suggestion when setting up hostname in raspi-config
Posted: Fri May 31, 2019 7:00 pm
by AndrewdAzotus
when setting the hostname in hostname and hosts, would you consider adding
sudo cp -v /etc/hostname /boot
then I can see which image I have if/when I insert it into a windows box :)
Re: suggestion when setting up hostname in raspi-config
Posted: Fri May 31, 2019 7:44 pm
by ShiftPlusOne
I don't see that happening, given the very niche use case.
There are many Windows tools to access linux partitions.
Posted: Sat Jun 01, 2019 9:19 am
by B.Goode
The shell version of the raspi-config utility is simply a shell script stored in /usr/bin/raspi-config.
You could modify it to meet your own requirements.
If you think it would be generally useful, you could offer to share your efforts via a Pull Request to the maintainers via https://github.com/RPi-Distro/raspi-config
Posted: Mon Jun 03, 2019 2:08 am
by AndrewdAzotus
there are many tools but given that i only plug my sd card into a windows box to re-image it and I do not see that it's worth installing one of those tools just to check the hostname, it seemed like a good idea to do this so that i can confirm the host name and that i have the right card before I flash it.
Raspi-config already updates hostname and hosts with the new hostname anyway, it seems such a minimal work effort addition to make.
found the script, I'll try the git options, thanks :)
Posted: Mon Jun 03, 2019 8:02 am
by ShiftPlusOne
I wouldn't recommend taking this to github, since it was already addressed here.
