1. In an ssh session, not running a GUI:
$ sudo amixer cset numid=3 1
numid=3,iface=MIXER,name='PCM Playback Route'
; type=INTEGER,access=rw------,values=1,min=0,max=2,step=0
: values=1
$ sudo amixer cset numid=3 2
: values=2Code: Select all
$ sudo amixer cget numid=3
: values=2Mute/unmute works ok with numid=2 1 or 0. So that hasn't changed.
Volume control is broken now as well.
$ sudo amixer cset numid=1 -- -400
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=1,min=-10239,max=400,step=0
: values=-10239
| dBscale-min=-102.39dB,step=0.01dB,mute=1Code: Select all
$ sudo amixer cset numid=1 -- 100
: values=-10239
$ sudo amixer cget numid=1
: values=-10239
$ sudo amixer -v
amixer version 1.0.252. Running in LXDE in a VNC session.
So far so good, when I start a VNC session and use the GUI over VNC, opening up LXTerminal and typing exactly the same commands in gies me something different:
Clinet is not authorized to connect to Serverxcb_connection_has_error() returned true
: values=1
/dev/snd is root:root but the contents are root:audio. My user, pi, is a member of the audio group, and has been able to run these commands previously.
Sorry it's so long, better to have too much info than not enough? Appreciate any help.
Thanks.
Cheers,
Norm.
