Andyroo
Re: Suggestion: Reporting ip address in /boot/boot.ip
Fri Jun 28, 2019 9:18 pm
Just look on the router / dhcp server?
Need Pi spray - these things are breeding in my house...
rin67630
Fri Jun 28, 2019 9:21 pm
thagrol wrote:
Fri Jun 28, 2019 8:48 pm
99.9% is a little strong, it's unlikely that you have experience of that many routers.
OK my realm is the typical noob's home*, who never changed the defaults of his router, does not know how to do it, is even unable to remember the routers credentials and has got a very max of 6-7 devices connected. Else you haven't got any problem and can look at the DHCP report.
*I am installing residential environmental data loggers.
Ernst
Fri Jun 28, 2019 9:33 pm
What about a school environment ? That is where there can be much more devices and the pupils do not have a access to the DHCP report, most likely they do not even know what DHCP means.
The road to insanity is paved with static ip addresses
Andyroo
Fri Jun 28, 2019 9:38 pm
knute wrote:
Fri Jun 28, 2019 9:14 pm
I do a lot of development on a Windows 10 machine. I use it to burn my SD cards. I've installed Bonjour but for the life of me can't get it to find other computers on the network with their hostname.
Can you find other computers by name from a Pi or other computers on the network?
Newer updates of Windows 10 have had a few fixes of the inbuilt mDNS support I understand so it may be worth trying without Bonjour :lol: The other thing to test is with the devices on the same physical segment of your LAN - either in the same Ethernet switch or WiFi SSID and AP. Going by the issues with Plus-net it would not surprise me is other cheaper home kit has issues.
Andyroo
Fri Jun 28, 2019 9:39 pm
I would hope that the class tutor would know how to find the Pi info or any tech support the school has. Given how regulated the local schools are around here then there is no way these would be used with a whole lot of work :lol:
thagrol
Fri Jun 28, 2019 9:53 pm
Fair enough. You've probably got experience of more models of domestic routers than I have. You'll forgive my challenge, I hope, it's my experience that many folks who make claims about 99.9% of X actualy have experience of less than 1% of X (and yes I know I'm doing the same thing by quoting stastics without evidence ;))
This space unintentionally left blank.
thagrol
Fri Jun 28, 2019 9:55 pm
Back in my day you were lucky if the class tutor could find the on switch.
Though to be fair computers have changed somewhat since then.
knute
Fri Jun 28, 2019 10:22 pm
No problem using a linux computer to find them. I just tried it with my Win 10 machine that is up to date and it works. Straight ping hostname.local returns the IPv6 address but using the -4 option I get the IPv4 address. Thanks for getting me to try it again! I can't tell you how much time I spent trying to get that to work.
Andyroo
Fri Jun 28, 2019 11:11 pm
My class tutor (I'm 57) worked at Rolls Royce using computers to design turbo fans and introduced me to computing using a dial-up terminal to the council mainframe - maybe I was lucky :D
HawaiianPi
Fri Jun 28, 2019 11:12 pm
There was another recent thread on finding the IP. Might want to check that out.
https://www.raspberrypi.org/forums/view ... 3&t=241894
Andyroo
Fri Jun 28, 2019 11:13 pm
Do not thank me - another poster on here pointed out that Windows has had problems but they got sorted with a fix pack and I remembered it :lol: I'm happy with my dear old Mac and Linux laptop (and a few Pi machines of course).
Sat Jun 29, 2019 8:04 am
The easiest way to get a file written is this one liner in /etc/rc.local
ip addr show > /boot/boot.ip
Assuming the DHCP lease time is longer than ten minutes you should be guaranteed to get the same IP address on a reboot.
If you want the IP address mailed use
ip addr show | mail -s "IP Address" [email protected]
You'll get something like
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether fc:b4:e6:bf:ae:70 brd ff:ff:ff:ff:ff:ff
    inet 192.168.3.14/24 brd 192.168.3.255 scope global wlxfcb4e6bfae70
    inet6 fd00:llll:llll:llll:feb4:e6ff:febf:ae70/64 scope global mngtmpaddr noprefixroute dynamic
       valid_lft 296sec preferred_lft 116sec
    inet6 2002:pppp:pppp:pppp:feb4:e6ff:febf:ae70/64 scope global mngtmpaddr noprefixroute dynamic
    inet6 fe80::feb4:e6ff:febf:ae70/64 scope link
delivered to your GMail spam folder.
This is a doctor free zone.
rin67630
Sat Jun 29, 2019 1:33 pm
You'll get something like [...] delivered to your GMail spam folder.
Not that simple! You need first to install and configure SMTP Mail
sudo apt-get install ssmtp
sudo apt-get install mailutils
Now edit the SSMTP configuration file
sudo nano /etc/ssmtp/ssmtp.conf
It needs to include this
root=postmaster
mailhub=smtp.gmail.com:587
hostname=raspberrypi
[email protected]
AuthPass=TheGmailPassword
FromLineOverride=YES
UseSTARTTLS=YES
Save, exit and test Dougies code, praying that GMail will not block your IPv6
Return to “Raspbian”
