Could it be explained in a simpler way?
Posted: Thu Dec 05, 2019 2:15 am
by rin67630
Upon updating Raspbian Buster with
sudo apt-get update
I get this error:
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'testing' to 'stable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
The man pages are at least as confusing as the main error containins absolutley no examples of the expected syntax to accept the stable release.
Could it be possible to get a simple example of how to accept above mentioned InRelease?
Thank you for helping
Re: Could it be explained in a simpler way?
Posted: Thu Dec 05, 2019 2:20 am
by trejan
Run "sudo apt update" instead and it'll prompt you. apt-get is intended for non-interactive usage in scripts so works differently to apt.
It is very unlikely apt-get or the man pages will be modified. It has been like this in upstream Debian for a long time now and the Raspbian maintainers try to avoid modifying packages as it is a maintenance headache.
Posted: Thu Dec 05, 2019 2:22 am
by fruitoftheloom
sudo apt-get update
I get this error:
Use APT as recommended:
sudo apt update
sudo apt full-upgrade
sudo reboot
https://www.raspberrypi.org/documentati ... pdating.md
Posted: Thu Dec 05, 2019 2:43 am
by rin67630
Thank you (and Trejan). So easy, once you do it right! :P
Posted: Thu Dec 05, 2019 10:45 am
by andrum99
Background: 'apt-get' used to be the recommended way to do these things, then 'apt' was developed as a successor.
Posted: Thu Dec 05, 2019 10:50 am
by rpdom
Sort of.
apt was developed as a more "user friendly" way to do things. apt-get is best for automated scripts and other things and is fine if you are used to doing things that way.
You will have to prise my apt-get from my poor dead broken pedipalps before I stop using it ;-)
Posted: Fri Dec 06, 2019 2:58 am
by Imperf3kt
Personally, I prefer aptitude, though I do still use apt mostly. Haven't used apt-get since the moment I found out I didn't have to type the -get bit.
