Hello everyone,
I was wondering if there is a way to delete or empty restart.txt in root because it takes so much space. is it possible?
Thanks alot
Is restart.txt in your current directory?
Has your SDCard failed to a read-only status?
You said the file was in root assuming that is the root directory and you are in the default /home/pi directory you need to add the path.
