Double L
Re: STICKY: Raspbian 'Buster' 2019-06-20 / 07-10
Thu Aug 29, 2019 9:48 pm
Thank you for the tip :)
But I am still curious about what the update might contain, is there anywhere one can see a change log? :geek:
wpballa1
Mon Sep 02, 2019 10:05 pm
This isn't quite a bug... In order to fulfill being a desktop computer replacement, printing is required. I've been using HPLIP on my 3+ quite successfully to use our wireless HP printer, but the add/remove software HPLIP doesn't support Buster (Version 3.18.12). HPLIP has now released a version that does work with Buster (3.19.8) but it won't install manually on a model 4, failing in the make despite many attempts to work around the problem. Any idea when the updated version or HPLIP will be available via the add/remove software?
BogoMax
Fri Sep 13, 2019 2:29 pm
I second wpballa1's request. It's been frustrating trying to get HPLIP to install. I get an error message about Debian10.1 not being supported.
Did I mention that I love my Raspberry Pi(s) :D. Amazing power from a tiny device.
wally333
Mon Oct 14, 2019 6:49 pm
fruitoftheloom wrote:
Thu Aug 29, 2019 6:22 pm
sudo apt update
sudo apt full-upgrade
sudo reboot
full-upgrade? I've not seen this mentioned before. How is it different from dist-upgrade which I've always seen mentioned and have been using.
Mon Oct 14, 2019 6:51 pm
dist-upgrade and full-upgrade are synonymous.
Mon Oct 14, 2019 7:15 pm
sudo apt update
sudo reboot
http://manpages.ubuntu.com/manpages/xen ... apt.8.html
https://linux.die.net/man/8/apt-get
RPi 4B 4GB (SSD Boot)..
ChasTech
Mon Oct 21, 2019 5:33 am
Didn't realise that this had already been released three months ago! I remember when Jessie was brand new :D
Is there a 64-bit version for the Pi 4, especially since the Pi 4 4GB variant will likely run faster if it has a 64-bit OS to work with?
If apples give you apple pie, bananas give you banana pie, pears give you pear pie, and cherries give you cherry pie, then what do raspberries give you?
A Raspberry Pi :lol:
mahjongg
Mon Oct 21, 2019 9:06 am
Its a common misunderstanding that a 64-biit version will runs significantly faster. This is not true, the speed difference is insignificant.
there are unofficial 64-bit releases you may try, but they are not as well supported as Raspbian.
As long as the RPF still sells hardware that only can run 32-bit its unlikely they will switch to 64-bit.
ChasTech
Mon Oct 21, 2019 2:45 pm
Well to be fair Raspbian was only made because Debian armhf didn't support the original Pi's ARMv6 architecture but armel didn't utilise it to its maximum capability. Debian arm64, however, is compatible with the Pi 3 and 4's ARMv8 processors and with u-boot to emulate UEFI and GRUB2 as a EFI bootloader, not many changes should really be required to get Debian arm64 running on 64-bit Pi's, but all the packages are compatible with the Pi 3 and 4 provided it is running Debian, so 64-bit Raspbian would surely just be unnecessary because of Debian.
rpdom
Mon Oct 21, 2019 4:17 pm
None of that fancy boot stuff should be required. The 64-bit kernel already works with the current bootloader.
The things that would need upgrading to 64-bit are all the Pi specific/modified packages that use things the standard Debian releases don't support yet.
Unreadable squiggle
maxmars
Mon Dec 09, 2019 11:50 am
Add another voice to the choir.. I've tried to manually install the latest HPLIP from sources but after a ton of succesfully compiled sources it complains about not finding some pre-built binaries to go with them. I'm guessing the problem is with the architecture.
Thanks to anyone looking into this or even only considering it.
Mon Dec 09, 2019 12:46 pm
First and foremost you should always try to install software from the Raspbian Buster repositories, and have responded to your other post:
https://www.raspberrypi.org/forums/view ... 6#p1578126
maxmars
Mon Dec 09, 2019 4:43 pm
I admit doing this because I have two RPI 4b boxes, one with Buster and another with Gentoo 64bit.
The compile-from-sources solution would let me kill two birds with a stone.
But I'm not greedy, having one box able to print is enough. I'll try the suggestion from the other thread asap.
Thanks again
Mon Dec 09, 2019 4:55 pm
Thanks again
This whole post is for Raspberry Buster a Debian based Operating System.
Nothing Gentoo related which is a completely differing Operating System:
https://www.raspberrypi.org/forums/viewforum.php?f=54
patient2
Tue Dec 10, 2019 1:56 pm
Could you kindly ask why the Raspbian (.zip) images are not widely distributed in different mirrors?
Everytime it downloads from:
https://downloads.raspberrypi.org/raspb ... buster.zip
Only other place I found was a ftp.jaist.ac.jp server?
Are there any trademarks or other stuff involved?
Many thanks
bensimmo
Thu Dec 19, 2019 3:51 pm
Many thanks
They use the torrent for that purpose.
Cyk
Tue Dec 24, 2019 11:53 am
Hi !
I'm trying to build raspbian , using a raspbian lite,
I can't succesfully clone it.
Please tel me I'm posting it in the wrong place, or if i miss some basics,
i'm a noob i coud have miss some step.
this is the git output:
git clone https://github.com/raspberrypi/linux --depth 1
Cloning into 'linux'...
remote: Enumerating objects: 66199, done.
remote: Counting objects: 100% (66199/66199), done.
remote: Compressing objects: 100% (61617/61617), done.
remote: Total 66199 (delta 5089), reused 17433 (delta 3657), pack-reused 0
Receiving objects: 100% (66199/66199), 177.85 MiB | 176.00 KiB/s, done.
error: inflate: data stream error (incorrect header check)
fatal: serious inflate inconsistency
fatal: index-pack failed
panamavibes
Contact: Website Facebook Google+ Twitter
Fri Apr 24, 2020 5:24 pm
I have a Raspberry Pi 2 Model B with only FireFox ESR as extra package I believe, having removed Wolfram and Mathematica prior to upgrading from wheezy to jessie to stretch just last week.
Originally the DF command showed 6.2 GB available on my 8 GB SD card and it was using only 2.7 GB. After the upgrade to stretch and removal of the big useless packages, I ended up with an almost full SD Card (5.7 GB of 6.2 GB).
Would it be possible (both feasable and practical) to upgrade my Pi 2 model B to Buster? Now that I actually want to do something with it the card is almost full and has almost nothing extra. Input welcome.
Facebook: PanamaVibes
Instagram: PanamaVibes
The original PanamaVibes since the early 2000's, not the one that had no creativity to make their own name.
bensimmo
Fri Apr 24, 2020 6:44 pm
A fresh install?
yes.
or get hold of another card, do a new fresh install on that and you can always go back to your old one if needed to get something.
rpint
Sat May 30, 2020 8:06 am
Is there a specific reason why a number of packages do not have binaries? Particularly baffling to me is stuff like e.g. gemrb, where the *-data binaries are available, but the main packages are not, even though both must have been built from the same source package.
mmhere
whence change log affecting apt-get full-upgrade?
Sat Jun 20, 2020 9:15 pm
I preflighted a full-upgrade...
$ sudo apt-get update |& tee -a /tmp/update.log
$ sudo apt-get -s full-upgrade
...to see what would be gotten today; these were proposed--
  libfm-data libfm-extra4 libfm-gtk-data libfm-gtk4 libfm-modules libfm4 libvlc-bin libvlc5 libvlccore9
  lxpanel lxpanel-data pcmanfm pi-greeter piclone raspberrypi-ui-mods rpi-eeprom vlc vlc-bin vlc-data
  vlc-l10n vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2
  vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization
Then I went ahead and applied the upgrade:
$ sudo apt-get -y full-upgrade |& tee -a /tmp/upgrade.log
My question is, and I have looked here in the forums as well as googling: how can I determine what a particular full-upgrade will bring across (and WHY) before doing it?
I cannot seem to find a release notes nor change log for an impending full-upgrade and wondered if this is available?
It would also be very useful to know if there is an Announcement somewhere when new stuff is added to the feeds that /etc/apt/*sources* and apt-get will draw from.
I do this stuff from the command line so I can log the results, but it would be nice to know ahead of time. Oh, and I always snapshot the uSD card ahead of time (dd it on another machine while the RPi4 is powered down) so that I can easily roll back.
If it helps/matters, this is on an RPi4 8B (#Yay!) just received.
_____
#Edit
Apologies if this is not the right place to post this; it seemed reasonable at the time.
Return to “Raspberry Pi OS”
