Re: FreeCAD on PI4 and Raspbian Buster.
Good Morning
I’ve tried Yesterday Scruss’s solution to build from Github repo and work’s perfectly, so far Freecad runs smoothly on the pi4!
I guess some more development will make installable just via terminal in the future
one hint for users in case they’ve already done some trials is to remove first all previously installed Freecad packages by add-remove programs
does anyone knows how to add a Freecad launcher on the bar or to Desktop instead of launching it via bin all the time?
Thank you, and happy 3D modelling
Hi - I'll throw my hat into the ring on this. I have a pi4 (4GB) being used to run PrusaSlicer and FreeCAD (Old Python & QT). PrusaSlicer now has a prebuilt binary for the pi4. It installs and runs fine. As for building FreeCAD from source against Python3 and QT5, no dice yet. Please see below:
Coin warning in cc_glglue_instance(): Error when setting up the GL context. This can happen if there is no current context, or if the context has been set up incorrectly.
Program received signal SIGSEGV, Segmentation fault.
#0 /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0xb194b120]
Still having issues with selecting NEW. Would be really nice to get this problem solved! FreeCAD makes a nice companion to PrusaSlicer for modeling and printing. I'd be happy to help with building and testing to move this along. Need someone with good graphics library knowledge to guide me a bit. Any updates on this? Many thanks.
Best - Muniac (aka Scott)
There is a version of Cura for Pis too. The select face to put on print bed button is the only thing that I noticed missing.
I got a working compile following the instructions from here:
https://scruss.com/blog/2020/02/16/free ... erry-pi-4/
A few things I would change:
1. make j-8 (towards the bottom, sets max # of threads, more=faster)
2. make install (after you have tested it to make sure it runs ok)
3. alias freecad='FreeCAD' (after you got it working, add it to your .bashrc to make it pernament)
4. instead of downloading the zip, clone it, but I do not know exactly how that is set up.
5. IF you are going to be keeping current(rebuilding often) then look at ccache it speeds things up.
It is a good 90 minutes of compile time and it with heat you by to the Max. The good news is that my passively cooled Pi4 only hit 52C in a 72F room. Not sure what the coin things does, but so far my version runs fine without it.
Edit: j-8 errored out at around 35%, but it was screaming up to that point. Maybe j-6
For the .19 version(currently):
git clone https://github.com/FreeCAD/FreeCAD.git
Another thumbs up for Scruss’s build: it works fine for me (certainly the crash on file open/new disappears) and his/her build instructions are to the point. I've opened all example files and played around with them a bit.
Setting up the build environment took me 10mins using copy paste!
Pi4-4 with passive cooling, fake openGL driver. Build time 95 mins. Although the little beast constantly ran at 100% cpu activity the temperature remained below 65ºC, so cpu speed remained at 1,5MHz.
This means lot's of python2 and Qt4 libraries on the system, but hei, it's great to have FreeCAD running for now...
Thanks!
Thanks!
I'm glad this is till working out for people.I don't really use FreeCAD too much, as OpenSCAD is how I think. (Sad, isn't it?)
A couple of responses to Brad Q's suggestions, which I do appreciate, but:
It would be -j8, but -j4 works and doesn't crash.
By downloading the zip, you're getting a known release: 0.18.4. By doing a clone, you get 0.19-pre-whatever. Known releases tend to be more stable, and I know that — at one point in time, at least — this version of the code compiled under Raspbian. If someone knows they need a version newer than 0.18.4, then they're on their own for building it. No amount of following my guide will help them.4. instead of downloading the zip, clone it, but I do not know exactly how that is set up.
‘Remember the Golden Rule of Selling: “Do not resort to violence.”’ — McGlashan.
Pronouns: he/him
Pronouns: he/him
Hi there,
JFYI Freecad 18.4 PY3/Qt5 works on RPI4 with Ubuntu 20.04LTS: https://forum.freecadweb.org/viewtopic. ... 14#p395614
Now ones could compare libs between Ubuntu 20.04LTS and Raspbian Buster to locate maybe the origine of the segfault issue with Raspbian.
As I am concerned I would prefer to use FreeCAD with Raspbian, any help still appreciated to track the bug or find a fix by updating some libs maybe
The build I linked to is Python 2, so there's your difference right there. The rest of the build differences would be too much work to consider, especially since the 2→3 change is monumental.
Pronouns: he/him
Pronouns: he/him
I'm not sure to see your point, AFAIK on RPI4 with Raspbian FreeCAD works with PY2or3/Qt4, and crashes with PY2or3/Qt5.
But it work with PY3/Qt5 with Ubuntu. So, maybe this statement is a way to locate the issue with Raspbian don't you think?
Someone else — not me — can do this
Pronouns: he/him
Pronouns: he/him
Hi there, JFYI FreeCAD 0.19 compiled with Py3/Qt5 works on RPI4 with Ubuntu 20.04LTS.
See here https://forum.freecadweb.org/viewtopic. ... 60#p396635
I hope someday that will be ok with Raspbian too, with no segfault issue....
Enjoy FreeCAD 0.19 on RPI4
Cools, thanks for the guides.
I will try this on Gentoo64 as well.
What version Mesa are these using?
I'm dancing on Rainbows.
ubuntu@ubuntu:~$ glxinfo | grep rendering
direct rendering: Yes
ubuntu@ubuntu:~$ glxinfo | grep OpenGL
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: llvmpipe (LLVM 9.0.1, 128 bits)
OpenGL core profile version string: 3.3 (Core Profile) Mesa 20.0.4
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.1 Mesa 20.0.4
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 20.0.4
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
OpenGL ES profile extensions:
That's maybe also why there is not segfault issue with FreeCAD Py3/Qt5 on Ubuntu 20.04?
I wonder if it's possible to switch to llvmpipe on raspbian and if-so what impact that has on freecad.
Is llvmpipe software rendering?
AFAIK yes it is. To continue topic about FreeCAD on Ubuntu 20.04 see here viewtopic.php?f=131&t=274059&p=1660615& ... d#p1659911
OpenGL vendor string: Broadcom
OpenGL renderer string: V3D 4.2
OpenGL version string: 2.1 Mesa 19.3.2
OpenGL shading language version string: 1.20
sudo apt-get install freecad
The fun begins now, only used 16 and 17, 18 is new to me.
Lots of interesting plugins I never noticed before.
Pi4 8GB + SSD (and USB3 case) ordered - all in preparation (and anticipation) of switching to 64bit Raspbian!
Thanks for letting us know. I was just thinking of needing to recompile it again as I did it for regular (32bit) Raspbian.
Yep I came here to find the link for compiling, then I thought I would try an install.Thanks for letting us know. I was just thinking of needing to recompile it again as I did it for regular (32bit) Raspbian.
I noticed Blender was pre-installed, maybe???
OpenSCAD, Wings3D, Inkscape... yep all working.
Bonus, is it is now booting and running from a 256GB SSD, but USB2 only, USB3 has issues with my USB to SATA chips.
Anyway 0.18 has a sheet metal plugin, model Cybertrucks?
I was looking for a CAD program to try making Cyberbots.
Got some stainless, cutters and bender in the basement.
Going to be fun as lockdown is at least till late August.
That's great! Blender? Wow - I never got to learn how to use it - but did use to occasionally to convert 3d objects from one format to another (lately for LibGDX WebGL/OpenGL project for Raspberry Pi!Gavinmc42 wrote:Yep I came here to find the link for compiling, then I thought I would try an install.
That's not really that important to me: I can always spare some not quite working but /boot partition is OK SD card to boot up things. I wouldn't switch from this RPi (I am typing this on) from 3-4Gbit/s SSD to 480Mbit/s again. It makes quite a difference when system is so responsive (due to fast I/O).Gavinmc42 wrote:Bonus, is it is now booting and running from a 256GB SSD, but USB2 only, USB3 has issues with my USB to SATA chips.
Hm. What size? Scale or not?Gavinmc42 wrote: Anyway 0.18 has a sheet metal plugin, model Cybertrucks?
I know what yo meanGavinmc42 wrote: Going to be fun as lockdown is at least till late August.
Back to FreeCAD - oddly enough, FreeCAD works (my compiled version on ordinary Raspbian and Pi4) better than on my MBP.
Blender for Artists has an easier to use interface.
viewtopic.php?f=54&t=249831
Will try it on this new Raspberry OS, now have plenty of SSD space.
Once Vulkan is working we can upgrade to the newest Vulkan Blender?
I have been spending lots of time trying to see how well a Pi4 can be used for enabling the Fourth Industrial revolution.
Looking pretty good now, 3D metal printers now need to make it to the desktop.
Inkscape has G-code output. wounder if there is a CAM plugin for FreeCAD?
Edit yep CAM stuff for FreeCAD.
Watching a tutorial on Freetube.
https://freetubeapp.io/#download
Don't think lockdown will go on long enough to learn everything on FreeCAD now, maybe that second wave can extend it?
What machines do I need to use/get to replace everything made in China?
Just for fun I tried to compile FreeCAD version 0.19 from git on the beta software Raspi OS 64-bit based on Debian.
These dependencies were from the install instructions.
This will install the latest source code from Github.
Look for summary report at the end, It will say...
-- Configuring done
-- Generating done
or an error.
If error scroll up and find whats wrong.
This step takes an hour or two. It will give you a percentage of complete while it scrolls.
I aimed an external fan at the raspberry pi because the temperature warning came on.
It worked for me. Now how do you make an Appimage for Aarch64?
Cheers
sudo apt install build-essential libtool lsb-release cmake cmake-gui cmake-curses-gui libboost-date-time-dev libboost-dev libboost-filesystem-dev libboost-graph-dev libboost-iostreams-dev libboost-program-options-dev libboost-python-dev libboost-regex-dev libboost-serialization-dev libboost-signals-dev libboost-thread-dev libcoin-dev libeigen3-dev libgts-bin libgts-dev libkdtree++-dev libmedc-dev libocct-data-exchange-dev libocct-ocaf-dev libocct-visualization-dev libopencv-dev libproj-dev libpyside2-dev libqt5opengl5-dev libqt5svg5-dev libqt5webkit5-dev libqt5x11extras5-dev libqt5xmlpatterns5-dev libshiboken2-dev libspnav-dev libvtk7-dev libx11-dev libxerces-c-dev libzipios++-dev occt-draw pyside2-tools python3-dev python3-matplotlib python3-pivy python3-ply python3-pyside2.qtcore python3-pyside2.qtgui python3-pyside2.qtsvg python3-pyside2.qtwidgets python3-pyside2uic qtbase5-dev qttools5-dev swig libsimage-dev doxygen libcoin-doc libspnav-dev
git clone https://github.com/FreeCAD/FreeCAD.git freecad-source
cd freecad-source
mkdir build
cd build
cmake .. -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3
-- Configuring done
-- Generating done
or an error.
make -j$(nproc)
cd bin
./FreeCAD
OS: Debian GNU/Linux 10 (buster) (LXDE/LXDE-pi)
Word size of OS: 64-bit
Word size of FreeCAD: 64-bit
Version: 0.19.21506 (Git)
Build type: Unknown
Branch: master
Hash: ac4196fb66a34cc4f246afa3c5858e6d4b821875
Python version: 3.7.3
Qt version: 5.11.3
Coin version: 4.0.0a
OCC version: 7.3.0
Locale: English/UnitedStates (en_US)
Cheers
Sheet Metal workbench loaded
During initialization the error "inconsistent use of tabs and spaces in indentation (<string>, line 52)" occurred in /home/pi/.FreeCAD/Mod/cura_engine/InitGui.py
Please look into the log file for further information
connect failed: No such file or directory
Now have two versions 0.18 and 0.19
Might give your instructions a go in Gentoo64 once it is using kernel 5.x.
Humm, guys you say FreeCAD works when compiling with Qt5 and PY3 on 64B OS, no more segfault issue? Right? Interesting!
Thank you guys for the information, I'm going to install 64B OS and compile FC.
@Gavinmc42: IMHO the error you get with Cura workbench is due to PY3, I guess Cura workbench is still PY2.
please help i get the following error..
#0 /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0xb179e120]
how do i fix it?
how do i fix it?
