ksharindam
Compress option in PCmanFM not working with xarchiver
Fri Jul 12, 2019 4:11 am
I am trying to Compress a file in pcmanfm by right clicking over a file. But clicking compress is not working.
xarchiver is used as default archiver in pcmanfm.
the output in terminal is
xarchiver: Unknown option --add-to
But the correct option should be --compress
This bug should be fixed.
Is xarchiver used in Raspbian as default archiver in pcmanfm ?
sail1943
Re: Compress option in PCmanFM not working with xarchiver
Wed Jul 31, 2019 3:39 am
any workaround for this problem ?
ksharindam
Wed Jul 31, 2019 7:08 am
have to edit the source code and change the command
xarchiver --add-to %F
to
xarchiver  --compress %F
But this should be done by the package maintainers.
I have switched to file-roller (though it has less features).
spl23
Thu Aug 01, 2019 11:54 am
No need to change source code - just go into /usr/share/libfm/archivers.list and make the change suggested above. I'll build a fixed package and push it to the repo at some point, but for now editing that file will work.
ksharindam
Thu Aug 01, 2019 1:27 pm
Ok, thank you so much.
sail1943
Sat Aug 03, 2019 6:17 am
Tried and it worked. Thank you both.
Return to “Raspberry Pi OS”
