I am a secondary school teacher from Wellington, NZ, trying out the rpi at home before possibly launching it at school next year. Problem is, I don't have broadband/ethernet at home, just the old-fashioned dial-up.
So, I can't use apt-get!
My PRi runs Raspbian Wheezy on a 16GB SD card which I built with win32discimager.
In past months I've already had a go at trying to get a Conexant usb dial-up modem going on my laptop with Linux Mint 13KDE, to no avail. I then loaded Puppy Slacko onto my work laptop (deleted Mint) and this distro was easy as it immediately recognised the modem & connected to my ISP.
Now I have a new RPi board set up and am struggling once again to get the USB modem working. After googling around a bit on the (dial-up!) laptop, I've tried all the following:
1) Try DPKG, aptitude, to install USB-modeswitch plus data package along with libusb - no joy here either, although libusb-0.1.12 did seem to install fully. I think after this that maybe I don't need USB_modeswitch anyway as it doesn't have windows drivers built into the chip?
2) Try to install the conexant USB modem's linux drivers that came on a disk with the device. I tried installing the .deb plus the .tar.gz versions but neither would install. The dgcmodem-1.13.tar.gz wouldn't even decompress/unzip, saying "unexpected end of file...Child returned status 1...error is not recoverable, etc.
3) Copy the ppp folder from Puppy & try to load this on the RPi - didn't work.
My question is, does anyone know whether it should be possible to get a USB dial-up modem working on the RPi? How does one go about this?
Perhaps, the ARM architecture doesn't support the modem's drivers? Is there a place where I can download an ARM-compatible driver? I couldn't find anything on linuxant. Should I try loading Puppy onto the SD card and use that distro instead of Raspbian Wheezy? Do the versions of Puppy available on this PRi website support dial-up?
Any thoughts from others who've gone down this path would be greatly appreciated.
Kind Regards,
DIYKiwi
PS: going up to paint the roof now!
