Buster's installed packages in a list
Posted: Sun Jun 30, 2019 9:26 pm
by jarvism
In case it's helpful for anyone here, I have lists of all of the packages (and versions) installed on the 2019-06-20 releases of the buster, buster-lite and buster-full images here.
these are essentially the outputs of:
apt list --installed
This was run direct on mounted images themselves so is essentially the equivalent of running it on a fresh install before any updates.
I did this so I can work out the differences between each case, and also the differences between these and my current stretch install so I can preempt any issues before I upgrade... in theory...
Re: Buster's installed packages in a list
Posted: Fri Jul 12, 2019 5:59 pm
by KitchM
And the results are.......????
Posted: Sat Jul 13, 2019 9:43 am
by DougieLawson
... exactly the same as if you run it on your Buster system.
Posted: Mon Aug 05, 2019 3:03 pm
by KitchM
Are there not three versions: Full, Desktop and Lite?
Posted: Mon Aug 05, 2019 5:11 pm
by B.Goode
Yes.
Posted: Mon Aug 05, 2019 5:48 pm
by KitchM
Then I could not find those three groups.
Posted: Mon Aug 05, 2019 6:08 pm
by Andyroo
You need to install each from https://www.raspberrypi.org/downloads/raspbian/
Posted: Mon Aug 05, 2019 6:32 pm
by ShiftPlusOne
Posted: Mon Aug 05, 2019 6:38 pm
by KitchM
Posted: Mon Aug 05, 2019 8:05 pm
by B.Goode
Quite so. But likely to be of academic/reference value only, since that June release of Raspbian Buster was superceded by a subsequent release in July 2019.
(Perhaps it is significant that the word here is a clickable link leading to https://gist.github.com/jarvisms/6d3edb ... 2bd8c7c5fb)
Posted: Mon Aug 05, 2019 8:55 pm
by KitchM
Yeah, it took me a minute to find the word, here, at first. However, the issue is that the names of the groups in the listing are not matching the names of the actual Raspbian packages.
Also, even if outdated to some degree, the basic programs used in each group can be significant in understanding the mindset of the packagers.
