ioscanner
Pi 4 with Raspbian Stretch?
Thu Aug 22, 2019 2:32 am
I have a project I am trying to use a Pi 4 on and it seems Buster is still new and doesn't have the support needed of a few close source projects. I have tried to install Stretch on the Pi 4 but it seems it doesn't work. Is there a way to install Stretch on the Pi 4?
Thanks in advance.
lpsw
Re: Pi 4 with Raspbian Stretch?
Thu Aug 22, 2019 2:49 am
No. The Pi4 requires Buster.
Self-education is, I firmly believe, the only kind of education there is - Isaac Asimov
Imperf3kt
Thu Aug 22, 2019 4:49 am
To be more accurate, the Pi4 needs the bootcode compatible with it to work.
This bootcode is not present in anything except Raspbian Buster and select 3rd party operating systems.
55:55:44:44:4C
52:4C:52:42:41
Thu Aug 22, 2019 9:25 am
Thanks in advance.
You need to tell us what you're trying to install & run. There may be a way to get the missing stuff on Buster.
This is a doctor free zone.
Thu Aug 22, 2019 9:37 am
Thanks in advance.
The OP is trying to use a Auvudea B101 HDMI Capture Device:
https://www.raspberrypi.org/forums/view ... &p=1523299
Retired disgracefully.....
timg236
Thu Aug 22, 2019 10:04 am
For reference, Raspberry Pi4 needs the following files to boot to Linux
  • start4.elf and fixup4.dat (or _cd _x variants)
  • kernel7l.img
  • *.dtb and overlays from bootfs
  • /lib/modules from Linux
So if you take a Stretch image for Pi3 and copy the following files from Buster then it should boot if you disable FKMS in config.txt by commenting out "dtoverlay=vc4-fkms-v3d". The Mesa drivers for V3D will NOT run on Stretch and there is no chance of anyone at RPi spending time on that.
Disclaimer: I've not tried this since some months before launch i.e. when we switched to Buster. This should at least get a Kernel + Linux console running but I wouldn't be surprised if you hit issues with userland.
i.e. If you really really really want to run stretch then the above is a good starting point but unless you are happy debugging via serial console and hacking userland stuff then I wouldn't bother :)
Imperf3kt
Thu Aug 22, 2019 10:51 pm
Are you sure? I've been using that config setting since Raspbian Jessie for one specific program that will not run without it.
Been working (mostly) fine since 2016
55:55:44:44:4C
52:4C:52:42:41
ShiftPlusOne
Thu Aug 22, 2019 11:37 pm
There's a distinction between V3D and VC4, in Mesa terms. VC4 is the gallium driver for pi =<3 and V3D is the driver for pi 4. I don't think there's a V3D driver in the stretch version of Mesa.
andrum99
Wed Sep 04, 2019 9:37 am
It would have been nice if they had used a different dtoverlay for Pi 4 to avoid this confusion.
fanoush
Wed Sep 04, 2019 11:31 am
I am running the old stretch I used before in a chroot on pi4. With schroot it even shares home directory and other configs so it is relatively painless. I currently use it to launch pyhoca-gui (remote access to x2go servers) which seems to be broken in Buster for me. So that is another solution to run old stuff on pi4.
Return to “Raspbian”
