mhorton
How to recompile dhcpcd
Wed May 08, 2019 8:17 pm
I have a copy of Stretch installed, which comes with dhcpcd 6.11.5. I would like to modify dhcpcd,and I'm having trouble.
I downloaded the current dhcpcd 7.99 from github. It compiles OK but does not run correctly, and it's clearly very different from the one on the system.
I downloaded the 6.11.1-DNA version from github, but it won't compile. It seems to want the header file <curl/curl.h>, which is not in the package, and even though curl is installed on my PI, there is no such header file in /usr/include.
The Raspbian branch on github doesn't seem to include utilities like dhcpcd.
Where can I find, or how can I configure, dhcpcd source code to compile and run correctly on my pi?
Re: How to recompile dhcpcd
Thu May 09, 2019 5:00 am
Uncomment the line in /etc/apt/sources.list that says
#deb-src http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
Then
sudo apt update
apt source dhcpcd
and the full source will be downloaded. You may need to install some additional packages to be able to compile it and build a new package (see package build instructions for Debian).
Signature is on holiday.
Return to “Raspbian”
