zavoodi
Dependency problem; can't install libcaca-dev
Sun May 19, 2019 4:35 pm
I've first run
$ sudo apt-get update
I then run:
$ sudo apt-get install libcaca-dev
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
 libcaca-dev : Depends: libcaca0 (= 0.99.beta19-2) but 0.99.beta19-2+deb8u1 is to be installed
How do I resolve this problem?
Return to “Raspbian”
