UNeverNo
eth0 not initialized properly on startup/after reboot
Sat Oct 12, 2019 8:50 pm
After applying latest updates it seems that my raspberry 2 B 1.1 can't initalize the ethernet adapter properly, in fact there are only a couple of times when it doesn't fail on startup.
When I do a reboot, it almost always fails.
I also get some undervolting-messages although I'm just idling in terminal (I didn't observe this before).
Power supply #1: 5,23-5,26V @ 0,23A
Power supply #2: 5,13V @ 0,23A
Power supply #3: 5,07V @ 0,23A
OS: buster
Kernel: 4.19.75-v7+
B.Goode
Re: eth0 not initialized properly on startup/after reboot
Sun Oct 13, 2019 7:20 am
Welcome to the Raspberry Pi forums.
OS: buster
Kernel: 4.19.75-v7+
Your power supplies look under-specified.
See the tables published by Raspberry Pi here: https://www.raspberrypi.org/documentati ... /#pi-power
Product Recommended PSU current capacity Maximum total USB peripheral current draw Typical bare-board active current consumption
Raspberry Pi 2 Model B 1.8A 600mA/1.2A (switchable) 350mA
UNeverNo
Thu Oct 17, 2019 10:23 am
All power supplies provide up to 2A, which should be more than sufficient. 230mA just seems to be the value if nothing else happens on the pi.
Gooseman
Thu Oct 17, 2019 10:35 am
I have seen problems in the past even with good power supplies (5.1V/2A) due to low-quality USB cables. Sadly also the USB Micro connector on either side (RPi and/or cable) can wear off with time and lead to increased voltage drop at power spikes. Being very short you do need more sophisticated equipment to see this, a multimeter is not enough. Try a shorter USB cable, maybe with higher cross section. I switched a some time ago to a Blitzwolf Ampcore cable and my problems went away.
B.Goode
If current from your unspecified power supplies is not the issue, maybe poorly-regulated voltage is? Perhaps the Voltage 'sags' at times of peak power demand?
This could be exacerbated by inadequate cabling causing a loss of power delivered to the board.
'Official' Raspberry Pi supplies do not have either of these issues.
Return to “Raspberry Pi OS”
