IpPsar01
Python program (not running in the foreground) needs the keyboard input
Fri Aug 23, 2019 6:56 pm
I have the slideshow application ‘feh’ running in the foreground on the console screen.
The idea is that feh is controlled by a another program (python) running.
This python program reads keyboard input but also processes the return string from eg. Google speech-to-text. As such it instructs feh to move to the next/previous picture (via signal.SIGUSR1), stop feh (signal.SIGTERM) and start a video (using omxplayer), etc..
However… since feh is running on the foreground feh takes the input from the keyboard!
So when the 'a' is pressed on the keyboard I want to close feh and start the default radio channel using omxplayer. Or when the 'v' is pressed i want to start a default video using omxplayer. But feh is catching the keystrokes so nothing happens :-(
It of course works when the shell in which the python program is running is on the foreground having focus.
How can I redirect the console keyboard/keystrokes to my python program and still have feh run in the foreground?
When playing videos (using omxplayer) my python program does get the keystrokes and all works fine.
BTW: the python program is not started in the background using ‘&’. It is the python program that forks feh using:
commando = "feh -Z -F -d -D30 -f " + config.FotoPlaylist
shellprog = subprocess.Popen(commando, shell=True, stdin=subprocess.PIPE, stdout=subprocess.PIPE, stderr=subprocess.PIPE,bufsize=1, preexec_fn=os.setsid)
When I run a ps -ax | grep feh I get two entries (probably due to the 'shell=true'):
1084 ? Ss 0:00 /bin/sh -c feh -Z -F -d -D30 -f /tmp/FehPlaylist
1085 ? S 0:57 feh -Z -F -d -D30 -f /tmp/FehPlaylist
Thsese processes also do not have a TTY assigned. Would that somehow cause this problem?
(changing to call to 'shell=false' gives an error so that is not an option)
Peculiar is that the same command is used to start omxplayer for internet radio and that is linked to a shell:
commando = "omxplayer -b -o local \"%s\"" % audiobestand
shellprog = subprocess.Popen(commando, shell=True, stdin=subprocess.PIPE, stdout=subprocess.PIPE, stderr=subprocess.PIPE,bufsize=0)
'ps -ax | grep omx' gives:
1064 pts/0 S+ 0:00 /bin/sh -c omxplayer -o local http://playerservices.streamtheworld.co ... DIOAAC.aac
1065 pts/0 S+ 0:00 /bin/bash /usr/bin/omxplayer -o local http://playerservices.streamtheworld.co ... DIOAAC.aac
1076 pts/0 Sl+ 1:56 /usr/bin/omxplayer.bin -o local http://playerservices.streamtheworld.co ... DIOAAC.aac
Thanks for any help!
Return to “Raspbian”
