Solskogen
Position-independent code
Tue Feb 04, 2020 10:28 am
On Debian buster (x86_64) gcc creates PIE binaries by default, while Raspbian does not.
Rasbian
 cat test.c
int main(void)
        return 0;
gcc test.c
 hardening-check a.out
a.out:
 Position Independent Executable: no, normal executable!
 Stack protected: no, not found!
 Fortify Source functions: unknown, no protectable libc functions used
 Read-only relocations: yes
 Immediate binding: no, not found!
Debian x86_64
a.out:
 Position Independent Executable: yes
arm-linux-gnueabihf-gcc test.c
a.out:
So both the native and the cross compiler on Debian buster creates PIE by default. Why doesn't Raspbian do the same?
Return to “Raspberry Pi OS”
