GUIzero - Need Help making my GUIzero GUI open on bootup!!!
Posted: Tue May 28, 2019 2:33 pm
by Skaterboy
I'm using guizero for a computer tech class and we are building a GUI that will show up on bootup but we are unable to make it work.
we setup the application to run on the bash file but it gives us an error message saying that the module guizero is not found. Any help would be appreciated!
Re: GUIzero - Need Help making my GUIzero GUI open on bootup!!!
Posted: Tue May 28, 2019 3:55 pm
by Andyroo
There are multiple ways for a program to start up and what is available can depend on both the user running the program and what has been set in raspi-config for logging on.
Have a look through https://www.dexterindustries.com/howto/ ... t-startup/
Without knowing a bit more about your program I’m stuck but I would check:
1) Does the program require a network - Set in raspi-config
2) Do you want to start the GUI as Pi - Set in raspi-config
I would then look to the systemd module start up rather than rc.local as it’s very easy to lock yourself out with rc.local errors (though you can fix it with a edit to cmdline.txt).
