Updated to debian 9.9
Posted: Fri May 17, 2019 11:16 pm
by kflmiami420
Hello I updated my pi zero W to the latest and now I have a message
in my system when I type LS to syy my files that reads
" release, wpasupplicant no longer respects the system"
What does it mean ?
this is my setup
Pi Model : Raspberry Pi Zero W Rev 1.1
System : Linux-4.19.42+-armv6l-with-debian-9.9
Revision Number : 9000c1
Serial Number : 00000000b580be1c
Python version : 2.7.13
I2C enabled : True
SPI enabled : True
CPU Clock : 1000MHz
CPU Temperature : 44.40°C
GPU Temperature : 45.46°C
RAM (Available) : 369MB (88MB)
Disk (Available) : 30G (23G)
Re: Updated to debian 9.9
Posted: Sat May 18, 2019 5:36 am
by Milliways
You didn't update to latest!
You installed an experimental kernel and presumably firmware, probably from running `rpi-update`. There are outstanding issues with the 4.19 kernel.
sudo apt-get update; sudo apt-get install --reinstall raspberrypi-bootloader raspberrypi-kernel
will put it back to the latest supported kernel/bootcode.
