
Wed Jun 17, 2020 5:41 pm
Thanlks, that was really fast!
Return to “Raspberry Pi OS”
