munocat
Help wanted to Connecting VT320 to a RPi Zero
Thu Jul 25, 2019 1:29 am
I am trying to connect a vt320 to the USB via a ftdi cable on ttyUSB0
I am running the last edit version of Raspbain.
hippy
Re: Help wanted to Connecting VT320 to a RPi Zero
Thu Jul 25, 2019 9:29 am
What part of what you are doing do you need help with ?
Assuming the VT320 is a serially connected CRT terminal, it may be that it requires an RS232C connection. Your FTDI cable may only produce TTL voltages or have the wrong polarity.
munocat
Thu Jul 25, 2019 3:46 pm
I was connecting to the ftdi using serial. I need help with configuring the pi
B.Goode
Thu Jul 25, 2019 4:13 pm
If you have a usb-to-serial adapter plugged into your RPi, what configuration do you imagine might be required on the RPi?
munocat
Thu Jul 25, 2019 6:24 pm
So I can log in via with the terminal
B.Goode
Thu Jul 25, 2019 6:28 pm
Similar recent thread here may help: https://www.raspberrypi.org/forums/view ... 8&t=235680
munocat
Thu Jul 25, 2019 6:34 pm
I am a noob, and that does not show the steps
hippy
Thu Jul 25, 2019 6:52 pm
From what I can remember you need to run something like this on the Pi -
getty -L 9600 ttyUSB0 vt320
Google might turn up something useful on "getty"
munocat
Thu Jul 25, 2019 7:01 pm
Thanks for suggesting, but still no luck
munocat
Thu Jul 25, 2019 9:39 pm
I have it working using this
systemctl start [email protected]
Does anyone know how to get the arrow and function keys to work?
dgordon42
Sat Jul 27, 2019 9:20 pm
On your VT320 Terminal, what is the output from:
echo $TERM
The default terminal is the VT100, some VT320 features may not work unless the system knows you are using a VT320.
I have a VT320 terminal which I also connect to my Pi's using a Serial to USB converter. I found it was very usefull to be able to plug into the Pi's USB port and get access to a command line during the early days of Pi WiFi which was not very reliable, my Pi's run headless.
It took a bit of setting up to get it to work, and even more setting up to get the numeric keypad to work in Vim, but that's another story.
Dave.
Return to “Raspbian”
