beta-tester
Raspbian Buster Lite has iptables but not nftables
Thu Jul 11, 2019 6:24 am
hello,
i just flashed the official "2019-06-20-raspbian-buster-lite.zip" to my SD card and plugged it to my RPi Zero.
i know Debian Buster is using by default nftables instead of iptables.
while installing and configuring things (dnsmasq, samba, lighttpd, wireguard) i realized,
that on my Raspbial Buster Lite image only iptables is installed and active.
there is no nftables installed, because i get this:
:~ $ sudo nft --help
sudo: nft: command not found
:~ $ sudo dpkg -l | grep -E 'nftables|iptables'
ii  iptables                       1.8.2-4                     armhf        administration tools for packet filtering and NAT
ii  libnftnl11:armhf               1.1.2-2                     armhf        Netfilter nftables userspace API library
:~ $ sudo iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
i didn't tried the other versions of Raspbian Buster (full and the normal one),
but this comment let me think that on Raspbian Buster nftables is installed and active by defalt...
Is been iptables substituted by nftables in Rasbpian Buster?
so is it a mistake, that on the light version is no nftables installed?
can i install nftables simply via sudo apt install nftables, and everything is good now - iptables is deactivated and nftables is active from now on...
or are there more things to do?
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
Re: Raspbian Buster Lite has iptables but not nftables
Thu Jul 11, 2019 6:48 am
hello,
Already an open recent discussion here:
https://www.raspberrypi.org/forums/view ... 9&t=244256
RPi 4B 4GB (SSD Boot)..
beta-tester
Thu Jul 11, 2019 7:09 am
that's what i told, that there is a comment...
but it does not explain, how i can get nft commands working, because nftables (at least the nft command) is not (fully) installed on my Raspbian Buster Lite image.
it looks like it is only an issue of Raspbian Buster Lite. the normal Raspbian Buster seems to have the nft command (nftables package) installed.
can i install nftables packet by hand by simply using sudo apt install nftables and everything is working as it should?
RaTTuS
Contact: Twitter YouTube
Thu Jul 11, 2019 7:37 am
worked for me on lite , not that I've used it but it installs
Covfefe
beta-tester
Thu Jul 11, 2019 10:32 am
thank you...
i installed it but i am still not sure if this was enough,
because i still get the old output from sudo iptables -L,
while in other comments it is reported that it is giving iptables: Operation not supported on other Raspbian Buster installations.
how can i disable the old iptables behavior so that my Raspbian Buster Lite is 100% in line with the nftables configuration as of Raspbian Buster Full or its normal version?
RaTTuS
Thu Jul 11, 2019 10:37 am
sudo apt remove iptables
Covfefe
beta-tester
Thu Jul 11, 2019 11:00 am
:shock: :oops: :mrgreen:
yes... and no...
yes, i can remove it... stupid me...
no, then i don't get the same behavior of the Raspbian Buster Full...
because on Raspbian Buster Full it is reported to get:
but i now get on Raspbian Buster Lite + nftables installed - iptables removed:
iptables: command not found
so, where is the difference in configuration?
is there a creation/configuration script available, to see, how the official Raspbian Buster Full and how Raspbian Buster Lite were configured?
RaTTuS
Thu Jul 11, 2019 11:05 am
I have to say "No Idea"
and wait for someone with more knowledge
Covfefe
UF_DoC
Thu Feb 27, 2020 10:15 am
Buster Image released on 2020-02-13 even has the same issue (Raspbian Buster with desktop).
It would be nice to get clarity on which versions should have nftables by default and which do not.
secondly as the op has been asking, What is the process to properly configure nftables over iptables.
Thanks.
UF_DoC
Thu Feb 27, 2020 10:29 am
On closer inspection it appears that the Buster image has two commands:
iptables-legacy and iptables-nft
$ iptables --version
iptables v1.8.2 (nf_tables)
$ iptables-legacy --version
iptables v1.8.2 (legacy)
$ iptables-nft --version
The iptables command is sym-linked via /etc/alternatives/iptables to iptables-nft
So it does appear the even though the nft specific command does not exist, nftables is the default.
Regards,
Return to “Raspberry Pi OS”
