Page 8 of 14
Re: [Guide] Kodi on Raspbian Buster
Posted: Thu Dec 05, 2019 9:33 pm
by gkreidl
G160 wrote:
Thu Dec 05, 2019 6:32 pm
Hi first off thanks for this.
Only issue I have is watching 1080i content, from a TVHeadend server...it plays for 2-5 seconds then the picture just freezes and I have to press stop to return to the menu.
Has anyone experienced this or know of a fix?
Happy to provide logs if needed.
Cheers.
I just tested 1080i TV streams, not from tvheadend but from mumudvb (but that shouldn't matter). They play fine and never break.
Check your GPU memory settings.
Posted: Fri Dec 06, 2019 9:10 am
by G160
Rascas wrote:
Thu Dec 05, 2019 8:00 pm
Cheers.
Yes, please post your Kodi debug log: http://kodi.wiki/view/Log_file
Sure buddy, thanks for taking a look.
https://pastebin.com/kJaRH1La
One thing to note is that the issue only appears when trying to watch live tv channels, the recordings from these channels (exactly the same format, untouched, 1080i x264 .ts files) play perfectly with no issues.
Posted: Fri Dec 06, 2019 10:03 am
by G160
Cheers.
Thanks for the tip, but ive checked that and it's set to 320.
I've taken the HTS pvr add-on out of the equation by loading the channels all into a .m3u file, with exactly the same results.
I should point out that all channels play perfectly on a Vero4k+ running Kodi 18.5 and macOS running Kodi 18.5, using both the pvr.hts add-on, and the .m3u file.
Posted: Fri Dec 06, 2019 11:05 am
by Seketh
Cheers.
What version of tvheadend are you using? I've had some issues with the 4.2 that is on the raspian repo, so I moved to Docker (linuxserver/tvheadend). It's the latest 4.3 and is working fine with an Xbox tv tuner.
Posted: Fri Dec 06, 2019 11:27 am
by G160
Thanks for the suggestion, im running 4.2.8, but I don't really want to pursue that route until I know its absolutely necessary, considering I have no problems with a Vero4k+ and macOS using this version 4.2.8.
Edit:
Just to clear this up ive upgraded my TVHeadend server to 4.3 and the issue is still there, no difference.
Thanks anyway...it was worth a shot.
Posted: Fri Dec 06, 2019 5:31 pm
by Rascas
andrum99 wrote:
Thu Dec 05, 2019 9:25 pm
It seems this build of Kodi doesn't work with the 64-bit kernel. Is this a known "issue"? I put that in inverted commas, since the 64-bit kernel is just a beta.
I am not sure if it is supposed to work with the 64-bit kernel, I suppose not. There is some hardware stuff on the Pi that is 32 bit only (I don't remember what exactly now) and maybe that is used by Kodi. I believe that only Kodi 19 will work, when the ffmpeg + v4l2 stuff is done. But ask here, they know better: https://www.raspberrypi.org/forums/view ... 9&t=250730
Posted: Fri Dec 06, 2019 8:12 pm
by andrum99
I don't know whether the problem is Kodi or the kernel - Kodi crashes at startup after displaying its bootsplash. I can provide logs if you like? I will also mention it on the 64-bit kernel thread.
Posted: Fri Dec 06, 2019 8:51 pm
by maxipower
I also tested this 64bit OS and managed to install the youtube addon on Kodi, but when i tried to open youtube the Kodi crashes.
Posted: Fri Dec 06, 2019 9:22 pm
by Rascas
No need to provide logs here, I already tested and I can confirm that it does not work. The error is the "could not initialize vc shared memory service". This could indicate that there was a permissions issue but it is not that because if you start Kodi as root it gives the same error. I believe it is something to do with what I said on my previous comment, I don't know what to do to fix it or even if it is possible to fix it like it is now.
If you take a look on the 64 bit kernel thread, on the first post they say "vcsm driver doesn't work with 64-bit (only the cma version) which will break software decode with kodi". Don't know what they exactly mean by that but CMA doesn't work also for me. Provide your Kodi log and terminal output on that thread, they may be able to help.
Posted: Fri Dec 06, 2019 10:04 pm
by Rascas
Update: If you update kernel/firmware with rpi-update, Kodi with the 64 bit kernel works. But somethings might not work, more fixes may be needed in kernel/firmware and Kodi source code.
Posted: Fri Dec 06, 2019 10:40 pm
by maxipower
Can you take a look at this topic in fórum Librelec, this issue does on both, Libreelec and under Raspberry OS.
https://forum.libreelec.tv/thread/20769 ... -frame-or/
Posted: Sat Dec 07, 2019 12:36 am
by Rascas
I will take a look at it on Monday, looks like it does only apply if you turn "Enable change refresh rate" on right? But even if I confirm the issue, I am afraid I can't do much to fix it. I only compile/package Kodi for Raspbian to work on all RPi version and make some small Raspbian specific fixes, I am not a Kodi dev. If it is a bug that occurs on Raspbian and Librelec, it is better to repor it on Kodi oficial forum.
Posted: Sat Dec 07, 2019 11:50 am
by maxipower
I´ll see if i find anything on the Kodi fórum.
Thanks for the answer...
Posted: Sat Dec 07, 2019 2:51 pm
by andrum99
Thanks - that is Kodi now working for me :D
One minor issue I noticed when running both with 32 and 64-bit kernels, is after playing a video from a samba share within Kodi, then exiting backk to the command line I have warnings like this:
mkdir failed on directory /var/cache/samba: Permission denied
Which is probably not surprising as I'm running Kodi under the 'pi' user, and /var/cache/samba doesn't exist.
Posted: Tue Dec 10, 2019 10:59 am
by G160
Cheers.
Any ideas on this guys?
Posted: Thu Dec 12, 2019 3:17 pm
by vtolstov
now with having all updates installed
[ 15.190915] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:49:crtc-0] flip_done timed out
[ 25.430912] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:49:crtc-0] flip_done timed out
[ 35.670859] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CONNECTOR:51:HDMI-A-1] flip_done timed out
[ 45.910873] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:28:plane-0] flip_done timed out
Posted: Thu Dec 12, 2019 3:52 pm
by Rascas
What updates are you refering to ? Updates using rpi-update tool are not supported, always use the kernel/firmware provided by the package manager and always provide the full debug log.
Posted: Thu Dec 12, 2019 3:55 pm
by Rascas
Cheers.
I took a look at the log and I cannot see anything related to your problem, so I have no clue. Can you tell the exact version of the TVHeadend server and also the TVHeadend client you are using in the machines that work ?
Posted: Thu Dec 12, 2019 4:11 pm
by vtolstov
Full updates means apt full-upgrade and this is full kernel log. I'm try to reboot 4 times and always have such errors.
Now I'm do rpi-update and reboot. Issue does bot appeared
How to return to stable after for example two months?
Posted: Thu Dec 12, 2019 4:23 pm
by Rascas
I don't know what that messages mean, I never saw them on mine, only that they are related to the graphics stack drivers and display.
You can return to stable kernel/firmware by reinstalling the following packages:
libraspberrypi-bin
libraspberrypi-dev
libraspberrypi-doc
libraspberrypi0
raspberrypi-bootloader
raspberrypi-kernel
Posted: Thu Dec 12, 2019 10:51 pm
by Lipown
Guys, I am getting Kodi freezed on exit like 80 percent of the time for last 14 days. The crashlog is not generated and I am forcing the Raspberry PI 4 to reboot so I don't need to unplug cable. Anyway it take quite a long time for reboot to kill Kodi and reboot. Any guide how to get the log or any other ideas what is going on please?
Posted: Fri Dec 13, 2019 12:02 am
by Rascas
https://kodi.wiki/view/Log_file
Posted: Fri Dec 13, 2019 3:02 am
by Gadgetguy
Check out this close kodi addon:
https://github.com/Based-Skid/plugin.close.kodi
I have been using it for some time and for me it has been quick and consistently reliable.
I add to my kodi favourites for quick access when it is time to close kodi
Posted: Fri Dec 13, 2019 8:54 am
by G160
Well strange thing, after doing nothing for 2 days, I power it up and it all seems to be working, im scratching my head at this one but the important thing is its working.
Posted: Mon Dec 16, 2019 10:21 pm
by hawkeye_a
Rascas wrote:
Mon Dec 02, 2019 4:23 pm
hawkeye_a wrote:
Mon Dec 02, 2019 2:55 pm
Hi folks. New member here.
Been a RPi2 for some years now, and have been using the RPi4-4 for a few months. Been having an issue with Kodi on Buster, and was hoping someone could point me to a fix/solution.
I did a "fresh" install of Buster last week via Noobs, and installed a few apps in Buster (LibreOffice, Gimp, Kodi). I haven't changed any of the default settings of Kodi. Playback of H264 video works like a charm, but anytime I try to play a HEVC(SD; haven't tried HD) file, Kodi crashes and returns me to Buster's desktop. This has happened multiple times so far.
Any suggestions?
Cheers
(Apologies if this issue has been answered elsewhere)
Post your Kodi debug log after reproducing the problem:
Apologies for not posting any logs yet. I wanted to make sure it wasn't anything specific to my build/pi, so I started from scratch and:
-updated the Raspberry Pi firmware to 2.4.1(latest as of 7 days ago?)
-Installed Raspbian(within the past 7 days)
-installed Kodi using apt (version 18.4?)
I tested playback from an external USB harddrive. H264(sd and hd) videos play fine. HEVC(any resolution) causes the screen to go blank momentarily, Kodi crashed and I'm back at the Raspbian desktop.
Off a different SD card, with LibreElec(Kodi 18.5?), playback of HEVC(any resolution) from an external USB drive is just fine, and it appears to be using hardware decoding(judging by the processor/memory activity monitor).
Cheers
Note*:I havent tried playing HEVC files in VLC on Raspbian.
