pi@raspberrypi:~$ command-not-found vim
Could not find the database of available applications, run update-command-not-found as root to fix this
Sorry, command-not-found has crashed! Please file a bug report at:
http://www.debian.org/Bugs/Reporting
Please include the following information with the report:
command-not-found version: 0.3
Python version: 3.7.3 final 0
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
Exception information:
local variable 'cnf' referenced before assignment
File "/usr/share/command-not-found/CommandNotFound/util.py", line 23, in crash_guard
callback()
File "/usr/bin/command-not-found", line 93, in main
if not cnf.advise(args[0], options.ignore_installed) and not options.no_failure_msg:
UnboundLocalError: local variable 'cnf' referenced before assignment
pi@raspberrypi:~$ sudo update-command-not-found
File "/usr/sbin/update-command-not-found", line 26, in <module>
col.create(db)
File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 94, in create
self._fill_commands(con)
File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 132, in _fill_commands
self._parse_single_contents_file(con, f, fp.stdout)
File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 271, in _parse_single_contents_file
priority = component_priorities[component]
KeyError: 'rpi'
