Paul.D
Re: [Guide] Kodi on Raspbian Buster
Wed Mar 11, 2020 3:01 pm
JOHN009 wrote:
Fri Nov 01, 2019 9:17 am
i was facing error of Ares Wizard error i searched on google and found a article and now problem is solved i hope it will help others too
how you found this useful
flyingsubs
Tue Mar 17, 2020 8:37 pm
Anyone having issues with video? Live tv seems to be choppy and recorded TV is also having issues. Not sure If i touched a setting at all. Not sure if this is the right place to post logs about it?
Is this the best place to post about issues?
Thanks!
-Flyingsubs
Rascas
Wed Mar 18, 2020 12:00 am
Thanks!
-Flyingsubs
Does turn on/off "Adjust display refresh rate" and "Sync playback to display" fix it? Default are both disabled.
If it doesn't I recommend that you try Kodi with clean/default settings. Close Kodi, move/remove ~/.kodi and start Kodi again.
flyingsubs
Wed Mar 18, 2020 12:16 am
Thank for the response! That setting is already turned off. I can start again, would you want to see the log in case there is something that can be fixed? Or are you thinking this is related to the skin helper service?
The other issue which I believe is related is the audio cut out and changes. I have surround sound and then all I can hear is the background noise.
Thanks,
Flyingsubs
Rascas
Wed Mar 18, 2020 12:26 am
Thanks,
Flyingsubs
Start fresh like explained above a see if the problem still exists, if so, post your kodi debug log.
flyingsubs
Wed Mar 18, 2020 1:01 am
Thanks will do. Can I still use the skin mod or does it have to be clean kodi no addons?
Rascas
Wed Mar 18, 2020 1:05 am
Clean, default skin. If the problem is the skin I can't do anything, you have to post your problem in Kodi forum, sub topic of that skin.
flyingsubs
Wed Mar 18, 2020 10:50 pm
Thank you! I think I may have figured it out? I did a test going to Youtube and got no sound. DId a sound test and that didn't work either. I read some forums and went to the config.txt and uncommented out hdmi_force_hotplug=1 rebooted and so far not having an issue. Also I uncommented HDMI_drive=2
Thanks,
Flyingsubs
Rascas
Mon Mar 23, 2020 1:34 am
Kodi updated to 18.6
No specific Raspbian changes.
Just update and upgrade the packages has you normally do.*
*Note that this packages are not yet available on Raspberry Pi repos, only on the PiPplware repo, you have to wait a little bit.
aitlamsali
Tue Mar 24, 2020 12:33 am
Hi All;
I have installed Kodi on Raspbian 10 (buster), but when I want to install the PVR Iptv, I search on addons and the list is empty !!
So I can't find and select then install, please tell me what's the problem exactly ?
Thanks !
Rascas
Tue Mar 24, 2020 9:43 am
Hi All;
Thanks !
Please read the first post.
maxipower
Sat Apr 04, 2020 3:46 pm
For those who only use Kodi is it worth upgrading to Kernel 5.4?
Rascas
Sat Apr 04, 2020 3:59 pm
Don't thinks so. Kernel 5.4 is still in testing and from a quick look, performance looks like the same, nothing new.
Sat Apr 04, 2020 5:08 pm
It's too early. It's an alpha kernel, not even beta. My TV uHAT doesn't run so my Kodi testing stalled.
maxipower
Sun Apr 05, 2020 6:28 pm
thank you both… ;)
jools72
Wed Apr 15, 2020 12:49 pm
I tried to follow this thread but I couldn't get x11 to work. Kodi needs some way to output audio and video, and isn't x11 or wayland needed for that? So I ended up with kodi-bin/kodi for debian/2:18.6+dfsg1-1 version instead.
What steps are required to revert to the one that's included in the normal apt get install kodi? Blacklisting some repos I assume?
Is there are good instruction somewhere on how to start kodi-standalone in debian from command line (without desktop)?
I ended up following this guide:
https://github.com/graysky2/kodi-standalone-service
clutch
Thu Apr 16, 2020 10:11 am
Hey,
tnx for guide. Everything went through just fine, however, I'm having problems controlling kodi via kore or yatse app on my android device.
I've noticed, that there's an option missing, called: Allow remote control from applications on other systems.
Web server works just fine...
Any idea?
Rascas
Thu Apr 16, 2020 11:28 am
Hey,
Any idea?
This ? Works fine here.
InvisibleRasta
Fri Apr 17, 2020 10:50 pm
For some reason, the current version of Kodi doesnt provide 2 important files:
/etc/init.d/kodi
/etc/default/kodi
They are required to start kodi on boot.
To fix the problem you need to create /etc/init.d/kodi first:
$ sudo touch /etc/init.d/kodi
The second file to create is /etc/default/kodi.
$ sudo touch /etc/default/kodi
# Set this to 1 to enable startup
ENABLED=1
# The user to run Kodi as
USER=pi
# Adjust niceness of Kodi (decrease for higher priority)
NICE=-5
We are almost done. The last thing is to is to make /etc/default/kodi executable:
$ sudo chmod a+x /etc/init.d/kodi
#! /bin/sh
### BEGIN INIT INFO
# Provides:          kodi
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: XBMC media centre
# Description:       Starts the XBMC media centre in standalone mode
### END INIT INFO
# Author: Michael Gorven <michael@gorven.za.net>
# PATH should only include /usr/* if it runs after the mountnfs.sh script
PATH=/sbin:/usr/sbin:/bin:/usr/bin
DESC="media centre"
NAME=kodi
STARTAS=/usr/bin/kodi-standalone
DAEMON=/bin/sh
DAEMON_ARGS=""
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
GEOMETRY=/var/run/kodi.fbset
# Defaults
ENABLED=0
USER=kodi
NICE=0
# Exit if the package is not installed
[ -x "$STARTAS" ] || exit 0
# Read configuration variable file if it is present
[ -r /etc/default/$NAME ] && . /etc/default/$NAME
# Backwards compatibility with previous package name
[ -r /etc/default/xbmc ] && . /etc/default/xbmc
# Exit if service is not enabled
[ "$ENABLED" = "1" ] || exit 0
# Load the VERBOSE setting and other rcS variables
. /lib/init/vars.sh
# Define LSB log_* functions.
# Depend on lsb-base (>= 3.2-14) to ensure that this file is present
# and status_of_proc is working.
. /lib/lsb/init-functions
# Function that starts the daemon/service
do_start()
        fbset --show | grep geometry | cut -d' ' -f 6- > $GEOMETRY
        # Return
        #   0 if daemon has been started
        #   1 if daemon was already running
        #   2 if daemon could not be started
        start-stop-daemon --start --quiet --pidfile $PIDFILE --user $USER --exec $DAEMON --startas $STARTAS --test > /dev/null \
                || return 1
        start-stop-daemon --start --quiet --pidfile $PIDFILE --nicelevel $NICE --chuid $USER --background --make-pidfile --exec $DAEMON --startas $STARTAS -- \
                $DAEMON_ARGS \
                || return 2
        # Add code here, if necessary, that waits for the process to be ready
        # to handle requests from services started subsequently which depend
        # on this one.  As a last resort, sleep for some time.
        sleep 10
                || return 2
# Function that stops the daemon/service
do_stop()
        # Return
        #   0 if daemon has been stopped
        #   1 if daemon was already stopped
        #   2 if daemon could not be stopped
        #   other if a failure occurred
        start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile $PIDFILE --user $USER --exec $DAEMON --startas $STARTAS
        # Kodi doesn't actually handle signals, so we have to send an RPC request to ask it to exit
        if [ -x /usr/bin/wget ]; then
                wget --post-data '{"jsonrpc": "2.0", "method": "Application.Quit", "params": [], "id": 0}' --header 'Content-Type: application/json' -O /dev/null --quiet http://localhost:8080/jsonrpc
        fi
        # Wait for children to finish too if this is a daemon that forks
        # and if the daemon is only ever run from this initscript.
        # If the above conditions are not satisfied then add some other code
        # that waits for the process to drop all resources that could be
        # needed by services started subsequently.  A last resort is to
        # sleep for some time.
        start-stop-daemon --stop --quiet --retry=0/30/KILL/5 --user $USER --name $NAME.bin
        RETVAL="$?"
        [ "$RETVAL" = 2 ] && return 2
        # Many daemons don't delete their pidfiles when they exit.
        rm -f $PIDFILE
        # Try to fix the display
        VT="$(fgconsole)"
        if [ "$VT" ]; then
                chvt 7
                chvt "$VT"
        fi
        if [ -e $GEOMETRY ]; then
                fbset --geometry $(cat $GEOMETRY)
        fi
        return "$RETVAL"
case "$1" in
  start)
        [ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
        do_start
        case "$?" in
                0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;;
                2) [ "$VERBOSE" != no ] && log_end_msg 1 ;;
        esac
  stop)
        [ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME"
        do_stop
        case "$?" in
        esac
  status)
        status_of_proc "$DAEMON" "$NAME" && exit 0 || exit $?
  restart|force-reload)
        # If the "reload" option is implemented then remove the
        # 'force-reload' alias
        log_daemon_msg "Restarting $DESC" "$NAME"
        do_stop
        case "$?" in
          0|1)
                do_start
                case "$?" in
                        0) log_end_msg 0 ;;
                        1) log_end_msg 1 ;; # Old process is still running
                        *) log_end_msg 1 ;; # Failed to start
                esac
                # Failed to stop
                log_end_msg 1
        esac
        echo "Usage: $SCRIPTNAME {start|stop|status|restart|force-reload}" >&2
        exit 3
esac
and add the init.d script to the startup scripts:
$ sudo update-rc.d kodi defaults
and thats it :)
Rascas
Sat Apr 18, 2020 12:31 am
/etc/init.d/kodi
/etc/default/kodi
ENABLED=1
USER=pi
NICE=-5
#! /bin/sh
### BEGIN INIT INFO
# Provides:          kodi
### END INIT INFO
DESC="media centre"
NAME=kodi
DAEMON=/bin/sh
DAEMON_ARGS=""
# Defaults
ENABLED=0
USER=kodi
NICE=0
. /lib/init/vars.sh
do_start()
        # Return
                || return 1
                $DAEMON_ARGS \
                || return 2
        sleep 10
                || return 2
do_stop()
        # Return
        fi
        RETVAL="$?"
        rm -f $PIDFILE
        VT="$(fgconsole)"
        if [ "$VT" ]; then
                chvt 7
                chvt "$VT"
        fi
        fi
        return "$RETVAL"
case "$1" in
  start)
        do_start
        case "$?" in
        esac
  stop)
        do_stop
        case "$?" in
        esac
  status)
        do_stop
        case "$?" in
          0|1)
                do_start
                case "$?" in
                        0) log_end_msg 0 ;;
                esac
                # Failed to stop
                log_end_msg 1
        esac
        exit 3
esac
and thats it :)
Despite init.d / SysVinit are still supported in Raspbian and other Linux distributions, almost no one uses it anymore, it was replaced by systemd.
ahmadka
Sun Apr 19, 2020 5:38 am
Hi everyone .. This is my first post here!
I've following the first post instructions to install kodi (just kodi for now - no addons yet) on my Raspberry Pi 4 which has Raspbian Buster installed on it. I have done the raspi-config required and recommended changes, and also setup the autostart (without desktop) service.
But despite the above, I get no HDMI output. Yes, I'm using HDMI 0 port (the one closer to the power port).
Can someone help me figure out what's the issue ?
Also if I run "kodi" manually, I get the following output:
pi@ApplePi:~ $ kodi
open /dev/fb0: No such file or directory
failed to export dumb buffer: Permission denied
Failed to create scanout resource
terminate called after throwing an instance of 'std::runtime_error'
  what():  eglSwapBuffers failed
Aborted (core dumped)
Crash report available at /home/pi/kodi_crashlog-20200418_221628.log
[E] Invalid arguments ' '
pi@ApplePi:~ $
I know you'll probably want to see the log file. Can you tell me where that file is located by default ?
Rascas
Sun Apr 19, 2020 10:12 pm
pi@ApplePi:~ $ kodi
pi@ApplePi:~ $
The log is right there on the command output: /home/pi/kodi_crashlog-20200418_221628.log
max11
Wed Apr 22, 2020 4:18 pm
I am running Kodi 18.6 Git 20200310-283bece277 (compiled 2020-03-22).
Installed is Raspbian Buster 4.19.97-v7l+ on a Raspi4 (4GB).
Up until now there were keys on the keyboard like '+' or '-' to increase or decrease the volume .
This somehow disappeared in the last updates... I didn't check if other keys are missing too..
Is there something i missed during the last updates?
regards
max11
Rascas
Wed Apr 22, 2020 4:23 pm
regards
max11
Both "+" and "-" work here. Also F9 and F10.
max11
Wed Apr 22, 2020 6:15 pm
Hi Rascas,
thanks for your fast answer.
F9 and F10 are working here too ... but not + and -
Strange ...
Ahhhhh .... i found my mistake ...
In Raspbian i had selected the correct (german) keyboard ..... but not in Kodi (where it was english).
After changing that now Kodi functions as expected ... please excuse - and continue with your great work on Kodi :)
Regards (and stay healthy)
Max11
Return to “Raspberry Pi OS”
