dan_ce
Getting a disk space error on the daily despite...
Mon May 20, 2019 9:46 am
/etc/cron.weekly/man-db:
/usr/bin/mandb: can't write to /var/cache/man/23501: No space left on device
/usr/bin/mandb: can't create index cache /var/cache/man/23501: No space left on device
run-parts: /etc/cron.weekly/man-db exited with return code 2
Hallo!
I'm getting this error daily now despite there being seemingly lots of space on the drive. Bit confused! Have followed a few of the suggestions found on online articles for what to do in this situation but nothing has helped.
Output of mount command
[email protected]:/dev $ mount
/dev/mmcblk0p2 on / type ext4 (rw,noatime,data=ordered)
devtmpfs on /dev type devtmpfs (rw,relatime,size=217600k,nr_inodes=54400,mode=755)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
tmpfs on /home/pi/log type tmpfs (rw,noatime,size=204800k,uid=1000,gid=1000)
/dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
//192.168.0.100/documents on /home/pi/macmini type cifs (rw,nosuid,nodev,noexec,relatime,vers=1.0,cache=strict,username=danebdon,domain=WORKGROUP,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.0.100,soft,unix,posixpaths,serverino,mapposix,acl,rsize=61440,wsize=65536,echo_interval=60,actimeo=1,_netdev)
tmpfs on /run/user/998 type tmpfs (rw,nosuid,nodev,relatime,size=44380k,mode=700,uid=998,gid=995)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=44380k,mode=700,uid=1000,gid=1000)
[email protected]:/ $ ls | xargs du -hs
0       proc
0       sys
100K    media
109M    etc
12K     mnt
16K     lost+found
22M     boot
238M    lib
23M     boot.bak
23M     run
3.7M    dev
36K     tmp
4.0K    debootstrap
4.0K    root
4.0K    srv
4.3G    home
412M    var
42M     opt
6.8M    bin
7.4M    sbin
853M    usr
Any help most welcome!
B.Goode
Re: Getting a disk space error on the daily despite...
Mon May 20, 2019 10:01 am
What does
df -h
reveal about the free space (not inodes) on your filesystems?
dan_ce
Mon May 20, 2019 10:35 am
Sorry I thought I'd included this image but it looks like when you select a few images in the directory it will still only upload one!
Ernst
Mon May 20, 2019 10:46 am
You should have noticed the problem when you posted the screen shot: your memory card is too small (or not properly adjusted).
B.Goode
Mon May 20, 2019 10:56 am
The first line of that most recent report clearly confirms the message from Cron - there is no space left on your root filesystem ( ' / ' ), which is where files being written to /var will go...
dan_ce
Mon May 20, 2019 11:10 am
Really? So me disk is just full, even though the subfolders show space available? Confused.
B.Goode
Mon May 20, 2019 11:21 am
Avail = 0; Use% = 100 : Yes, your root filesystem (not necessarily 'the disk', whatever that means) is full so Cron can't write to it.
Ernst
Mon May 20, 2019 11:31 am
Where did you read that the disk is full ? I said memory card is too small (or not properly adjusted) because of the 1.8GB size of the root file system (= root partition). Based on this information I suspect that you have installed a raspbian lite version on a 2GB memory card which is the absolute minimum. My experience is that raspbian lite should have a memory card with preferably 4GB and raspbian with desktop preferably 8GB or more
Paeryn
Mon May 20, 2019 1:38 pm
Most of those listed have their file system as tmpfs, those exist in memory only and their contents are not part of the physical disk.
dl324
Mon May 20, 2019 7:05 pm
What matters is the partition that you try to write to.
Check /var/cache:
df -h /var/cache
Return to “Raspbian”
