TheLukaBoss
Apache2 & CGI Setup
Fri Feb 21, 2020 11:27 am
This is my first post. So if you would like any more info, please just ask.
I have setup Apache2 & CGI on my RPi 1 B+ (Jessie). This took a while in itself.
I have routed 'IP/cgi-bin/' to 'usr/lib/cgi-bin/', and this seems to work fine.
However when I visit my webpage 'IP/cgi-bin/test.cgi', which contains the following code:
#!/usr/lib/python3.4
import os
import cgi
cgi.test()
cgi.print_environ()
the 500 error appears. In the error.log file:
[Fri Feb 21 09:37:28.380583 2020] [mpm_event:notice] [pid 2182:tid 3069706768] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 09:37:28.383697 2020] [core:notice] [pid 2182:tid 3069706768] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:08:02.182560 2020] [mpm_event:notice] [pid 2182:tid 3069706768] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 10:08:04.081508 2020] [mpm_event:notice] [pid 4386:tid 3069612560] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 10:08:04.082572 2020] [core:notice] [pid 4386:tid 3069612560] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:08:32.990267 2020] [authz_core:error] [pid 4389:tid 3019895856] [client 192.168.1.10:51161] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:09:34.603844 2020] [authz_core:error] [pid 4390:tid 3045061680] [client 192.168.1.10:51170] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:09:35.757106 2020] [authz_core:error] [pid 4390:tid 3036673072] [client 192.168.1.10:51170] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:10:02.920711 2020] [authz_core:error] [pid 4389:tid 3011507248] [client 192.168.1.10:51174] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:10:03.929164 2020] [authz_core:error] [pid 4389:tid 3053450288] [client 192.168.1.10:51174] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:10:04.088015 2020] [authz_core:error] [pid 4389:tid 3003118640] [client 192.168.1.10:51174] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:11:22.264664 2020] [mpm_event:notice] [pid 4386:tid 3069612560] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 10:11:24.237280 2020] [mpm_event:notice] [pid 4794:tid 3069751824] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 10:11:24.238373 2020] [core:notice] [pid 4794:tid 3069751824] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:11:28.694277 2020] [authz_core:error] [pid 4798:tid 3011507248] [client 192.168.1.10:51186] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:11:29.911101 2020] [authz_core:error] [pid 4798:tid 3019895856] [client 192.168.1.10:51186] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:17:55.482193 2020] [mpm_event:notice] [pid 4794:tid 3069751824] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 10:17:57.466701 2020] [mpm_event:notice] [pid 5352:tid 3069170192] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 10:17:57.473787 2020] [core:notice] [pid 5352:tid 3069170192] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:18:01.577341 2020] [authz_core:error] [pid 5357:tid 3035624496] [client 192.168.1.10:51218] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:19:35.887709 2020] [mpm_event:notice] [pid 5352:tid 3069170192] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 10:19:38.455313 2020] [mpm_event:notice] [pid 5646:tid 3069342224] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 10:19:38.462656 2020] [core:notice] [pid 5646:tid 3069342224] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:19:41.776689 2020] [authz_core:error] [pid 5651:tid 3052401712] [client 192.168.1.10:51235] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:19:42.903448 2020] [authz_core:error] [pid 5651:tid 3044013104] [client 192.168.1.10:51235] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:20:34.161306 2020] [mpm_event:notice] [pid 5646:tid 3069342224] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 10:20:35.949006 2020] [mpm_event:notice] [pid 5857:tid 3069575696] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 10:20:35.953978 2020] [core:notice] [pid 5857:tid 3069575696] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:21:39.639390 2020] [mpm_event:notice] [pid 5857:tid 3069575696] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 10:21:41.601314 2020] [mpm_event:notice] [pid 6025:tid 3070042640] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 10:21:41.609012 2020] [core:notice] [pid 6025:tid 3070042640] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:21:49.188417 2020] [authz_core:error] [pid 6030:tid 3053450288] [client 192.168.1.10:51251] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:23:30.251261 2020] [authz_core:error] [pid 6029:tid 3036673072] [client 192.168.1.10:51268] AH01630: client denied by server configuration: /etc/apache2/usr
[Fri Feb 21 10:27:39.501633 2020] [mpm_event:notice] [pid 6025:tid 3070042640] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 10:27:41.481409 2020] [mpm_event:notice] [pid 6654:tid 3070169616] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 10:27:41.488885 2020] [core:notice] [pid 6654:tid 3070169616] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:27:44.674677 2020] [cgid:error] [pid 6658:tid 3036673072] [client 192.168.1.10:51279] AH01264: script not found or unable to stat: /etc/apache2/usr
[Fri Feb 21 10:27:46.803310 2020] [cgid:error] [pid 6658:tid 3028284464] [client 192.168.1.10:51279] AH01264: script not found or unable to stat: /etc/apache2/usr
[Fri Feb 21 10:28:55.572308 2020] [cgid:error] [pid 6658:tid 3045061680] [client 192.168.1.10:51288] AH01264: script not found or unable to stat: /etc/apache2/usr
[Fri Feb 21 10:30:18.382045 2020] [cgid:error] [pid 6658:tid 2986341424] [client 192.168.1.10:51299] AH01264: script not found or unable to stat: /etc/apache2/usr
[Fri Feb 21 10:30:24.649016 2020] [cgid:error] [pid 6659:tid 3036673072] [client 192.168.1.10:51303] AH01264: script not found or unable to stat: /etc/apache2/usr
[Fri Feb 21 10:30:26.958988 2020] [cgid:error] [pid 6659:tid 3028284464] [client 192.168.1.10:51303] AH01264: script not found or unable to stat: /etc/apache2/usr
[Fri Feb 21 10:35:04.669875 2020] [mpm_event:notice] [pid 6654:tid 3070169616] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 10:35:06.601128 2020] [mpm_event:notice] [pid 7192:tid 3069653520] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 10:35:06.602608 2020] [core:notice] [pid 7192:tid 3069653520] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:35:09.997199 2020] [cgid:error] [pid 7258:tid 3069653520] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:35:10.001684 2020] [cgid:error] [pid 7196:tid 3035624496] [client 192.168.1.10:51396] End of script output before headers: test.cgi
[Fri Feb 21 10:38:52.703158 2020] [cgid:error] [pid 7503:tid 3069653520] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:38:52.707859 2020] [cgid:error] [pid 7198:tid 3044013104] [client 192.168.1.10:51419] End of script output before headers: test.cgi
[Fri Feb 21 10:50:29.458117 2020] [cgid:error] [pid 8272:tid 3069653520] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:50:29.462544 2020] [cgid:error] [pid 7198:tid 3035624496] [client 192.168.1.10:51508] End of script output before headers: test.cgi
[Fri Feb 21 10:50:32.690253 2020] [cgid:error] [pid 8274:tid 3069653520] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.py' failed
[Fri Feb 21 10:50:32.700761 2020] [cgid:error] [pid 7198:tid 3027235888] [client 192.168.1.10:51509] End of script output before headers: test.py
[Fri Feb 21 10:54:34.098505 2020] [mpm_event:notice] [pid 7192:tid 3069653520] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 10:54:36.050077 2020] [mpm_event:notice] [pid 8556:tid 3069219344] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 10:54:36.053785 2020] [core:notice] [pid 8556:tid 3069219344] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:54:39.250599 2020] [cgid:error] [pid 8663:tid 3069219344] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.py' failed
[Fri Feb 21 10:54:39.255243 2020] [cgid:error] [pid 8560:tid 3052401712] [client 192.168.1.10:51587] End of script output before headers: test.py
[Fri Feb 21 10:54:43.333385 2020] [cgid:error] [pid 8665:tid 3069219344] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:54:43.337790 2020] [cgid:error] [pid 8561:tid 3018847280] [client 192.168.1.10:51588] End of script output before headers: test.cgi
[Fri Feb 21 10:54:54.695985 2020] [cgid:error] [pid 8668:tid 3069219344] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:54:54.700193 2020] [cgid:error] [pid 8560:tid 3027235888] [client 192.168.1.10:51593] End of script output before headers: test.cgi
[Fri Feb 21 10:55:08.858162 2020] [mpm_event:notice] [pid 8556:tid 3069219344] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 10:55:10.811131 2020] [mpm_event:notice] [pid 8721:tid 3069776400] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 10:55:10.812610 2020] [core:notice] [pid 8721:tid 3069776400] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:55:13.484937 2020] [cgid:error] [pid 8787:tid 3069776400] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:55:13.489387 2020] [cgid:error] [pid 8725:tid 3036673072] [client 192.168.1.10:51602] End of script output before headers: test.cgi
[Fri Feb 21 10:55:14.456680 2020] [cgid:error] [pid 8788:tid 3069776400] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:55:14.461178 2020] [cgid:error] [pid 8727:tid 3053450288] [client 192.168.1.10:51601] End of script output before headers: test.cgi
[Fri Feb 21 10:55:14.692635 2020] [cgid:error] [pid 8790:tid 3069776400] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:55:14.696993 2020] [cgid:error] [pid 8725:tid 3045061680] [client 192.168.1.10:51603] End of script output before headers: test.cgi
[Fri Feb 21 10:55:15.765793 2020] [cgid:error] [pid 8792:tid 3069776400] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:55:15.775028 2020] [cgid:error] [pid 8727:tid 3045061680] [client 192.168.1.10:51604] End of script output before headers: test.cgi
[Fri Feb 21 10:55:23.943419 2020] [cgid:error] [pid 8795:tid 3069776400] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:55:23.947818 2020] [cgid:error] [pid 8725:tid 3028284464] [client 192.168.1.10:51605] End of script output before headers: test.cgi
[Fri Feb 21 10:56:54.017925 2020] [mpm_event:notice] [pid 8721:tid 3069776400] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 10:56:55.980589 2020] [mpm_event:notice] [pid 8937:tid 3069948432] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 10:56:55.988038 2020] [core:notice] [pid 8937:tid 3069948432] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 10:59:54.195696 2020] [cgid:error] [pid 9228:tid 3069948432] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:59:54.200006 2020] [cgid:error] [pid 8942:tid 3053450288] [client 192.168.1.10:51705] End of script output before headers: test.cgi
[Fri Feb 21 10:59:54.892635 2020] [cgid:error] [pid 9229:tid 3069948432] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 10:59:54.897026 2020] [cgid:error] [pid 8941:tid 3036673072] [client 192.168.1.10:51706] End of script output before headers: test.cgi
[Fri Feb 21 11:01:04.421909 2020] [cgid:error] [pid 9285:tid 3069948432] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 11:01:04.426286 2020] [cgid:error] [pid 8942:tid 3036673072] [client 192.168.1.10:51726] End of script output before headers: test.cgi
[Fri Feb 21 11:02:11.911488 2020] [cgid:error] [pid 9387:tid 3069948432] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 11:02:11.915828 2020] [cgid:error] [pid 8942:tid 3028284464] [client 192.168.1.10:51750] End of script output before headers: test.cgi
[Fri Feb 21 11:06:08.654170 2020] [mpm_event:notice] [pid 8937:tid 3069948432] AH00491: caught SIGTERM, shutting down
[Fri Feb 21 11:06:10.631669 2020] [mpm_event:notice] [pid 9631:tid 3070202384] AH00489: Apache/2.4.10 (Raspbian) configured -- resuming normal operations
[Fri Feb 21 11:06:10.633148 2020] [core:notice] [pid 9631:tid 3070202384] AH00094: Command line: '/usr/sbin/apache2'
[Fri Feb 21 11:06:13.610543 2020] [cgid:error] [pid 9697:tid 3070202384] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 11:06:13.615053 2020] [cgid:error] [pid 9635:tid 3036673072] [client 192.168.1.10:51837] End of script output before headers: test.cgi
[Fri Feb 21 11:06:14.486623 2020] [cgid:error] [pid 9698:tid 3070202384] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 11:06:14.490822 2020] [cgid:error] [pid 9637:tid 3053450288] [client 192.168.1.10:51836] End of script output before headers: test.cgi
[Fri Feb 21 11:06:17.110330 2020] [cgid:error] [pid 9637:tid 3045061680] [client 192.168.1.10:51839] AH01265: attempt to invoke directory as script: /usr/lib/cgi-bin/
[Fri Feb 21 11:06:27.391725 2020] [cgid:error] [pid 9703:tid 3070202384] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.py' failed
[Fri Feb 21 11:06:27.396180 2020] [cgid:error] [pid 9635:tid 3028284464] [client 192.168.1.10:51844] End of script output before headers: test.py
[Fri Feb 21 11:09:09.813617 2020] [core:error] [pid 9637:tid 3036673072] (13)Permission denied: [client 192.168.1.10:51902] AH00035: access to /cgi-bin/test.py denied (filesystem path '/usr/lib/cgi-bin/test.py') because search permissions are missing on a component of the path
[Fri Feb 21 11:09:13.528296 2020] [core:error] [pid 9637:tid 3028284464] (13)Permission denied: [client 192.168.1.10:51902] AH00035: access to /cgi-bin/test.cgi denied (filesystem path '/usr/lib/cgi-bin/test.cgi') because search permissions are missing on a component of the path
[Fri Feb 21 11:09:36.262925 2020] [cgid:error] [pid 9943:tid 3070202384] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 11:09:36.267540 2020] [cgid:error] [pid 9637:tid 3011507248] [client 192.168.1.10:51912] End of script output before headers: test.cgi
[Fri Feb 21 11:09:37.064402 2020] [cgid:error] [pid 9944:tid 3070202384] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 11:09:37.068711 2020] [cgid:error] [pid 9635:tid 3053450288] [client 192.168.1.10:51913] End of script output before headers: test.cgi
[Fri Feb 21 11:09:48.623289 2020] [cgid:error] [pid 9635:tid 3011507248] [client 192.168.1.10:51917] AH01265: attempt to invoke directory as script: /usr/lib/cgi-bin/
[Fri Feb 21 11:10:14.335627 2020] [cgid:error] [pid 9635:tid 2994730032] [client 192.168.1.10:51927] AH01265: attempt to invoke directory as script: /usr/lib/cgi-bin/
[Fri Feb 21 11:10:19.607870 2020] [cgid:error] [pid 10000:tid 3070202384] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 11:10:19.612210 2020] [cgid:error] [pid 9637:tid 2994730032] [client 192.168.1.10:51926] End of script output before headers: test.cgi
[Fri Feb 21 11:10:54.903240 2020] [cgid:error] [pid 10012:tid 3070202384] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 11:10:54.907689 2020] [cgid:error] [pid 9637:tid 2977952816] [client 192.168.1.10:51943] End of script output before headers: test.cgi
[Fri Feb 21 11:11:36.926277 2020] [cgid:error] [pid 10063:tid 3070202384] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 11:11:36.931575 2020] [cgid:error] [pid 9637:tid 2961175600] [client 192.168.1.10:51956] End of script output before headers: test.cgi
[Fri Feb 21 11:12:01.191499 2020] [cgid:error] [pid 10115:tid 3070202384] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 11:12:01.196034 2020] [cgid:error] [pid 9635:tid 2977952816] [client 192.168.1.10:51964] End of script output before headers: test.cgi
[Fri Feb 21 11:15:14.978992 2020] [cgid:error] [pid 10296:tid 3070202384] (13)Permission denied: AH01241: exec of '/usr/lib/cgi-bin/test.cgi' failed
[Fri Feb 21 11:15:14.983357 2020] [cgid:error] [pid 9635:tid 2969564208] [client 192.168.1.10:52028] End of script output before headers: test.cgi
In main config:
# This is the main Apache server configuration file.  It contains the
# configuration directives that give the server its instructions.
# See http://httpd.apache.org/docs/2.4/ for detailed information about
# the directives and /usr/share/doc/apache2/README.Debian about Debian specific
# hints.
# Summary of how the Apache 2 configuration works in Debian:
# The Apache 2 web server configuration in Debian is quite different to
# upstream's suggested way to configure the web server. This is because Debian's
# default Apache2 installation attempts to make adding and removing modules,
# virtual hosts, and extra configuration directives as flexible as possible, in
# order to make automating the changes and administering the server as easy as
# possible.
# It is split into several files forming the configuration hierarchy outlined
# below, all located in the /etc/apache2/ directory:
#	/etc/apache2/
#	|-- apache2.conf
#	|	`--  ports.conf
#	|-- mods-enabled
#	|	|-- *.load
#	|	`-- *.conf
#	|-- conf-enabled
#	|	`-- *.conf
# 	`-- sites-enabled
#	 	`-- *.conf
# * apache2.conf is the main configuration file (this file). It puts the pieces
#   together by including all remaining configuration files when starting up the
#   web server.
# * ports.conf is always included from the main configuration file. It is
#   supposed to determine listening ports for incoming connections which can be
#   customized anytime.
# * Configuration files in the mods-enabled/, conf-enabled/ and sites-enabled/
#   directories contain particular configuration snippets which manage modules,
#   global configuration fragments, or virtual host configurations,
#   respectively.
#   They are activated by symlinking available configuration files from their
#   respective *-available/ counterparts. These should be managed by using our
#   helpers a2enmod/a2dismod, a2ensite/a2dissite and a2enconf/a2disconf. See
#   their respective man pages for detailed information.
# * The binary is called apache2. Due to the use of environment variables, in
#   the default configuration, apache2 needs to be started/stopped with
#   /etc/init.d/apache2 or apache2ctl. Calling /usr/bin/apache2 directly will not
#   work with the default configuration.
# Global configuration
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE!  If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the Mutex documentation (available
# at <URL:http://httpd.apache.org/docs/2.4/mod/core.html#mutex>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
#ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
Mutex file:${APACHE_LOCK_DIR} default
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 5
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here.  If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog ${APACHE_LOG_DIR}/error.log
# LogLevel: Control the severity of messages logged to the error_log.
# Available values: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the log level for particular modules, e.g.
# "LogLevel info ssl:warn"
LogLevel warn
# Include module configuration:
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
# Include list of ports to listen on
Include ports.conf
# Sets the default security model of the Apache2 HTTPD server. It does
# not allow access to the root filesystem outside of /usr/share and /var/www.
# The former is used by web applications packaged in Debian,
# the latter may be used for local directories served by the web server. If
# your system is serving content from a sub-directory in /srv you must allow
# access here, or in any related virtual host.
<Directory />
	Options FollowSymLinks
	AllowOverride None
	Require all granted
</Directory>
<Directory /usr/share>
	AllowOverride None
	Require all granted
</Directory>
<Directory /var/www/>
	Options Indexes FollowSymLinks
	AllowOverride None
	Require all granted
</Directory>
#<Directory /srv/>
#	Options Indexes FollowSymLinks
#	AllowOverride None
#	Require all granted
#</Directory>
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives.  See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<FilesMatch "^\.ht">
	Require all denied
</FilesMatch>
# The following directives define some format nicknames for use with
# a CustomLog directive.
# These deviate from the Common Log Format definitions in that they use %O
# (the actual bytes sent including headers) instead of %b (the size of the
# requested file), because the latter makes it impossible to detect partial
# requests.
# Note that the use of %{X-Forwarded-For}i instead of %h is not recommended.
# Use mod_remoteip instead.
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Include of directories ignores editors' and dpkg's backup files,
# see README.Debian for details.
# Include generic snippets of statements
IncludeOptional conf-enabled/*.conf
# Include the virtual host configurations:
IncludeOptional sites-enabled/*.conf
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
In 000-default.conf:
<VirtualHost *:80>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "usr/lib/cgi_bin">
	AddHandler cgi-script .py
	AddHandler cgi-script .cgi
	AddHandler cgi-script .sh
	AllowOverride None
	Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
	Require all granted
</Directory>
<Directory "/etc/apache2/usr">
	Require all granted
</Directory>
	# The ServerName directive sets the request scheme, hostname and port that
	# the server uses to identify itself. This is used when creating
	# redirection URLs. In the context of virtual hosts, the ServerName
	# specifies what hostname must appear in the request's Host: header to
	# match this virtual host. For the default virtual host (this file) this
	# value is not decisive as it is used as a last resort host regardless.
	# However, you must set it for any further virtual host explicitly.
	#ServerName www.example.com
	ServerAdmin webmaster@localhost
	DocumentRoot /var/www/html
	# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
	# It is also possible to configure the loglevel for particular
	# modules, e.g.
	#LogLevel info ssl:warn
	CustomLog ${APACHE_LOG_DIR}/access.log combined
	# For most configuration files from conf-available/, which are
	# enabled or disabled at a global level, it is possible to
	# include a line for only one particular virtual host. For example the
	# following line enables the CGI configuration for this host only
	# after it has been globally disabled with "a2disconf".
	#Include conf-available/serve-cgi-bin.conf
</VirtualHost>
I understand the issue is to do with permissions (I think), however I do not know what chmod setup to use where.
Any help would be greatly appreciated.
Thanks!
:idea: Anyone with a light bulb moment should help me. I am not lucky enough to get them.
Also thanks to everyone for everything! Have a good day!
knute
Re: Apache2 & CGI Setup
Fri Feb 21, 2020 9:04 pm
So enabling CGI is very simple with current apache. You don't need to edit ANY files. Just run the command:
sudo a2enmod cgid
Next put your CGI files in the /usr/lib/cgi-bin directory. They need to be executable by www-data.
That's it!
I would guess that your 500 error is caused by some permission problem. Try setting the owner of your CGI program file to www-data:www-data and the permissions to 750.
TheLukaBoss
Fri Feb 21, 2020 9:18 pm
sudo a2enmod cgid
That's it!
Ok thanks!
Step number 1 I already tried, it was already running.
The other steps seem to make no difference.
Thanks!
import os
import cgi
cgi.test()
cgi.print_environ()
Your shebang line is incorrect. It should be
#!/usr/bin/python3
or
#!/usr/bin/env python3
TheLukaBoss
Fri Feb 21, 2020 9:31 pm
import os
import cgi
cgi.test()
cgi.print_environ()
#!/usr/bin/python3
or
Ah thanks, hoped you'd reply!
Of course the first shebang path worked a treat!
Kudos to you.
Thanks once more.
Return to “Raspberry Pi OS”
