mtylerb
Re: Minecraft 1.14.4 on Raspbian Buster and RPi4
Mon Mar 30, 2020 1:14 pm
lilbytez wrote:
Mon Mar 30, 2020 12:50 am
I had already installed the 1.12.2 version rpiMike made. I thought that was the latest version for the Pi 4. And whenever I open the form on this one where I change my username to normal I see no text. Is there any workaround for this? Thanks.
I had that problem when I was using the incorrect launcher. The new launcher shows a white screen, the older launcher works.
https://www.dropbox.com/s/rwhgz44l3k7no ... t.jar?dl=0
That's the launcher from my script.
timof121
Fri Apr 10, 2020 2:06 pm
Is there any way to run versions like 1.15.2 or 1.16? I was thinking minecraft 1.13+ need LWJGL 3.
rpiMike
Fri Apr 10, 2020 2:10 pm
I've got 1.15.2 working with preview optifine.
timof121
Fri Apr 10, 2020 2:25 pm
DarkPlatinum wrote:
Fri Dec 27, 2019 8:42 am
How did the opengl driver work? All I get is lines on the minecraft window.
For me it worked
timof121
Fri Apr 10, 2020 2:26 pm
Hello. What i neeed to change in the script to run it?
theohmn
Fri Apr 10, 2020 5:45 pm
I'd love to know too, my son is desperate to get this working on his Pi :)
timof121
Sat Apr 11, 2020 4:34 pm
I will loook the difference between the 1.12.2 script, and if i get working versions like 1.15.2 i will notify you
Ehrelicio
Sat Apr 11, 2020 11:50 pm
This is great - works perfectly! Is there a way to update for version 1.15.2? Thank you!
timof121
Sun Apr 12, 2020 8:04 pm
Did you found a way how to update to 1.15.2?
DestyNova
Sun Apr 12, 2020 8:45 pm
This is fantastic! I ran into two small problems that were easily solved:
  1. The launcher was getting stuck while trying to launch vanilla Minecraft, so the Optifine installer later refused to run because the profile hadn't been initialised yet. The stack trace matched this upstream bug report. One of the comments suggested to download this version of the Minecraft launcher, so I did that, then used
    mv launcher.jar Minecraft.jar
    to replace the existing Minecraft.jar downloaded by the script.
  2. The client was then able to start up, host a local game, and join a 1.14.4 game running on my laptop. However, it was crashing after a minute or two with an error like:
    mmap of bo 706 ..... failed
    This looked like the JVM was trying to grow the heap and failed to allocate more memory. I was a bit surprised how much of the 4 GB on the RPi4 is taken up with just running the desktop environment and a terminal. Anyway, changing the run script to use
    -Xmx1500m
    instead of
    -Xmx2g
    seems to have done the trick.
rpiMike
Tue Apr 14, 2020 8:40 pm
How to setup 1.15.2:
viewtopic.php?f=78&t=270973
timof121
Fri Apr 17, 2020 8:05 am
Thanks!
LordMontag
Sat May 09, 2020 4:55 pm
Thankyou sooooooo much!!!!! :) Worked perfectly for this Pi noob. Super impressed at your attention to detail - and the "select all" for copy paste was just super awesome.
Return to “Raspberry Pi OS”
