tigernero
Problem 7 led act raspberry pi4 with sudo reboot
Fri Feb 07, 2020 8:49 pm
since I updated to version 2020-02-05 raspbian with kernel update 4.19.97,
7 times out of 10 with the simple "sudo reboot" command my 2 pi4s that worked well until a few days ago do not restart,
and I am forced to turn off and on again. I noticed that the led act emits 7 short flashes which means kernel image not found,
but maybe I am wrong that this does it to me after the update of February 5, and with 2 pi4 to which
I connected an external USB hd. it doesn't happen to me on pi3 that i have with the same raspbian image
ralphrmartin
Re: Problem 7 led act raspberry pi4 with sudo reboot
Sat Feb 08, 2020 10:16 am
I am having the same problem.
Previously, I could boot my RPi 4 fine with rootfs on a Sandisk Extreme SSD connected via a powered Startech USB 3. Now boot fails every time, but messages flash by took quickly to see what starts the chain of problems off - but there are definitely USB related error messages.
The same setup works OK if I swap out the USB 3 hub for a USB 2 hub.
Something is definitely broken in USB3 in 4.19.97
raspijunky
Sat Feb 08, 2020 1:12 pm
Same to me with 2 Pi's 4
Setting up a brand new rapsbian with only webmin installed reboot hangs and green led flashes 7 times
tigernero
Sun Feb 09, 2020 6:02 am
you too like me have connected an external HD with data inside on USB 3.0?
I think it is a serious bug not being able to restart a pi4 with HD connected on USB and to see it not to start with. 7 flashing LEDs
RonR
Sun Feb 09, 2020 9:38 am
Add me to the list of affected Raspberry Pi 4 users.
It began here with the kernel update just before the 2020-02-05 image was posted. I had hoped the problem would go away with the new image, but it has not. I'm running Raspbian Lite here.
I don't know if it's related, but when logged in as root, raspi-config now displays:
Sun Feb 09, 2020 10:22 am
You have to run raspi-config as pi (not root) and let it switch to root when needed.
This is a doctor free zone.
HawaiianPi
My 4B2 was recently updated to the latest (stable) firmware and kernel, and it has the OS on SSD (SATA-III SSD with USB 3.0 adapter cable).
I have no trouble restarting that system. The system was updated with the following command.
sudo apt update && sudo apt full-upgrade -y
RaspberryPi4B2:~ $ uname -a
Linux RaspberryPi4B2 4.19.97-v8+ #1294 SMP PREEMPT Thu Jan 30 13:27:08 GMT 2020 aarch64 GNU/Linux
RaspberryPi4B2:~ $ cat /sys/firmware/devicetree/base/model;echo
Raspberry Pi 4 Model B Rev 1.1
RaspberryPi4B2:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
RonR
Sun Feb 09, 2020 7:25 pm
raspi-config has ALWAYS run properly as root until this last update. If you run it as pi, it insists that you run it with sudo. If you enter root instead of pi, it simply re-prompts with pi as the default again. I don't do anything as user pi. I always run as root (please don't start with the lectures).
Something is terribly out of whack with this the last update and image.
tigernero
Sun Feb 09, 2020 7:56 pm
the startup lock error after a simple "sudo reboot" occurs 9 times out of 10 only on Raspberry pi4
not on the other pi4s that I have.
something in the latest February 5 update or in the 4.19.97 kernel does not correctly restart the pi4.
is it possible that the raspbian team is not aware of this problem?
HermannSW
Sun Feb 09, 2020 8:05 pm
Buster 2/5 image broke raspivid recording as well.
6by9 provided rpi-update workaround 4 hours ago, and now raspivid works again:
https://www.raspberrypi.org/forums/view ... 5#p1608966
Going back with rpi-update to some changelist will definitely fix the reboot issue you see, unclear which changelist.
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
RonR
Sun Feb 09, 2020 8:50 pm
Running 'rpi-update 993f475' appears to fix the reboot problem (the expected behavior of the red power led is also restored).
[If you are booting a USB device via an SD card and you update your SD card first, you must delete /boot/.firmware_revision before you will be able to update your USB device.]
NOTE: The problem with running raspi-config as root is NOT corrected with this update.
tigernero
Sun Feb 09, 2020 8:57 pm
I gave "sudo rpi-update 993f475" command on my pi4 and see if it gets stuck in reboots. on another pi4 that is no longer reachable after a reboot located at work, I will give the same command tomorrow and see if the subsequent reboots resolved the problem thanks for now.
tigernero
Sun Feb 09, 2020 9:14 pm
after giving two consecutive restarts to my home, the second one gave the same problem as the no restart of raspbian. also after having given the rpi-update 993f475 command as mentioned above
raspbian is installed on microsd, but i have a hd of my data connected on usb 3.0
tigernero
Sun Feb 09, 2020 9:26 pm
tried to remove the /boot/.firmware_revision file and restore the rpi-update 993f475 command and it seems to say it seems to hold 2 consecutive reboots. we hope well
RonR
Sun Feb 09, 2020 10:04 pm
The first reboot after running 'rpi-update 993f475' may still be problematic as the Raspberry Pi is not running the updated software until after the reboot. Hopefully you'll be good after that.
RonR
Sun Feb 09, 2020 11:13 pm
The problem with running raspi-config as user 'root' is not related to the reboot problem. This problem was introduced into the latest update of raspi-config.
The following script will make a copy of the original raspi-config as /usr/bin/raspi-config_orig and patch /usr/bin/raspi-config to be able to run when logged in as user 'root':
#!/bin/bash
if [ ! -f /usr/bin/raspi-config_orig ]; then
  cp /usr/bin/raspi-config /usr/bin/raspi-config_orig
fi
sed -i 's/\"root\"/""/' /usr/bin/raspi-config
carver1
Mon Feb 10, 2020 8:46 pm
Out of curiousity:
—Have you rebooted more than once since applying that update?
—And assuming you’ve rebooted while using a terminal, were you doing so with an keyboard attached to your RPi4, or via SSH, VNC, etc?
—Are you running Raspbian Desktop or Lite?
—What syntax did you use to reboot? (This sounds tedious, but I can consistently reboot via ‘sudo reboot’ but I consistently get only a shutdown followed by a solid red light whenever I use ‘sudo shutdown -r now’ )
tigernero
Tue Feb 11, 2020 6:42 am
kernel update 4.19.97 of 10 February has solved the restart problem if not also resolved raspi-config problem with root user
RonR
Tue Feb 11, 2020 6:54 am
I'm not seeing a resolution to raspi-config running under user 'root' other than the patch I posted (that may be what you were saying as your statement is unclear to me).
ShiftPlusOne
Tue Feb 11, 2020 10:25 am
The raspi-config change is intentional.
There are a number of setting which are user-specific rather than system-wide. In the past, raspi-config would assume the user is 'pi', which isn't always the case. Then it assumed that it was run through sudo, so $SUDO_USER was set. Now it used $SUDO_USER, falls back on who -m, and then if the user insists on trying to run it directly as root, it will ask which user those settings should apply to.
RonR
Tue Feb 11, 2020 8:50 pm
But you're excluding user 'root' from being one of those users.
ShiftPlusOne
Tue Feb 11, 2020 9:19 pm
Yes. If you're using raspi-config and don't know why you wouldn't want to autologin as root, then it won't let you shoot yourself in the foot. If you believe you have a good reason to override that check, you don't need raspi-config in the first place.
RonR
Tue Feb 11, 2020 9:52 pm
I guess we're going to have to agree to disagree on this one. My philosophy has always been to write software that makes tasks easier for the user, not more difficult. As noted, the restriction is easily removed.
Return to “Raspbian”
